06-04-2009, 08:45 PM | #1 |
Member#: 107179
Vehicle:S4, WRX 1.27 60', 9.37 1/4 |
2.0L 20g 100 octane
I just got back from my new tune at P&L Motorsports for 100 octane on my 20g and I am very happy with it. It might have made a bit more as it is only a td05 and still using the internal wastegate but I'm very happy where it is at.
Event: dyno pull Location: P&L Motorsports, Franklin Park IL Ambient Temp: 81 Elevation: ~650 feet Weather: warm and sunny Tires: Geforce sports 234/45/17 Car: 2003 WRX Tuner: Jorge Dyno Info: DynoJet Peak HP at RPM: 361 @ 6450 on 100, 326 @ 6500 on 93, uncorrected Peak Torque at RPM: 335 @ 4300 on 100, 285 @ 5200 on 93, uncorrected Baseline hp/tq for a stock on same dyno: 230-240 stock STi Target Boost: 26 on 100, 21 on 93 Target AFR: 12.2 on 100 11.6 on 93 Fuel: Sunoco GT 100, and Shell 93 Engine/Power Modifications: Full power mod list listed below Driveline Modifications: 03 WRX 5 speed with RA 1-4 and ACT stage 1 clutch Suspension Modifications: Coilovers, swaybars, endlinks, rear dif bushings Other Modifications: BBS wheels with wider than normal tires Power mods: Deadbolt td05 20g Borla exhaust manifold APS up-pipe APS 3" exhaust Deatschwerks 750cc injectors APS Top Mount intercooler Samco turbo inlet P&L high flow intake AEM map sensor Stock 2.0 block @94k miles Green lines are my original tune 93 octane tune at 21 tapering to 19 and change PSI. (this did not have the AEM Map sensor or the P&L high flow intake) Blue lines are my new 93 octane tune with 21 psi. Red line is my new 100 octane 26 psi tune. I am also very thrilled about is how much faster the car spools up compared to my previous 20g tune. The pulls started a little bit earlier so I don't know the exact amount of difference but you can see it comes on a good bit sooner and Jorge was saying full boost was hitting around 3800-3900 rpms. Thanks again to the guys at P&L Jorge specifically for a highly enjoyable car.
06-04-2009, 08:49 PM | #2 |
Member#: 110273
Vehicle:450 whp 30R STI 10.96@126 |
Nice, Definately not bad at all for a tod5 20G on 100oct.. Glad you like it!
06-04-2009, 09:33 PM | #3 |
Member#: 173241
TXIC
Vehicle:2002 s256 twinscroll now with one more gear |
looks good
06-04-2009, 09:38 PM | #4 |
Member#: 168386
Your running out of things to do now...
But gratz, the numbers are sick. You sounded so excited when i called you... lol |
06-04-2009, 09:40 PM | #5 |
Member#: 126441
SCIC
Vehicle:03 bugeye |
that looks nuts. very nice
06-04-2009, 09:43 PM | #6 |
Member#: 107179
06-04-2009, 09:45 PM | #7 |
Member#: 173241
TXIC
man i wounder what i would make on 100oct, i am really really limited on my torque because of the fact that i live in texas at sea level and its fing hot, what kinda of timing are you running
06-04-2009, 09:59 PM | #8 |
Member#: 107179
I'm not sure, to be honest. I turned in my car and some money and got back a lot faster car, thats all I really know
06-05-2009, 12:49 AM | #9 |
Member#: 173241
TXIC
haha nice
06-05-2009, 01:09 AM | #10 |
Member#: 194599
Vehicle:2005 Legacy GT OBP |
Nice numbers.
06-05-2009, 01:34 AM | #11 |
Member#: 125529
Vehicle:02 WRX 18G EJ205 1/4 mi stock block record |
Very nice,...
More info on the P&L intake please... Perhaps Jorge can chime in and fill us in on the tune details,.... Was the timing any different on the new tune>?(pump) How much extra power do you think the intake really makes with this setup and do you think the 12 degree cooler temps and less humidity played a factor in the number differences ? Overall looks like a fun ride |
06-05-2009, 02:07 AM | #12 | |
Member#: 107179
http://www.pandlmotorsports.com/osCo...roducts_id=352 As to whether it can be entirely attributed to the intake or the tune, I can't say for sure, but I can see at least a good chunk being due to the intake. The turbo XS short ram I had has a fairly small (1/2 the length roughly) filter compared to the P&L one. In my mind (please someone chime in if I am wrong) if that filter were what was slowing my spool by taking more effort to pull the same air through, I could see that making a good difference. Not only that, but that small piece of corrugated piping after the intake is gone with the P&L intake which I could see causing funky air flow in the intake. I'm not concerned with the number differences between my old 93 map and the new 93 map. What I'm exceptionally happy with (in addition to the rest, obviously) is the power coming earlier. I really only asked him to add it so I could see the difference in spool on the same sheet because that seemed to me to be too significant to just be a fluke. |
06-05-2009, 11:07 AM | #13 |
Member#: 125529
OK well its a BIG MAF,.. that makes sense. The Diameter changed from 2.4 to 3.0 . For some reason last night (half asleep) I was thinking intake manifold lol
What size inlet does your turbo have? |
06-05-2009, 12:02 PM | #14 |
Member#: 107179
The turbo inlet is 2.4 inch. I originally wasn't planning on pushing the car quite this far (imagine how that works out ) so some things that could have been done (like EWG and larger hot side) weren't.
