Welcome to the North American Subaru Impreza Owners Club Wednesday October 17, 2018
Old 10-03-2017, 11:52 AM   #1
Mach V Dan
Member#: 12029
Default Mach V Dan's 2015 WRX audio install - Pioneer AppRadio 4
I thought I had made a thread about this previously, but I guess I never did. So here it is a couple of years late.
I found the stock head unit in my 2015 WRX (non-nav) to be adequate but very basic. The sound quality of the whole system was pretty terrible, with no bass and muddy clarity. Even at higher volume levels it was hard to hear over the noise of the car. Plus the hands-free phone functions were terrible.
I decided I didn't want head unit-based navigation. Phone-based nav is constantly updating and advancing, and I have been frustrated before by nav systems in head units that quickly went out of date. I also thought I could live without a CD player. I mostly listen to an iPod Classic, or to streaming music from the phone. That led me to Pioneer's AppRadio 4 (SPH-DA120), which is basically a double-DIN screen that is meant to be a radio and a front-end for your phone, and that's it. There's no optical disc slot at all.
I had my local car audio place, Kartunes, do the install. They sold me the head unit and speakers. I supplied a couple of JL Audio amps that I had leftover from another project, plus the sub enclosure. (More on that below.)
In talking with the Kartunes guys, I set out goals of high sound quality, decent bass, complete OEM control integration (I wanted the steering wheel controls to work intuitively, and for the center console aux and USB ports to work properly), and enough sound level so I could hear my music clearly at freeway speeds. (Or damage my hearing, whichever way you want to look at it.) I also wanted to retain the spare tire.
We talked about a custom trunk-mounted subwoofer, but the cost of building a custom box was a lot. I found an unused OEM Subaru Kicker accessory sub on ebay for cheap, bought it, and pulled the Kicker driver out of it. A JL Audio driver went in there instead. The Subaru box is kind of cheap -- it's basically just a clamshell of thermoformed plastic. The Kartunes installers papered the inside with dense foam to try to make it less ring-y.
Sub in place
The sub stays in the car using a sort of rinky-dink fastener that Subaru supplies -- you can see that above, in the upper left of the photo. It works, but it's not my favorite part of it.
For speakers I used Focal separates (PS 165 FX) in front, and coax drivers (165 AC) in the rear doors. I supplied some speakers spacers but Kartunes didn't like 'em and made their own.
Front door speakers in place
Tweeters with custom adapters
Rear speakers in place
The two amps are on a small rack that sits under the rear trunk floor in the tire well. It has a little bracket under it that hooks into the spare tire retainer; that plus friction keeps it in place nicely.
The head unit mounted very neatly. I'm a tiny bit sad that the head unit is smaller than the actual hole in the dash, meaning I missed out on a little bit of potential screen real estate. At the time, the Kenwood DDX916WS (which is as wide as that Subaru/Toyota stereo mounting hole) hadn't come out yet. The Pioneer screen is plenty bright and easy to use, though.
Head unit in Apple CarPlay mode
Spotify
Nav using Apple Maps
After a couple of days at the install place, it was all done and it works great. The stock steering wheel controls all work -- that means I can switch between radio/aux/CarPlay using the mode button, control volume, and switch stations or tracks, all from the steering wheel. The aux port and USB port under the armrest work. There's a hands-free mic up in the headliner that's far better than the OEM one.
The CarPlay features are about 90% satisfying. It's a little frustrating that you cannot enter any text data through the head unit. That is, if you want to enter a new nav destination or choose a new artist on Spotify or anything like that, that's a no go. You have to do that on the phone itself (while you are not driving, obviously), then plug in to implement the new destination or channel.
Another issue with CarPlay (and Android Auto too) at this time is that the phone has to be physically wired up to the head unit. For whatever reason, you can't run it wirelessly, at least not yet. It's not like it's a huge hassle to plug in the phone, but it's just one more thing to keep track of.
