11-30-2006, 02:46 PM | #151 |
Member#: 113031
Vehicle:2002 wrx wrb |
i did this the other day in my 02, it was a lot easier than i thought it would be... the only difference was i only had to remove that one piece of silver trim around the cd player, and the heat/ac controls
12-27-2006, 09:33 PM | #152 | |
Member#: 116052
Vehicle:2011 STI ( Sold ) WRB |
12-28-2006, 12:42 PM | #153 |
Member#: 110438
SCIC
Vehicle:2006 STi (XPT Stg2) CGM |
How does the antenna power cable looks like? I have a horrible radio reception on my new HU, I assume it's because of the antenna power not connected. Anybody have a pic lying around somewhere? =)
12-28-2006, 02:16 PM | #154 |
Member#: 125857
NESIC
Vehicle:2006 WRX Wagon Lmtd WRB |
Same thing here, I installed the Alpine 9856 and both AM and FM are pretty weak, have been since the day I installed. I have read a few places that said to hook up the power ant. connection (i didnt do that when installing) but the alpine manual says
"Power Antenna Lead (Blue) Connect this lead to the +B terminal of your power antenna, if applicable. • This lead should be used only for controlling the vehicle's power antenna. Do not use this lead to turn on an amplifier, or a signal processor, etc." So I am not sure what to do. Any help would be appreciated! |
12-28-2006, 04:11 PM | #155 |
Member#: 110438
SCIC
Well, I just took my car back to the shop which installed the audio system for me. I brought a picture of the antenna power cable (there is a thread here somewhere, just search "antenna power"). 5 minutes and it's done. Reception is great.
12-29-2006, 01:41 AM | #156 |
Member#: 99289
12-29-2006, 08:50 AM | #157 |
Member#: 125857
NESIC
I understood what people were saying and what they were doing to fix their issue but I found it odd that the Alpine manual said to not connect the power ant. cable to an amplifier. I figure i wont break anything so ill give it a shot.
12-29-2006, 09:07 AM | #158 |
Member#: 78952
Vehicle:2005 WRX CGM |
Dude, they mean an audio amplifier, not a powered antenna amplifier They don't want people using the power antenna amplifier as a remote lead that's all.. Connect it and be done...otherwise suffer with poor signal This has been a common known issue for years now. It still amazes me when guys resist doing what everyone here who has an aftermarket unit has already done. Sorry to go on a rant, but this is something that shouldn't be discussed...it just should be done.
12-29-2006, 01:47 PM | #159 |
Member#: 62023
NESIC
Vehicle:2018 4dr Scat Pack |
Does anyone know if there is a wiring harness for Kenwood Stereos that will connect directly to the Impreza wiring harness?
Or do you have to get a Subaru harness and solder it to the Kenwood harness? I just stopped at 4 different autoparts stores around town and NONE of them had a Subaru wiring harnesses. The one place had a harness guide and it said they didn't make one for the Impreza. WTF?! |
12-29-2006, 02:06 PM | #160 |
Member#: 110438
SCIC
Just go to your "Jack's Super Stereo Installations!!" or whatever local stereo shop you have there. People there usually care about making money and will order whatever harness your heart desires. That's what I did and had a wonderful $70 install with lifetime warranty and all that.
12-30-2006, 12:32 AM | #161 |
Member#: 112854
Vehicle:2009 IS-F 2014 Forester XT |
Excellent write up. It took me 30 minutes to install my alpine cda9857.
12-30-2006, 05:59 AM | #162 |
Member#: 110109
VIC
Vehicle:2006 Impreza 2.5i Aspen White |
Thanks for the write up. This thread and the webpage explaining the wire harness helped a lot.
I also made the mistake of not hooking up the wire for the antenna booster. I guess it's a common problem. |
12-30-2006, 09:41 AM | #163 |
Member#: 62023
NESIC
So I finally found the harness but when I was wrapping up the install I found that my Kenwood HU is too wide for the stereo bezel. WTF?!?
The Face plate on the factory stereo tapers in about a millimeter or two on the sides and top, but the Kenwood unit does not. How do I fix this? I guess I can either dremel the dash bezel so that it fits but I'm not sure how that's going to come out. Or I can see if the metal fram around the stereo face can be cut out. I hate stereos. |
01-03-2007, 04:30 PM | #164 |
Member#: 131897
Vehicle:2010 STi 05 FXT SSM |
I just finished an install and instead of an aftermarket pocket I used the Forester DIN pocket with pop up door...see pics...
