So I purchased the F1 rear fog light for my 2015 WRX. It is the smoked lense with red square bar. After installing it as per the instructions I came across an issue I was hoping someone could help me out with. When the car is on, the center of the fog light are lit up. When pressing the brakes the center gets brighter and the square bar also lights up. My question is this. How do I fix it so the square light bar is lit up with the center only coming on when the brake light is pressed?
I just think it looks nicer when all you see is the square red bar lit up while driving. As of now at idle the center is lit up with the red bar lighting up only when the brake is pressed. I used the plug and play harness and followed the included instructions. Any ideas or help would be much appreciated.