There are sometimes glitches with the head unit. Used with my trusty iPod Classic (in direct connect mode, where the head unit is controlling the iPod through the USB port), the iPod will crash about once every few hours of use. Used with a USB thumb drive full of music, the head unit has occasionally crashed and rebooted itself. Oh, and one more thing about using a thumb drive -- the head unit has to index all the music on the drive every time you power it up. If it's a big drive (128GB) that can take 5-10 minutes.
Another user interface thing that bugs me is there's no rotary volume knob. I realize this is a challenge with flat-screen head units, and some of the units that DO have a rotary knob have a little teeny one that's difficult to use anyway.
One final annoyance is that if you want to run your iOS nav through CarPlay, you are stuck using Apple Maps. Which is, in my opinion, much inferior to Google Maps. Oh well -- it still gets me where I need to go, and it's still being updated and improved all the time.
Those are small gripes. The overall implementation of CarPlay is great and really brings both the functions and the user experience of the iOS to the car.
Overall, this setup fills most of my requirements for getting music/phone/podcast/map data in my car. It sounds great and the install is almost totally stealth.
Thanks for reading.
--Dan
Mach V
FastWRX.com
Mach V Dan is offline   Reply With Quote
Old 10-03-2017, 12:41 PM   #2
Midnite8
Member#: 430858
2016 WRX Premium
World Rally Blue
Nice post, but I didn't notice any sound deadening...?
Midnite8 is offline   Reply With Quote
Old 10-03-2017, 02:04 PM   #3
Mach V Dan
Member#: 12029
OMGthecarisgoingtoexplode!
Do you have a question?
--Dan
Mach V
FastWRX.com
Old 10-03-2017, 02:56 PM   #4
gaugeof12
Member#: 132859
2015 WRX
CWP
Does the stock back up cam still work? If it does do you have really bad fisheye? Looks like a great upgrade. I would like to do something similar if i could keep everything working.
gaugeof12 is offline   Reply With Quote
Old 10-03-2017, 03:02 PM   #5
Mach V Dan
Member#: 12029
The stock backup camera still works, displaying on the stock multi-function display as it always did. I guess I could have plumbed the camera into the new head unit, but I didn't think of it.
Uh...no more fisheye than it ever did?
--Dan
Mach V
FastWRX.com
Old 10-03-2017, 04:07 PM   #6
Midnite8
Member#: 430858
2016 WRX Premium
World Rally Blue
--Dan
Mach V
FastWRX.com
Haha! Did you just decide not to do any deadening?
Old 10-03-2017, 04:46 PM   #7
Mach V Dan
Member#: 12029
Yes. The labor is a lot, and the benefit not worth it me on this particular car. Plus, I wanted to keep the weight down. That was another reason for that plastic sub enclosure, instead of the custom MDF or fiberglas/plywood boxes I've done in previous cars.
--Dan
Mach V
FastWRX.com
Old 10-03-2017, 08:34 PM   #8
BHOD
Member#: 463264
2018 WRX sport, 6MT
crystal BLACK silica
Thanks for sharing and you chosen nice gear.
And nothing to guide the sound inside the car as well.
Front speakers drilled directly in the door, glued with silicon and apparently tap on factory speakers wires... (when it's really easy to run new wire)
Rien pour écrire à sa mère
BHOD is online now   Reply With Quote
Old 10-04-2017, 07:46 AM   #9
tmcquinn
Member#: 310769
2018 WRX, 2002 WRX,
2003 WRX, 2012 Impreza
Very cool. The day is gonna come when the stock unit in my car is getting replaced.
For me, head unit NAV is dead. Not only does Google Maps tend to be up to date, the traffic function can save you many hours by diverting you around traffic jams. I want a setup like yours where it can display on that big screen.
tmcquinn is offline   Reply With Quote
Old 10-04-2017, 10:35 AM   #10
BHOD
Member#: 463264
2018 WRX sport, 6MT
Pioneer, Sony and Kenwood offer great HU.
If you don't want DVD/CD reader, Sony has a very good model as well.
