Welcome to the North American Subaru Impreza Owners Club Sunday December 9, 2018
Old 02-10-2014, 11:52 AM   #2751
truetotexas
Member#: 228295
2013 WRX
Satin White Pearl
Originally Posted by georhey View Post
Yeah, i went with a 255/40 on an 18x9.5 +38. I didn't rub much when it was just me in the car but with one other passenger i would get rubbing every now and then. I went with a slight roll and i've been good. I did a search on here and found this thread. May be of help to you.
http://forums.nasioc.com/forums/show...ll+san+antonio
Yeah I came across that guy as well. A couple of friends of mine had some issues, not to bad mouth him or anything. So I was trying to avoid rubbing all together if possible, heh.
The wheels i'm looking at (reserved a set actually) are the nt03 in SBC. What did you end up going with on your car?
truetotexas is offline   Reply With Quote
Old 02-10-2014, 11:54 AM   #2752
georhey
Member#: 349264
2013 WRX Hatch
Satin White Pearl
I went with Matte Bronze RPF 1's. I posted a pic on page 109 of this thread.
georhey is offline   Reply With Quote
Old 02-10-2014, 12:00 PM   #2753
truetotexas
Member#: 228295
2013 WRX
Satin White Pearl
ah word. the flicker link looks like it was having issues. Good choice mang!
Old 02-10-2014, 12:04 PM   #2754
Digitalwave
Member#: 321857
You can rent/buy a fender roller too, they are only $180 from Eastwood.
It's not hard to roll GR rear fenders. I've rolled 3 sets now (completely flat roll) and haven't had a single chip in the paint.
Digitalwave is offline   Reply With Quote
Old 02-10-2014, 12:31 PM   #2755
georhey
Member#: 349264
2013 WRX Hatch
Satin White Pearl
Oops. Fixed the link.. Thanks for the heads up.
Old 02-10-2014, 12:36 PM   #2756
truetotexas
Member#: 228295
2013 WRX
Satin White Pearl
In your experience, would a light roll be considered something like a 45 degree roll? I wouldnt think that a flat roll/pull would be needed right?
Old 02-10-2014, 12:38 PM   #2757
SWP_671
Member#: 309347
2011 Subaru WRX
Satin White Pearl
I wouldn't think either will fit without a LOT of camber and/or a significant pull of all the fenders.
As long as it will fit. I already have the wheels. Im kinda leaning towards 275/35 though. Just wanted to know how much camber or fender work i needed to do
SWP_671 is offline   Reply With Quote
Old 02-10-2014, 12:49 PM   #2758
revolving
Member#: 368922
I've been struggling on the tire size as well. I'm planning on going with 18x9.5 et45 on my '12 WRX along with RCE blacks. Been going back and forth on 245/40's vs 255/35 but think i'm finally settled on the 255/35 Continental DW's. Hope the +45 won't require too much rolling.
revolving is offline   Reply With Quote
Old 02-10-2014, 01:25 PM   #2759
zr0z
Member#: 325764
2017 FXT
Other than the obvious bolt pattern, does anyone know if the STI 5x114 hub sits any differently on the car than the WRX's 5x100 hub? I'm seeing a lot of STI guys get a LOT wider wheels/lower offsets. Wasn't sure if it was just because or if the wheels fit differently. Just a question a quick search/google couldn't answer.
zr0z is offline   Reply With Quote
Old 02-10-2014, 01:51 PM   #2760
Digitalwave
Member#: 321857
Yeah, maybe not even 45*. One car I helped with only took 2 quick passes with the roller, it probably only moved 20* from where it was. He was running a 255/40-17 Hankook V12 on a 17x9" ET38 wheel.
Pulling the front and rear fenders, and stiff suspension will help. Having a high ride height helps too. Otherwise you'll probably need 4-6* of camber if you want to be reasonably low.
255/35 would be the proper sized tire.
I think it has to do with the wheels and fitments that are available in the market in 5x114.3 as well.
Old 02-10-2014, 01:54 PM   #2761
Ruzty1311
Member#: 311911
2012 WRX Limited Sdn
SWP (TP Stg 2)
It shouldn't need much since the wheel will be further away from the fender as opposed to a +38 offset that some of us have would be...not by much but it might aid in not needing a more aggressive roll with that higher offset
Ruzty1311 is offline   Reply With Quote
Old 02-10-2014, 03:52 PM   #2762
sc00by4life
Member#: 97135
no. in terms of where wheels sit, its exactly the same.
the guys you see running large wheels and super low offsets are the more experienced fitment guys. you see them with both wrx and sti's.
