Welcome to the North American Subaru Impreza Owners Club Tuesday October 15, 2019
Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.0L Turbo Powertrain
Old 08-22-2019, 12:20 AM   #26
adam99
Member#: 480524
2015 WRX
Catted or catless exhaust? If it is catless with the combo of header and intake then it will 100% creep. If you are then get you wastegate ported or just go with socal v3 or fp blue.
adam99 is offline   Reply With Quote
Old 08-22-2019, 05:51 AM   #27
dreew
Member#: 450499
2015 wrx
black and gray
Good luck with your build. I had to recently rebuild my 2015 FA and went thru all of this and used similar parts. After my build the car never sounded the same and i kind of have PTSD thinking that that little tick i hear sometimes is going to be another motor i cant afford.
dreew is offline   Reply With Quote
Old 08-22-2019, 09:37 PM   #28
bluewrx2018
Member#: 485226
Originally Posted by WRXnick16 View Post
You won't need a new clutch with your low mileage and power levels. Obviously you'll need to look for an upgrade if you go with a larger turbo and start pushing higher power levels later on. It really just depends on your plans for the car and if you would rather replace it now while the engine is out or wait and pay the labor cost again down the road.
The tuner said stock fueling is holding me back. Said the stock turbo has more power to offer. Just getting the fuel now is the bottle neck.
I might keep the stock clutch for awhile. And see how things go.
bluewrx2018 is offline   Reply With Quote
Old 08-22-2019, 09:39 PM   #29
bluewrx2018
Member#: 485226
I have a HFC on the J Pipe.
The exhaust is all straight piped with muffler deletes.
Old 08-22-2019, 09:42 PM   #30
bluewrx2018
Member#: 485226
Thank you.
Itís an expensive hobby. Thatís for sure.
The rod knock was the worst sound I have ever experienced with any engine. One I will never forget.
Old 08-22-2019, 11:20 PM   #31
WRXnick16
Member#: 447898
2016 WRX (traded)
2019 STI CWP
You may want to get a second opinion on the fueling. I've seen numerous builds on ethanol pushing over 400whp without any fueling issues. I actually saw a post about a 580whp build the other day and the tuner (stimikey) commented that they finally ran out of fuel and will have to install a port injection system to push further.
The FA20's direct injection system can flow a lot of fuel. It's just the HPFP that doesn't do well with ethanol mixes over E60.
WRXnick16 is offline   Reply With Quote
Old 08-23-2019, 07:28 PM   #32
bluewrx2018
Member#: 485226
Itís definitely the HPFP. Thatís what he said I needed to upgrade.
Old 08-23-2019, 07:33 PM   #33
bluewrx2018
Member#: 485226
I also want to put this out there for everyone with a EJ or FA. An AOS is a must. My tuner stated relieving the crankcase pressure could prevent issues with these engines. If you are doing any modifications do yourself a favor a install a AOS. Small price to pay initially that could save you big money in the long run.
Old 08-24-2019, 06:05 AM   #34
violentleaf
Member#: 432126
2015 WRX
Galaxy Blue
Not sure what you mean here. All cars for a very long time now have pcv systems that relieve crankcase pressure into the intake. The aos is more or less just a filter.
violentleaf is offline   Reply With Quote
Old 08-24-2019, 12:24 PM   #35
GlarryHoodDIT
Member#: 460907
2016 WRX
Right but when you explain it like that the tuner cant make money selling one to you.
GlarryHoodDIT is offline   Reply With Quote
Old 08-24-2019, 12:32 PM   #36
adam99
Member#: 480524
2015 WRX
Old 08-24-2019, 01:11 PM   #37
WRXnick16
Member#: 447898
2016 WRX (traded)
2019 STI CWP
There's no need to upgrade the HPFP unless you plan on running over 500whp (not happening on the stock turbo). Otherwise, the only limitation is that you shouldn't run over an E60 blend on the stock HPFP, but you won't gain much (if any) power going above that.
An AOS is far from necessary for a daily driven street car. Its main purpose is to help reduce blow-by gasses and oil from making its way into your intake tract & forming a thin film in your intercooler. This becomes more important if you track your car and see sustained boost & rpm or if you're running flex fuel. Think of it as more of a preventive maintenance item.
