Welcome to the North American Subaru Impreza Owners Club Sunday May 20, 2018
Old 05-31-2017, 05:42 PM   #776
Rafaelsoares123
Member#: 459508
2012 Wrx
Originally Posted by Rafaelsoares123 View Post
i hope someone can help me.... been researching for a while now and got nothing
bought the car used which was supposed to have a starter, but dealers removed it because "it wouldnt be covered in warranty due to being aftermarket"
at first i ofcourse assumed it was the batteries, nope.
I tried bringing it to subaru to see if having the fobs could be programmed would fix it, their computers wouldnt accept the code.
I got two fobs, and im certain they belong to this car
I believe something may have been unplugged/ snipped in the process of removing the starter, does anyone have knowledge of the wiring set up?
I tried doing the manual programming everything communicated correctly but the fobs never worked, horns go off when i unlocked using the key, when i lock the car with driverside lock button i hear the lock chirp. everything seems to be working but i cant seem to figure out whats unplugged. I did notice a couple cables disconnected, but they are different colors i dont think they belong together where is the keyless module located? i was thinking maybe someone accidently ripped it out, but wouldnt that mean the car wouldnt have any means of security?(locking, unlocking, horn going off upon incorrectly opening doors, lock chirp)
Thanks to anyone in advance that could help
feel free to text me if you think you got this figured out 401-297-8841
Rafaelsoares123 is offline   Reply With Quote
Old 08-01-2017, 09:05 AM   #777
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
For a 2001 RS USDM and factory alarm, the little red light/pushbutton on the dash, if it's broken (red lens falls out) is that an issue for the system?
I'm guessing it makes it a PITA programming remotes, going into valet mode, etc.
Should the system still work though?
It's a customer car, remote quit working but I think it is due to them getting a new car battery and losing programming. I can't get into programming mode though.
BTW, what fuses feed the remote and alarm? My documents don't show them.
Old 09-05-2017, 11:34 PM   #778
dkempner
Member#: 462832
I have a 2016 WRX with keyless entry but no push to start. I bought replacement keys from Amazon. Are these able to be programmed without visiting the dealer? Will a car locksmith be able to program them more cheaply?
dkempner is offline   Reply With Quote
Old 09-29-2017, 11:27 AM   #779
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
OK, for the older factory alarm, made by Code Alarm, all black rectangular remote used on...
Impreza, 96-01 (I think dependent on build date, may be an Alpine if late)
Legacy, 95-99
Forester, 98-00
The FCC code is, GOH-M24.
Uses a small 12volt battery, about 1/2 the length of a AAA.
Programming remotes can be found here....about 2/3's of the way down...http://www.cars101.com/subaru/keyles...gram%20remotes
The remote receiver for this system is under the drivers side of the dash, just above the interior fusebox. If you pull the coin holder out (covering the interior fuse box) you can "sorta see" the receiver. Yes, it's a PITA to get to, but unlike later models (receiver seems to be under the center console) it's not too bad.
I searched this thread, looks like few have questions on this series programming.
PS, trying out the linked FOB programming on a 01 Impreza RS, the method in the first post didn't work, thus my comment on build date.
I will update this post if the linked method works on the 01 RS.
Follow up, the method I linked in this post worked on the 01 RS. Yay!
Old 09-29-2017, 02:34 PM   #780
Namyjay
Member#: 475328
Default Help
So, i have a 2008 Impreza. Up until about 3 weeks ago, the factory remotes worked fine. Then they intermittently stopped working to lock and unock the doors, etc. and so i thought maybe its the battery. changed the battery and it was not it.
Now, I had wanted remote start anyway, so i thought upgrading to that would override whatever issues i was having with the remotes and kill two birds.
I get the remote installed and its working fine at the place. Get home, and same issues as before with the new remote.
Its not all the time. It seems to work after I drive the car. But after its been sitting for a while, like in my driveway over night, it wont open in the morning.
So i paid all this money for remote start hoping that it was fix the beginning issue but now neither are right.
Ideas of what it is please???? though it seems random, I cant help but notice it happens only at my house....
So weird.
Namyjay is offline   Reply With Quote
Old 11-22-2017, 09:54 AM   #781
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
So weird.
Maybe a ground is poor or your main car battery is getting weak. If you can, leave the car on a trickle charger overnight and try the remote in the morning.