Old 10-04-2017, 11:04 AM   #11
Mach V Dan
Member#: 12029
Thanks.
Uh, what?
The wire is all new. The speaker spacers are sealed to the door with silicone; they are fastened with screws. The front speakers also required spacers, so they are not "drilled directly in the door." How do you prefer to attach speakers to doors?
"Nothing to write Mom about"? Sorry it does not meet your Bureau of French-Speaking Car Stereo Snobs standards. My goal in posting this was to share what I did, and maybe help some other people in making decisions on similar installs. (Here's another thread with questions about just this kind of thing.) I don't by any means represent this system as the best-sounding system in the universe. It was a straightforward install that meets my personal needs.
--Dan
Mach V
FastWRX.com
Old 10-04-2017, 12:29 PM   #12
gaugeof12
Member#: 132859
2015 WRX
CWP
--Dan
Mach V
FastWRX.com
Thanks Dan. I though that some of the "processing" to remove the fisheye for the camera was done by the head unit. MAYBE that's ONLY an issue if you are rerouting it to go through the head unit display.
Old 11-17-2017, 01:52 PM   #13
Mach V Dan
Member#: 12029
Huh. I don't know. I didn't even look into running the backup camera into the Pioneer head unit.
--Dan
Mach V
FastWRX.com
Old 11-20-2017, 05:18 PM   #14
Drew18WRX
Member#: 476291
2018 WRX
Entry level sound system.
Should they have been riveted?
What is wrong with OEM wiring? It is copper. How much power is run through the wire? Unless you are running significantly higher power you are wasting money, time and energy. Even then... still not really necessary. The signal loss is going to be nearly non-existant.
Seems like a lot of trash talking for no reason in this thread.
The only issue I noted was you said it took the shop a few days to do this. Sounds excessive to me. Deck+SWC/4spk/2 amps/sub+wiring. Would likely have taken less than a day when I was working in a shop.
That being said glad your happy can't wait to get my WRX, I have a bunch of parts awaiting install once I receive it.
Drew18WRX is offline   Reply With Quote
Old 11-30-2017, 11:45 AM   #15
Mach V Dan
Member#: 12029
In this case I am running significantly more power. We've gone from whatever the OEM head unit has -- 20 watts? -- to around 475 watts RMS. (The JL amps are 75x4 and 175x1 at 4 ohms.) So I think the larger gauge wire is justified.
I can't argue with that, but I wasn't really in a hurry, so the time to get it done didn't bother me.
--Dan
Mach V
FastWRX.com
Old 12-01-2017, 11:31 AM   #16
eyekode
Member#: 477587
Thanks for posting!
Great looking install. I really wish there was a solution that included google maps for ios.
eyekode is offline   Reply With Quote
Old 12-01-2017, 05:13 PM   #17
Six WRX
Member#: 477886
2017 Base WRX
Very nice install; curious, did you consider installing the amps under the front seats?
Six WRX is offline   Reply With Quote
Old 12-01-2017, 09:03 PM   #18
Mach V Dan
Member#: 12029
Yes. After measuring, I think we decided the largest one would not fit.
--Dan
Mach V
FastWRX.com
Old 12-01-2017, 11:38 PM   #19
fuelMuncher
Member#: 301554
2002 WRX Wagon
PSM, 2007 OBP WRX Limited
Thanks.
Uh, what?
--Dan
Mach V
FastWRX.com
Oh, hells yea
fuelMuncher is offline   Reply With Quote
Old 12-02-2017, 03:13 PM   #20
SpicyPeaNut
Member#: 43310
1978 Brat
Looks good Dan. I've followed your posts over the years but still haven't bought anything directly from you. I can never decide on a wheel setup so I've stayed stock all these years lol.
This inspires me to take apart my factory kicker sub box and line it with dynamat type material. I already spent 1000's on new speakers, wiring, multiple head units, cleansweep and just have never been happy with the audio from my 13 sti. Maybe lining the kicker box will give my bass a little more of a clean sound.
SpicyPeaNut is offline   Reply With Quote