06-05-2009, 05:06 PM | #15 |
Member#: 125529
I hear you,.. I am on a 2.4in inlet PNP 7cm 18G EWG
went 11.96 @ 117 on C16 @ 22psi. Now considering BIG MAF with the MAP sensor and pushing the tune past 26 to see whats really up Are you on stock trans? How did you convince Jorge to push this tune this hot? We all know how conservative he is |
06-05-2009, 05:24 PM | #16 |
Member#: 121549
Vehicle:2020 Supra LE Renaissance Red 2.0 |
looks good. i need to get my car up to jorge and get a better tune. gotta install the aps 70mm intake, perrin ebcs, and turbo inlet on mine first. possibly header also.
06-05-2009, 05:42 PM | #17 | |
Member#: 107179
It's funny you should ask, when I walked in yesterday one of the questions he asked me was "aggressive or conservative" so naturally I tried the middle ground and he said something like "scantrons don't have a fill-in-the-blank" and doing his usual thing that gets me to think about what I'm doing. A little bit later we were on the dyno after the first pull at 360whp (like the 3rd or so 100 octane pull, but the first that hit 360) on 100 octane he turns to me asking "win or wuss, right now we're somewhere in the middle". So I made the decision to pull what my friend called the "boost tampon" out and responded "win." He was actually going to go a bit further than this but the IWG td05 hotside wouldn't let us. The more I think about it though I'm not sure this tune is all that "hot" in and of itself, it's just that it is in the territory of natural mechanical problems for the transmission and stock block. I don't think 36 whp is a big request from going from 93 octane to 100 octane. (Here is where my ignorance from not being a tuner shows) Last edited by RexFTW; 06-05-2009 at 05:53 PM. Reason: Added more |
06-06-2009, 12:10 AM | #18 |
Member#: 125529
I got the same rhetoric from him when he tuned me, unfortunately I had some issues and we stopped @ 315 or so.
I would be willing to bet his timing is conservative for 26psi I am surprised he didnt give you the lecture about an open deck block and ovaling of the tops of the cylinders,....lol Enjoy your ride,... get it to the track so we can see some trap speeds |
06-06-2009, 02:31 AM | #19 | |
Member#: 107179
Ever since I started working with P&L I've always had bigger plans than I needed and Jorge keeps reeling me back. I think like a chess player and even though I don't always make the absolute best move I still at least measure all known options to some extent. I'm probably Jorge and Paul's most annoying customer as I forever have a question either relevant to my car currently or plans rolling around my mind. Last edited by RexFTW; 06-06-2009 at 02:39 AM. |
06-06-2009, 03:55 AM | #20 |
Member#: 41754
Vehicle:03 wrx gt35r, 2.5L, meth |
very nice, I used to have a td05-20g - I think it's the best overall turbo for the wrx on meth or 100oct. Surprisingly responsive yet provides good power!
06-06-2009, 07:38 PM | #21 |
Member#: 78770
Vehicle:03 wrx wrb |
What are you expecting 1/4 mile time? or have you researched what similar WHP cars do?
06-06-2009, 08:05 PM | #22 | |
Member#: 107179
I wouldn't be surprised if I did like 12.5@110 and change or something like that. If I had a 6 speed I'd be more willing to throw down but I'd rather get at least some life out of the RA gears. |
06-07-2009, 12:51 AM | #23 | |
Member#: 29933
Vehicle:2004 STI Silver/Silver |
06-08-2009, 03:28 PM | #24 | |
Member#: 107179
Last night was time to put some more gas in and I was able to talk myself into getting the 93 octane back in after running 100 for the weekend . We'll see how long that lasts . |
06-08-2009, 03:34 PM | #25 |
Member#: 176103
Vehicle:2004 WRX Blouch 18g 324whp |
^^^ lol. It's a tad bit extra, as if gas already isn't expensive enough
Similar Threads | ||||
FP Green - 2.0L - 360whp on 94 octane | Master2192 | Proven Power Bragging | 38 | 08-10-2010 05:41 PM |
02 WRX Wagon Stock 2.0L Blouch TD05 7cm^2 20g Tuned By AMS | Krang | Proven Power Bragging | 34 | 01-10-2010 09:44 PM |
WRX 2.0L 20G Dyno w/ Ecuedit | akira02rex | Proven Power Bragging | 27 | 09-28-2007 09:46 PM |
STI + 20G + 100 octane = 398 wheel torque | Drews_WRX | Proven Power Bragging | 8 | 06-13-2005 09:01 PM |
ecotek 2.0L = 1,100 HP ! | IllNastyImpreza | Off-Topic | 13 | 01-29-2004 12:41 PM |
