Welcome to the North American Subaru Impreza Owners Club Wednesday October 23, 2019
Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.0L Turbo Powertrain
Old 09-18-2019, 10:12 AM   #1
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Default Teaser FA20 Oil Pan
We have had many requests to design a new FA20 performance oil pan. After much debate we have decided to move forward. There are many challenges in designing an oil pan for the FA20. With the manifold wrapped around the pan find room to expand the pan is difficult.
QUESTION: What features would be most important to you in an aftermarket FA20 pan?
Pick of the OEM pans we have for testing
KillerBMotorsport is offline   Reply With Quote
Old 09-18-2019, 10:48 AM   #2
adam99
Member#: 480524
2015 WRX
Its happening
adam99 is offline   Reply With Quote
Old 09-18-2019, 11:18 AM   #3
idiosyncrisia
Member#: 448185
2016 WRX
I know nothing about oiling in the FA20 system. I am on a stock block with full bolt ons. If my engine goes boom, which I hope it never does, I'll be pairing this with your pickup.
You are the self exclaimed oiling experts for Subarus, so I think a lot of the community is going to trust your judgement on whatever design you make.
Maybe in the casting by the oil fill hole, you can write "Tighten to 2 Ugga Duggas, no more." That's the only thing I can think of
idiosyncrisia is offline   Reply With Quote
Old 09-18-2019, 11:47 AM   #4
noobultimatum
Member#: 431550
2016 WRX
ALL THE STAGES
just make sure it clears well with your EWG headers.
Other than that... I'll wait for more "oil" experienced subie-bros chime in. Im still learning. My understanding of an aftermarket oil pan is extra capacity, and baffles to keep sloshing down to a min (keep the pick up covered to avoid starvation?)
How does the stock pan fare when it comes to sloshing? Is capacity an issue with stock fa pans for people who run their fa hard in different competitive conditions?
noobultimatum is offline   Reply With Quote
Old 09-18-2019, 02:41 PM   #5
RacecarWRX
Member#: 499928
2015 WRX
Pressure, pressure, pressure.
Happy to help test if needed Chris. You know the car is setup to collect data on everything.
RacecarWRX is offline   Reply With Quote
Old 09-18-2019, 10:02 PM   #6
killadawg
Member#: 424203
2016 WRX stg 4 Rally
STI Drivetrain GM
Drysump options? Redirected headers so a belt and drive can be installed?. :-).. option.
killadawg is offline   Reply With Quote
Old 09-19-2019, 06:54 AM   #7
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Thanks for the endorsement! I think that trust was earned due to the amount of R&D time we put into products, making sure the customer is not the tester.
LOL, Ugga Dugga
Capacity is not the issue as far as I can tell. More never hurts though
Like other Suby applications the stock stuff is generally OK-to-good up to a point. As driver experience and mods improve, the limits will typically be found.
It will definitely clear our headers
We will certainly be looking for those out there at the limits of the OEM system, and have the proper feedback capabilities; namely datalogging and telemetry
If we get to a level where we see a need for D.S. we'll explore that option. At this point, there is no need. Our High Performance Oil Control Valve for the EJs solved many high sustained (+1.8Gs) lateral loading. We only ever recommend DS on an EJ for banked oval/circle and some aviation applications (aerobatics; inverted, fixed bank, etc...). Otherwise, there is no need for the added cost, complexity and maintenance/reliability issues that go along with a DS. For the FA, the lubrication and PCV system is COMPLETELY different, so we'll see how that evolves over time as people push the platform in new and different ways.
Originally Posted by adam99 View Post
Its happening
Yes. Yes it is
Old 09-26-2019, 01:25 AM   #8
noobultimatum
Member#: 431550
2016 WRX
ALL THE STAGES
Are you guys planning on doing a baffle combo as well or will it utilize the factory baffle (or whatever is in there)?