Between the HPFP and AOS comments, I'd be questioning if the tuner is just trying to make more money off of you and/or how much experience they have with the platform. Are you planning on running straight E85 or flex fuel?
Old 08-24-2019, 06:30 PM   #38
bluewrx2018
Member#: 485226
I know what it does. After spending the money I am spending a 400 dollar part is piece of mind.
Old 08-24-2019, 06:32 PM   #39
bluewrx2018
Member#: 485226
Iím in sales so I get it. Itís something I didnít want to omit from my build. Makes sense to have it.
Old 08-24-2019, 06:48 PM   #40
Rexy18
Member#: 500337
Not to me. 400$ that could have gone somewhere else, hope you sleep well at night.
Rexy18 is offline   Reply With Quote
Old 08-24-2019, 07:26 PM   #41
bluewrx2018
Member#: 485226
To each there own. I sleep very well
Old 08-26-2019, 07:43 PM   #42
bluewrx2018
Member#: 485226
Just ordered the Perrin Front Mount Intercooler for this build.
I used coupon code SAVE10 on Perrinís site for 10 percent off. FYI.
Will keep you all posted once I buy more add onís to this build and engine build progress.
Old 08-31-2019, 08:36 PM   #43
bluewrx2018
Member#: 485226
ProCom has received all parts to start the engine build. It will start right after the Labor Day Holiday. Stay tuned.
Old 09-03-2019, 07:18 PM   #44
bluewrx2018
Member#: 485226
Couple pics of Perrinís Boost Controller
Couple pics of Perrinís AOS
Couple pics of Perrinís FMIC
Waiting on my boost tubes for the FMIC
All in all solid parts, well made and reasonably priced. Very good packaging.
Old 09-10-2019, 09:17 PM   #45
bluewrx2018
Member#: 485226
I added the TGV and EGR deletes to my build. Also added the Big Oil Filter Kit.
Old 09-11-2019, 06:44 PM   #46
bluewrx2018
Member#: 485226
Engine is back together. All thatís left is FMIC, TGV and EGR Deletes. The Perrin FMIC does require shaving the inside of the bumper FYI.
Old 09-12-2019, 01:51 AM   #47
F1SC
Member#: 506276
Any idea why your FA20 grenaded? I rarely see issues like that on the FA20 in comparison to the EJ25. Following this build with interest as I hope to do the same!
F1SC is offline   Reply With Quote
Old 09-12-2019, 07:33 AM   #48
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
You need to add our pickup to the mix for improve oil flow to the pump. You'll see improved pressure as well as improved cam sync.
On another note, did you see check the condition of the OEM pickup? We had two shop cars have issues. One a pickup screen failure, allowing debris into the pump. The second was silicone EVERYWHERE on the pickup screen. Usually there are some pieces, but this was a lot; far more than I've ever seen on a Subaru engine before.
Something else I noticed you're looking to do a 'big' filter. I would recommend sticking with the stock one. You're not going to find an aftermarket one that flows as well AND has the same filtration capabilities. The OEM filters have super dense filter media which gives them the bet of both. High flow oil filters are usually TERRIBLE at filtering, which is why they flow so well. For example, a K&N 'high flow oil filter' filters down to 90 microns, whereas the factory filter goes down to 5 microns. Essentially the K&N should ONLY be used for real racing where the oil/filter is changed ever few passes, stages, or so many hours of use. NOT for an application that requires 'street' use longevity.
The most important thing with these engines as far as the lubrication system is assuring the supply is good, and oil temps are king. If those two are in check (and the engine is built right, quality tune, fuel, etc...), you should NEVER have a failure due to insufficient oiling.
Looking forward to seeing how your project progresses!
KillerBMotorsport is offline   Reply With Quote
Old 09-12-2019, 09:51 AM   #49
2018wrx_newbie
Member#: 477489
2018 WRX Limited
CWP
I have nothing of value to contribute to this thread, but just wanted to say thanks for sharing the details. Interesting to see the progress.
2018wrx_newbie is online now   Reply With Quote
Old 09-12-2019, 09:42 PM   #50
bluewrx2018
Member#: 485226
Not 100 percent sure why it blew. But Iím betting because of the OTS Cobb reflash I was running. Most definitely should have had it tuned.
