Welcome to the North American Subaru Impreza Owners Club Sunday May 20, 2018
Old 07-23-2010, 01:00 PM   #26
kero
Member#: 94299
2000 2.5 RS Sedan
SRP
^^ Wow, you aren't running an 02's, my local tuner told me it's critical to have at least one of the 02's working, I can't remember for what but he said it was important. I wish I could remember if it was front or the rear but when I asked him to remove the 02 codes, he wouldn't do it as he told me it has to do with fueling or something along those lines.
kero is offline   Reply With Quote
Old 07-23-2010, 01:02 PM   #27
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Yeah, the way flightwatch is doing it is NOT a good idea. The ECU is unhappy and using its failsafe tables. He's also going to have less control over AFR and will require retunes every time his gas station changes blends (which happens twice a year, minimum). No O2 sensors is not a good idea for a street-driven car.
Old 07-24-2010, 11:03 AM   #28
kero
Member#: 94299
2000 2.5 RS Sedan
SRP
^^ Thank you for confirming, I am happy my local tuner knows his stuff.
Old 07-24-2010, 11:34 AM   #29
white guys wrx
Member#: 223316
2005 STi
& 02 WRX
keep ur stock header an buy an aftermarket uppipe.....
white guys wrx is offline   Reply With Quote
Old 07-24-2010, 11:50 AM   #30
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
Keep in mind not everyone gets the CEL. I had my UELs in -30 winters, and not a single check engine light...
Old 07-24-2010, 12:08 PM   #31
thesniperz
Member#: 235744
2000 Forester STi
White - JDM yo!
^ yeah, that's what i'm trying to find out..
what's your setup?
thesniperz is offline   Reply With Quote
Old 07-24-2010, 10:49 PM   #32
kero
Member#: 94299
2000 2.5 RS Sedan
SRP
The 2.5i' seem to be more sensitive to the UEL's and please understand the ECU's are not the same on 05 and earlier and the 06/07s. You can not use certain fixes on 06/07's that you can on prior years. Like spacers, of the resistor fix, etc etc.
Old 07-24-2010, 10:52 PM   #33
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
You got the year split wrong.
The picky cars are 05 and newer, the easy to please cars are 04 and older (they get easier as they get older).
Old 07-24-2010, 10:53 PM   #34
Bluefoton
Member#: 141373
2008 2.5i-hatch -
what's your setup?
Borla knock-off UEL's, stock cat, STi catback.
Old 07-24-2010, 11:00 PM   #35
R-raid
Member#: 211124
2000 Impreza RS
Sedona Red Pearl
I have an have rs 2000 w/ unequal length headers and the CEL turn on
whole exhaust is redone. borla replicas as the headers
R-raid is offline   Reply With Quote
Old 07-24-2010, 11:03 PM   #36
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Originally Posted by R-raid View Post
u have rs 2000 w/ unequal headers and cel pops
whole exhaust is redone. borla replicas magnflow and custom exhaust bent pipes
I have no idea what the hell you tried to say.
Old 07-24-2010, 11:12 PM   #37
R-raid
Member#: 211124
2000 Impreza RS
Sedona Red Pearl
hahaha yeah....
i edited it
Old 07-25-2010, 02:35 PM   #38
kero
Member#: 94299
2000 2.5 RS Sedan
SRP
My bad sorry LOL!
Old 07-26-2010, 12:06 PM   #39
GEE-OTTO
Member#: 201277
2008 08 QSM 5MT LGT
QSM
Originally Posted by flightwatch View Post
It is true that the only way to permanently clear the DTC is to eliminate it via reflash. That's how the track pipe boys do it. Welding a cat in a near stock location is next to impossible because the stock cat is actually integrated into the exhaust manifold. I have a high flow cat in mine, but I'm not running any o2 sensors. I had my tuner take out the codes, and I have not had any issues at all.
Gotta love 2006+ N/A manifold design engineers damn them
GEE-OTTO is offline   Reply With Quote
Old 07-27-2010, 01:44 PM   #40
WinterSubie
Member#: 243234
2009 Hatch
I'm still trying to figure out what to do if I get headers and a catback. Will any 08+ wrx downpipe work to connect them because I know some people use the stock downpipe from an 04-05.
WinterSubie is offline   Reply With Quote
Old 07-27-2010, 01:45 PM   #41
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
No, the 08+ downpipe will not work for you. No, no one used an unmodified older downpipe either.
Some people have used, on older cars, the turbo manifolds, crossover pipe, and then a custom pipe that replaces the up-pipe and the vertical part of the down-pipe, before tying into a turbo cat back.
Possible Complete UEL Header Solution for P0420 CEL nti_hazard88 Normally Aspirated Powertrain 56 04-02-2018 01:56 PM
CEL error after installing Borla UEL headers? MerrosFox Normally Aspirated Powertrain 5 02-05-2010 03:25 PM
FS NY: Heat coated Fujitsubo EL header, Gruppe-S UEL header, STi uppipe garface Engine/Power/Exhaust 27 05-07-2009 11:00 AM
el headers for uel headers gostdog Private 'Wanted' Classifieds 8 12-02-2008 10:46 AM
NJ: GC jet-hot coated borla UEL headers and stock headers M E R C U R Y Tri-State Area Private Classifieds 1 05-12-2008 01:58 PM
