Welcome to the North American Subaru Impreza Owners Club Thursday December 3, 2020
Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.0L Turbo Powertrain
Old 09-03-2019, 06:44 PM   #1426
CBSWRX
Member#: 424895
2016 WRX - (SOLD!)
Originally Posted by Cianski06 View Post
*UPDATE* Subaru Canada fixed the car but did not call it a warranty repair and instead a "gesture of Goodwill" they're actively avoiding calling it a warranty repair. Canadians, print the SOA TSB like I did and have it ready if your pitch stop mount breaks like mine did. Subaru of Canada isn't likely to recall this issue.
Side note, the courtesy cars windscreen cracked during my time with it and the dealer is trying to get $1000 out of me for the repair. This is going to suck!!
WTF is up with Subaru Canada and getting TSB things done. Someone’s bonus must be tied to this metric. Damn near impossible for me to get a new TOB under a TSB along with getting the updated battery charging logic ECU programming. I get it, good profit to be made trying to get people to pay for a new battery every 2 years, but come on. No dice for me for getting it done under warranty. Useless support.
Glad your pitch stop mount got covered. Sucks about the cracked windshield though, hope it got sorted out
CBSWRX is offline   Reply With Quote
Old 09-04-2019, 10:53 AM   #1427
gn4rwhals
Member#: 453427
2017 WRX
Crystal White Pearl
Perrin Brace and Group N Pitch stop installed over the weekend, little to no NVH added.
Not a hard job if you have a buddy help out when bleeding the clutch line.
gn4rwhals is offline   Reply With Quote
Old 10-18-2019, 01:54 PM   #1428
gasgaskid
Member#: 455827
So just wondering, anyone out there who added the Perrin pitchstop brace ever have the older 2015-2016 brace crack after the install? I have a 2016 WRX and just wondering if i should install the brace. Canadian model so i don't think the U.S. recall will protect me.
gasgaskid is offline   Reply With Quote
Old 10-18-2019, 03:36 PM   #1429
killadawg
Member#: 424203
2016 WRX STage ??
STI/PPG/ GM
I was pushing near 500whp no issues on that brace.. yet I did have all other mounts changed to hard / solid, and thus I probably dont get as much movement as if you just have a solid pitch stop along with that brace.. (tubular trans solid hook up, hard poly motor mounts, fluidampr pulley, etc..) I would not recommend running any brace if your firewall is cracked.. get it fixed, then run the brace. If the brace has broken, I would reach out to Perrin ( they have great customer service ) good luck
killadawg is offline   Reply With Quote
Old 10-18-2019, 06:22 PM   #1430
ShowCase
Member#: 392669
2015 WRX Limited 6MT
Galaxy Blue Pearl
15 WRX with 101k miles. Mines still good, installed the Perrin brace really early on... maybe around 20k miles, don***8217;t remember too well, I think I wrote it down in a log somewhere.
ShowCase is offline   Reply With Quote
Old 12-10-2019, 05:35 PM   #1431
gurusan
Member#: 258165
2015 WRX
So I recently bought a 2015 WRX, according to carfax there are no open recalls...is there any way to verify this was done? Looking back at the service history there's nothing about a TSB being performed.
gurusan is offline   Reply With Quote
Old 12-10-2019, 05:41 PM   #1432
alapilusa
Member#: 424692
2015 WRX
A TSB is not a recall. It is if you are having a problem, it will be fixed with an updated part to prevent further issues.
I believe there have only been 2 recalls on the 2015 WRX. One is related to an ECU reprogram to an updated version and the second is related to replacing the plastic turbo inlet due to cracking. These are both set to certain production dates. I happened to be lucky and my car fell in the middle of the 2 and had no recalls at all associated with it.
alapilusa is offline   Reply With Quote
Old 12-10-2019, 06:43 PM   #1433
gurusan
Member#: 258165
2015 WRX
Thanks for the clarification. Guess I'll take off the TMIC soon and take a looksee at the area.
Old 11-19-2020, 10:14 PM   #1434
Silverdragon_503
Member#: 520389
Default I just replaced mine.
So it is a very expensive task if your car is over 60k I believe it was. That is the cut off for the warranty recall through Subaru.
if you are over the cut off the cheapest option is the route I went. purchase the new bracket, then remove the engine and transmission yourself, super easy if you have all the right equipment, have the car towed to the body shop of your choice, and have them weld on the new one. they are going to try to tell you that it should be pinch welded and that you should remove the dash and everything else. my body shop just drilled the appropriate holed and filled the holes by means of I believe it was Mig welding. I purchased all new mounts, engine, and transmission, also I ordered the pitch stop brace. The problem is fixed and actually runs much smoother with all of the new mounts. for those wondering, I went with Perrin performance for all mounts.
Silverdragon_503 is offline   Reply With Quote
Old 11-20-2020, 08:13 AM   #1435
vtwinjunkie
Member#: 415503
2016 WRX limited
black silica
Check the stock part really good before install to make sure it isnt already damaged...if so do it!
I have a 2016 that I bought new, and installed the mount back in early 2017 and its doing great.
vtwinjunkie is offline   Reply With Quote
Old 11-22-2020, 04:29 AM   #1436
Silverdragon_503
Member#: 520389
Just so everyone knows if it is damaged. You have to get it fixed before installing the brace. The brace is not designed to take on the full pitching force and will fail over time. If it is not damaged already then install the brace. The brace was designed only to brace the pitchstop bracket mounted to the fire wall and mitigate firewall flex.
Old 11-22-2020, 04:32 AM   #1437
Silverdragon_503
Member#: 520389
The recall was for certain cars made it is by vin not by where the car was sold if you are under the milage. I believe it was 80k then they should honor it. if not call subaru corporate.
Old 11-22-2020, 11:49 PM   #1438
BillyMagnum
Member#: 219892
AP1 S2K Life Now
17' PRD WRX CVT (Sold)
I always update this thread and figured I'd add it here for reference just in case anyone would need it. This is for CVT WRX owners.
https://forums.nasioc.com/forums/sho....php?t=2831539
BillyMagnum is offline   Reply With Quote
