Welcome to the North American Subaru Impreza Owners Club Wednesday May 29, 2024
Old 12-24-2006, 05:14 PM   #1
v8eaterWRX
Member#: 108547
2017 Tundra 1794
Lifted, Armored, Muddy AF
Default wont boost over 5psi
I took my car from Phoenix, AZ to Flagstaff, AZ for Christmas. This morning when I went to leave my hotel the car didn't want to start. When it finally started, it idled really weird, going from around 500 rpms to 2000 rpms. Felt like it was going to die. I let it run for about ten minutes before leaving to warm up. Now it will not boost over 5 psi. Last night I put gas in it at a litle hole in the wall station last night because it was the only one around so I think I may have gotten bad gas, but I have no cel. I added some octane booster to see if it would change, but nothing yet. Yesterday before I left it shot some black crap out of the exhaust but I assumed it was from the Lucas injector cleaner I was running. The exhaust seems clean now. Reset the ecu and changed the realtime map to stage 2 91 octane but still won't boost. No metal shavings in the oil, and its a fresh change to Royal Purple 10w40. Car is an 05 wrx, perrin inlet hose, sti tmic, helix catted down, greddy evo 2 cb, cobb up, cobb ap.
v8eaterWRX is offline   Reply With Quote
Old 12-24-2006, 05:17 PM   #2
nkx
Member#: 96951
2004 wrx sedan
'10 Outback 6mt-wifey's
did you check all the vac/boost hoses? and the hoses on the output side of the compressor?
nkx is offline   Reply With Quote
Old 12-24-2006, 05:23 PM   #3
v8eaterWRX
Member#: 108547
2017 Tundra 1794
yup. no abnormal noises like leaks either. the turbo to tmic is off a little but still sealed (always like this, only about 1/8''). someone said my turbo may be shot, its at 31k so I guess maybe, but only had the junk in the exhaust once.
Old 12-24-2006, 05:31 PM   #4
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
There's always a chance the black stuff was your cat de-catting itself (thought it doesn't sound related to the rough running/low boost). How many miles you got on it?
lancelucas is offline   Reply With Quote
Old 12-24-2006, 05:35 PM   #5
v8eaterWRX
Member#: 108547
2017 Tundra 1794
at least 10k maybe 20k. could the low boost be because of bad gas?
Old 12-24-2006, 05:38 PM   #6
haw4747
Member#: 135714
i don;t think bad gas would cause you to not boost above 5psi. it would certainly hurt your ability to conrol knocking but it wouldn't reduce boost so severely.
haw4747 is offline   Reply With Quote
Old 12-24-2006, 09:50 PM   #7
v8eaterWRX
Member#: 108547
2017 Tundra 1794
I checked my boost electronically with my ap and it is reading 13-14 psi, so it seems that my mechanical gauge is just off? I'm still a little low, but not as drastically. I guess its just the change in elevation?
Old 12-25-2006, 03:05 AM   #8
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Originally Posted by haw4747
i don't think bad gas would cause you to not boost above 5psi.
If the Ignition Advanced Multiplier [IAM] drops low enough because of knock, the ECU turns off boost control and this would limit him to wastegate boost (7-9 psi) which could show up as 5 if his boost gauge is off.
Old 12-25-2006, 06:06 PM   #9
emo_tactical9
Member#: 135814
95 240sx SE
95 200sx SE-R - 84 200sx
I once had my car act like it was going to die everytime it would boost just driving on the interstate. It got so bad that it did it even when still in vacuum. Thought the fuel pump was going out. I ended up adding some octane booster and chalked it up to bad gas. It hasn't done it since.
emo_tactical9 is offline   Reply With Quote
boost won't go over 5psi what the hell? jevera2k Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 05-07-2014 02:36 AM
BIG 16G install, cant boost past 5psi AntiZeroTrip Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 05-02-2009 12:12 PM
no boost only 5psi hooptywrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 08-09-2005 10:45 AM
Stock 04 WRX max boost 13.5psi, but..... AWDrifter21 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 01-20-2005 01:53 PM
HELP!Car wont get over 3800 rpm? 4CEFED6 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 27 08-19-2002 10:23 AM
