Welcome to the North American Subaru Impreza Owners Club Monday October 22, 2018
Old 05-25-2005, 11:41 PM   #1
jlam86
Member#: 86822
2004 WRX
Default first gear is being a bitch (5km/h)
I noticed my car won't allow me to switch into first when I'm going really slow. It has to be pretty much at a dead stop before it will allow me to. Is this common with all subaru's or what?
Also, my second gear sounds a little funny. Doesn't do it all the time. Just when it feels like it. It makes more of a high pitched noise. Hard to explain. Definately not quite like the rest. Assistance please!
thanks
Justin
jlam86 is offline   Reply With Quote
Old 05-26-2005, 01:18 AM   #2
Impreza_RX
Member#: 68015
2006 WRX TR
Steel Gray Metallic
deal with it?
im seems like subarus werent made to go into first when rolling.
the high pitch noise just might be in ur head. turn up the music...
Impreza_RX is offline   Reply With Quote
Old 05-26-2005, 07:49 AM   #3
orndog
Member#: 34670
2016 slowmobile
Make sure your fluid isn't low - especially if it's a new car.
orndog is offline   Reply With Quote
Old 05-26-2005, 08:55 AM   #4
lionken07
Member#: 13660
16 BRZ Limited 6MT
04 WRX 5MT
first gear is always a bitch.
Either double clutch to first or don't put it in 1st unless your in a dead stop.
lionken07 is offline   Reply With Quote
Old 05-26-2005, 02:36 PM   #5
Davemeister
Member#: 86577
2018 Supercoolmobile
Awesome Pearl Metallic
Usually I put it in 2nd and engine brake, then clutch in and 1st is pretty easy to get into.
Davemeister is offline   Reply With Quote
Old 05-27-2005, 12:54 AM   #6
Imprezivblue
Member#: 75678
2000 2.5 RS BRP
1st gear is more of a bitch to get into than any other gear- but as long as you rev match it should be fine. I had a friend on an autox course drive my car and he was on the top of first and second- shifted 9 times around the 30 second course! So- if he can do it, I can learn to do it. I've been practicing for a while because i know its been tough to get into- just not autox course ready to be shiftin like that.
Cliff Notes: It can be done with rev matching with enough practice.
Imprezivblue is offline   Reply With Quote
Old 05-30-2005, 04:06 PM   #7
Suby1128
Member#: 33995
2002 WRX Sedan
Sedona Red Pearl
it's because 1st gear isn't synchronized, just like reverse. You'll end up breaking your 1st gear if you keep trying to slam it into 1st from a roll.
Craig
Suby1128 is offline   Reply With Quote
Old 05-30-2005, 05:05 PM   #8
Davemeister
Member#: 86577
1st gear does have a synchronizer.
Old 05-30-2005, 07:50 PM   #9
Anub1s
Member#: 81106
2014 Baby Mobile
Whitey White
Here's a tip, if you are rolling and need to go into first, give the car a little bit of gas, everything lines up better and the gear slides right in.
Anub1s is offline   Reply With Quote
Old 06-01-2005, 04:30 AM   #10
TurboReXx007
Member#: 84148
2005 Wrx
black
yeah thats a good option or while you are rolling hold it to the 1st gear position and it should also slip in while you are slowing down.
TurboReXx007 is offline   Reply With Quote
Old 06-01-2005, 07:42 AM   #11
Davemeister
Member#: 86577
Holding it in place is just waiting for the synchro. That causes wear on the synchro. It's better to rev match, as he describes.
Old 06-01-2005, 12:32 PM   #12
balajc
Member#: 15393
MY00 2.5RS Coupe 5MT
Silverthorn Metallic
do what he said...I can double clutch into 1st going 10mph (not that I would do it all the time)
balajc is offline   Reply With Quote
Old 06-01-2005, 03:48 PM   #13
Imprezivblue
Member#: 75678
2000 2.5 RS BRP
bingo!
05 tranny is finally in my 02 wagon, but first gear is weird... dwike Transmission (AT/MT) & Driveline 0 03-30-2008 08:21 PM
I think my first gear is ****ed up WRX_Mike Transmission (AT/MT) & Driveline 3 02-17-2006 10:56 PM
Pic of broken first gear. Which gear is this.. quickscooby Transmission (AT/MT) & Driveline 2 01-03-2004 12:56 PM
I spoke too soon..... first gear is clicking.... GregUnd Texas Impreza Club Forum -- TXIC 19 11-13-2002 07:32 PM
('93-'01) Have no Fear, First Gear is Here Aspen_2.5RS Impreza Forum 3 05-31-2001 12:30 AM