Old 02-10-2014, 10:56 PM   #2763
yacksblend
Member#: 349658
2013 WRX
Would there be strut clearance issues with an 18x9.5 +48? Also supposing the car was lowered about 1'' on springs? 255/35 tires
yacksblend is offline   Reply With Quote
Old 02-11-2014, 06:40 PM   #2764
jdick0101
Member#: 357103
'11 sedan. stock suspension
18X8.5 +45. 245/40 tire
will fit fine correct?
jdick0101 is offline   Reply With Quote
Old 02-11-2014, 07:12 PM   #2765
Ruzty1311
Member#: 311911
SWP (TP Stg 2)
Yes!!! ^^
Old 02-12-2014, 03:00 AM   #2766
Shanghai_Subaru
Member#: 379859
I'm having a hard time finding any pictures of a wrx with the BBS SR wheels. Any help?
Shanghai_Subaru is offline   Reply With Quote
Old 02-12-2014, 08:11 AM   #2767
SWP_671
Member#: 309347
2011 Subaru WRX
Satin White Pearl
How much difference is 18x9.5 + 38 to 18x10 + 38 if both of them has 275/35 sized tires (same brand)?
Im thinking that your tires are the first one to touch the fenders if ever, so clearance issues (fender roll and camber) would be the same?
Old 02-12-2014, 10:22 AM   #2768
Digitalwave
Member#: 321857
You'd have 1/4" more rim poke, but with the same size tire, the fender clearance might be a little less than 1/4" difference.
It doesn't sound like much, but unless you plan to keep the ride height high, that is a very tough fitment.
Old 02-12-2014, 11:33 AM   #2769
Mdsiman
Member#: 360019
2013 Wrx
Would I need a mild or flat roll in the rear with 18x9.5 38 rpf1 with conti dw 255/35? Either being dropped on rce blacks or kw v1
Mdsiman is offline   Reply With Quote
Old 02-12-2014, 02:15 PM   #2770
Digitalwave
Member#: 321857
Probably a moderate roll, maybe not all the way flat (but you might as well go all the way if you are doing it).
Old 02-12-2014, 03:59 PM   #2771
Mdsiman
Member#: 360019
2013 Wrx
yea im going to go all the way.
I just got done ordeering my 18x9.5 38 rpf1 sbc!!! should have them in a few days!
Old 02-12-2014, 05:34 PM   #2772
colin1234567
Member#: 212639
WRX= 13/SWP/SOLD
'10 NC2 Miata
No such thing as moderate roll, if you're going to roll you should be rolling flat, no sense in stretching that paint twice if you need the extra couple MM in the future.
colin1234567 is offline   Reply With Quote
Old 02-12-2014, 10:35 PM   #2773
HuckFinn
Member#: 298502
2011 WRX sedan
I've got the same question. I'm looking at WedsSport SA-15R wheels in 18x9.5 for my WRX but they come in a +48 offset in 5x100 spacing at that size. I've found folks who have successfully fit 18x9.5 +45 wheels on a GR STI/WRX, running 265/35 tires with no strut clearance issues, but I haven't found anyone running a higher offset. Worst case, I suppose 3mm spacers should fix any problems, but I'd love to know if anyone has managed to get a wheel/tire setup in that size to fit without spacers.
HuckFinn is offline   Reply With Quote
Old 02-13-2014, 10:26 AM   #2774
Digitalwave
Member#: 321857
I believe it's going to depend on what strut/coils you are running, and how much camber is dialed in.
Old 02-13-2014, 12:54 PM   #2775
HuckFinn
Member#: 298502
2011 WRX sedan
I've got RCE Bilstein struts with yellow springs and front camber is at about 1.7 degrees. Rear camber is at about 1.3 degrees. That setup doesn't drop the car much and actually should give me slightly more clearance then coilovers. That should be a nice setup if it does clear the front struts, since I might not even need any fender work with that high of an offset. Pretty close to pulling the trigger.
Needed: Stock Impreza/WRX/Legacy wheels and tires to fit '01 Legacy L acetmi Private 'Wanted' Classifieds 0 06-14-2006 01:43 PM
need somewhere to get wheels and tires asap bubba03wrx Southern California Impreza Club Forum -- SCIC 22 04-02-2004 10:14 PM
Wider wheels and tires in the rear SilveRexy03 Tire & Wheel 14 11-04-2003 05:49 PM
WEre is a good place to buy wheels and tires MilfordSubaru Mid West Subaru Owners Club Forum -- MWSOC 4 05-25-2002 02:14 PM
Where to buy wheels and tires? wilddave1 Brakes, Steering & Suspension 4 03-21-2002 03:20 PM