01-05-2007, 04:36 AM | #165 |
Member#: 108772
South East
Vehicle:2006 WRX TR Black |
Got my Alpine 9856 in today and i can't seem to get these screws out:
did anyone else have trouble getting these out? they're just really tight and 1 screw has already started to strip. |
01-05-2007, 06:02 AM | #166 |
Member#: 106753
NESIC
Vehicle:2017 Focus RS Wht |
OK where the hell does the pink wire go ??????
01-05-2007, 09:37 AM | #167 |
Member#: 99289
Use the proper sized bit, in a drill at low speed. It allowed me to press down with full force, and back out the screws. And what does the tag on the pink wire say? (my guess is "mute in")
01-05-2007, 09:46 AM | #168 | |
Member#: 89252
Vehicle:2005 STi PSM |
I got ONE of those screws out with a phillips head. ONE. The other 7 had to be dremmeled to flathead style and muscled out. Those screws were the biggest PITA of my entire radio install. |
01-05-2007, 10:25 AM | #169 |
Member#: 88668
NESIC
Vehicle:'05 Outback Sport 5MT - Regal Blue / Grey |
They're on very tight, and seem to be somewhat seized. I was able to get them out by using a large phillips (larger than a #2 - biggest you can squeeze in there), and pushing down as hard as possible so the screwdriver doesn't lift and strip the bolts. As soon as you crack it, they'll come out no problem. Just takes a bit of muscle to get it going.
01-05-2007, 11:52 AM | #170 |
Member#: 3601
NWIC
Vehicle:2006 WRX Wagon BRIGHT BLUE! |
I had no problem removing the screws - if I had I would have used the motorcycle impact screw driver which hammers the bit into the screw as it turn it.
http://www.harborfreight.com/cpi/cta...emnumber=37530 |
01-05-2007, 02:11 PM | #171 |
Member#: 50490
South East
Vehicle:07 097/800 UGM STI Dirty |
I had to buy a "screw out" set from Sears. It was ~$10 and worked just fine for the one screw I stripped completely round.
http://www.sears.com/sr/javasr/produ...seBVCookie=Yes |
01-05-2007, 05:45 PM | #172 |
Member#: 106753
NESIC
01-06-2007, 01:20 AM | #173 | ||
Member#: 25837
South East
Vehicle:1996 SVX L AWD Laguna Blue Pearl |
Incidentally, you can download the manuals from most radio manufacturers. That's how I checked this wire. For Alpine, go to http://www.alpinetechcenter.com/ then click on the "Continue without login >>" link. [ADDED:] And to answer the question, unless you have a phone kit, you should tape off the end of this wire (or use some heat shrink). Save it in case you decide to use it some day. Last edited by SVXdc; 02-23-2007 at 01:21 AM. |
02-04-2007, 02:07 AM | #174 |
Member#: 133615
NWIC
Vehicle:2005 STI GUY SWRB |
I have a few battery hookups (yellow wires) for the HU, Ipod adapter, subwoofer (same for ground). Are there any concerns on wiring all of these to the stock harness or should the non-HU connections be wired to the battery directly?
Thanks! |
02-10-2007, 12:28 PM | #175 |
Member#: 137331
Vehicle:2007 STI WRB |
Very helpful pictures, thanks a ton!
How to install 2007 AUX Input on 2006 WRX? | GooseMan | Car Audio, Video & Security | 5 | 08-15-2011 05:27 PM |
How-to install a stereo in a 1993 Impreza L | rizwan | Car Audio, Video & Security | 5 | 12-05-2009 02:26 PM |
How to install A system in your 06 Impreza | Harley Sporty | Car Audio, Video & Security | 57 | 02-12-2009 09:47 PM |
How to install new pedals on a 2006 STI | Jag32 | Interior & Exterior Modification | 4 | 06-30-2006 01:24 PM |
How to install aftermarket stereo in '02 WRX | joeroket | Car Audio, Video & Security | 4 | 04-28-2005 07:28 PM |