Old 12-26-2017, 06:01 PM   #782
Jiiks
Member#: 478387
2002 Impreza STI
Anyone have any idea how to wire an aftermarket keyless entry to an alphacorp system? I tried the red/white yellow/red wires but they don't seem to work at all.
It's the following unit:
I can post images of it if needed.
Jiiks is offline   Reply With Quote
Old 12-27-2017, 08:18 AM   #783
Jiiks
Member#: 478387
2002 Impreza STI
Okay I figured it out. Here's a diagram incase anyone ever has the same system and needs to wire it: (sorry for the terrible pictures my scanner didn't want to cooperate so I had to use my phone)
Manufacturer: Alpha Corp
Model No. CV98N
Part #: 88035FE031
Unlock pin also goes to pin 4 in the connector.(white wire in my case)
Old 02-23-2018, 09:30 AM   #784
dreamer9142
Member#: 482497
Unhappy Will this work for me? HELP!!!!!
So, I bought a 2007 Impreza 2.5i hatchback yesterday and was able to unlock it and start it at the dealership for the test drive using the key, the key fob was left inside the dealership. Later at home after I had locked the car with the lock button on the door, I went back out to my car and used the key to unlock the car, the key fob was left in the house. My alarm went off, I don't know what finally made the alarm stop, but it did. I was always outside of the car when I tried to open it. The security light didn't seem to ever stop blinking, even when the alarm was off. Would reprogramming the key fob fix my issue and allow me to get in my car to start it? I assume I am going to have to open the door, set the alarm off and sit in the car and wait for the alarm to go off before I can reprogram the fob. I see on the forum that turning the key on three times will shut the alarm off, really? I don't know if this post makes any sense, I am worried I just messed up by buying this car. It is supposed to be replacing my 96 outback with 290,000 miles on it. Feel free to text or call with advice please... 216-804-1050
dreamer9142 is offline   Reply With Quote
Old 02-26-2018, 12:52 PM   #785
seb28
Member#: 291749
2007 Impreza WRX
WHITE
Yeah turnig the key on three time will stop the alarm. If you lock the door with the remote or the inside button, the alarm will automatically get armed. You then must unlock the door with the remote if you don’t want the alarm to go off. Not sure but I think that if you lock the door with the key the alarm won’t arm.
seb28 is offline   Reply With Quote
Old 03-20-2018, 01:04 PM   #786
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
THe system has to be put in valet mode in order to open the door with just the key (not the remote)
See page one for instuctions
RexyGirl is offline   Reply With Quote
Old 03-28-2018, 03:32 AM   #787
PDXREALTOR
Member#: 468393
2017 STI
2017 STI limited (push button start). The damn car is stuck in alarm 'arm' mode.
My door locks quit working, I swapped the fuse, and ever since then the immobilizer light flashes and anytime I open the door the alarm goes off.
I've tried everything in the manual with no success.
It's as if the antennas aren't picking up my fob - neither remotely or via any button presses.
The push start button is completely dead - no accessory functions just illumination with or without headlights.
PDXREALTOR is offline   Reply With Quote
Old 04-16-2018, 05:08 PM   #788
RexyGirl
Member#: 63616
with mods :)
If you are under 36,000 miles, or have an extended warranty, take it to the dealer. It should be covered.
Check the battery in your remote as well. It might be that simple
Old 05-16-2018, 12:26 PM   #789
Slim_Jim
Member#: 473831
2018 WRX STI Limited
Lapis Blue Pearl
Try holding the fob up to the push to start button and see if it does anything. The fob is supposed to have an RFID chip in it that the car will pick up in the event that the fob's battery completely dies. You should be able to start the car while holding the fob right next to the start button while you push it.
Slim_Jim is offline   Reply With Quote
Factory Alarm + Keyless entry from 04 FXT Skidd Interior/Dressup/Audio & Security 0 01-22-2009 08:26 PM
Factory alarm/keyless entry install - Anyone want to help?! NickWRX Tri-State Area Forum 3 07-06-2008 09:22 PM
All you need to know about ass hair. WRick Off-Topic 22 01-23-2006 07:22 PM
Factory Alarm / Keyless entry Woody Vancouver Impreza Club Forum -- VIC 3 04-21-2002 11:51 PM
Factory alarm/keyless entry on MY01 Safir Car Audio, Video & Security 1 02-08-2001 01:01 PM
