07-15-2014, 02:51 PM | #4626 | |
Member#: 301037
Vehicle:2004 Forester XT Aspen White |
-Art
07-15-2014, 03:37 PM | #4627 | |
Member#: 71721
NESIC
Vehicle:98 RSTi, 00 RS 13 Sierra |
Here's the mod list to date Engine/Transmission '03 WRX 2.0L Engine - Rebuilt/refreshed personally with all new OE components Wire Harness merge done personally TGVs deleted along with other non-essential, never to be reinstalled electronics Gates Racing Timing Belt Gates Racing Alternator/Power Steering Belt Cosworth Billet Timing Belt Guide STI 11mm Oil Pump STI Engine Mounting Plates Cusco Engine Mounts Cusco Transmission Mount BC Adjustable Timing Gears Black Perrin 2.4" Turbo Inlet JDM V9 VF37 Twinscroll Turbo JDM V9 OEM Twinscroll Headers JDM V9 OEM Twinscroll Up Pipe JDM V9 OEM Twinscroll Down Pipe JDM V9 OEM Twinscroll Oil Pan JDM V9 OEM Twinscroll Oil Baffle JDM V9 OEM Twinscrool Oil Pickup JDM GC8 Blitz Ř80mm Nur-Spec RX Catback ARC Titanium Pulley Cover ARC Polished Super Induction Box Zero Sports 76mm Air Intake Pipe Greddy Magnetic Drain Plug ACT HD Clutch ACT HD Pressure Plate Kartboy Short Throw Shifter Kartboy Front Shifter Bushings Kartboy Rear Shifter Bushing Forced Performance non-AVCS Oil Supply line OEM Thermostat DeatschWerks/Bosch EV14 1000cc Topfeed injectors DeatschWerks DW200 Fuel pump & install kit Beatrush Lightweight Alternator Pulley GR STi Passenger Side Hard Coolant Line JDM Spec-C STi TGV Top-feed Deletes EVAP Delete PTP Turbo Blankets Turbo Blanket Lava Denso Iridium Power Plugs One Step Colder GrimmSpeed Lightweight Crank Pulley (Black) GrimmSpeed Electronic Boost Control Solenoid GrimmSpeed Red Aluminum Oil Cap GrimmSpeed Intake Manifold to TGV Gaskets GrimmSpeed BOV Gasket GrimmSpeed Header Gaskets GrimmSpeed Throttle Body Gasket GrimmSpeed OEM Downpipe to 3in Cat Back Adapter GrimmSpeed Top Mount Intercooler GrimmSpeed TGV to Engine Gaskets - 2 sets GrimmSpeed Phenolic Thermal Spacer 3mm GrimmSpeed TMIC Y-Pipe Kit Black Couplers GrimmSpeed Intercooler Y-Pipe Gaskets Grimmspeed WRX Radiator Shroud modified for use on a RS with a GD Radiator Moroso Aluminum Coolant Expansion Tank DEI 12"x12" Reflect-a-Gold Sheet Passenger side heat protection Boxer4Racing Remote Oil Pressure sender kit A/C fully deleted Heater core and blower still in place (for defogging on track) OEM Air Conditioning Delete Bracket Old School GFB WRX 50/50 Hybrid BOV Koyo Racing aluminum radiator 36mm Hyper V core Koyo 1.3 bar Radiator Cap 2 Spal 10 Slim-line 802 cfm puller fans Samco Black radiator hoses Gates radiator hoses (backup) Brand-new Alternator Brand-new Power steering Pump Rotella T6 Synthetic 5W-40 Purolator Pureone Filter Autocraft ETX20L lightweight Battery Braille Lightweight Battery Mount Interior OEM GC Altimeter/Compass Pod & DIN Bracket custom 52mm Gauge setup White HVAC LED Conversion White LED Gauge Cluster Conversion White LED Window Switch Conversion LED Map Lights LED Dome Light Array Trunk Light Added & converted to LED Remote Unlock Added Passenger side Oh-**** Handle Added Beatrush Aluminum Rear Seat Delete Panel Brey Krause Fire Extinguisher Mount Amerex 2.5lb fire extinguisher Nardi Deep Corn 350mm Steering Wheel w/ Baller Bolts burnt Ti hardware Works Bell Short Hub Works Bell "Yoshioka" Quick Release RIPT Interiors Black Carpet 1/2 Gutted Interior - Per SCCA SM Class rules & due to cage Gutted Trunk Drivers side & Passenger side Airbag delete Sparco EVOII GrpTech Seats Sparco Bases Sparco Side Brackets Takata 4pt Harnesses Takata 6pt Harness Straps Schroth 3" 3 Bar slides (4x) Kales Custom, Custom 4pt Cage WC Lathewerks STi Brushed Titanium Shift Knob 52mm Stack Mechanical Oil Pressure gauge 52mm Stack Mechanical Boost Pressure gauge Exterior '99-01 RS Front Bumper '99-01 RS Clear Bumper turn signals '99-01 RS Crystal Headlights Prodrive P1 Fog Light Kit LED Plate Lights JDM "Clear" Tail Lights JDM Clear Parking Lights Grimmspeed Antenna Delete WRC style Carbon Fiber Aero Mirrors JDM STi V6 Grille JDM WRB I Badge Clear Front Bumper Turn Signals Clear Sidemarker Turn Signals Australian Head Light Protectors (Clear) Suspension/Handling/Braking JDM V4 WRX Subframe GC8 Aluminum Control Arms Group N Top Hats Kartboy Pitch Stop KYB AGX Struts (front only) Goodridge Stainless Steel Brakelines (Front) Stoptech ST40 Front 4piston Calipers (Black) Stoptech 2-piece Floating 328x28mm Slotted AeroRotor (Front) Stoptech Stainless Brake Lines (Rear) Axxis Ultimate Front Brake Pads Brembo LCF600 Brake Fluid 2004 STi Brembo Rear Calipers - Powder Coated Semi Gloss Black & 100% Rebuilt w/ Brand new OE components STi Master Cylinder DBA 4000 Rear Brembo Slotted Rotors for retrofit onto early Imprezas Rear Brembo Adapters StopTech Street Performance Brake Pad - 2004 Subaru Impreza WRX Sti - Rear 7 good 17x7.5 +48 STi Rays RS Zero's (Ultra friggin rare) - 1 w/ borked lug holes STi Rays RS-Zero Center Caps - Refinished 225/45/17 Dunlop Direzza StarSpec Z1's Eibach 5mm Wheel Spacers (Subaru hub specific) GrimmSpeed Master Cylinder Brace |
07-15-2014, 03:45 PM | #4628 |
Member#: 301037
Quite the build sheet, these are exactly the type of cars we want our products represented on. Thank you for the support, looking forward to more than a teaser pic!
-Art |
07-15-2014, 06:13 PM | #4629 |
Member#: 340284
We need more pictures from your car! Great list!
Sent from my iPhone using NASIOC |
07-15-2014, 08:40 PM | #4630 |
Member#: 2216
Vehicle:0000 Gee See dented |
07-16-2014, 05:39 AM | #4631 |
Member#: 346388
Vehicle:2001 Ej205 Impreza L SRP |
Now that's a list....more pics for sure.
I just got mine in and started up the other weekend....I also have some issues to work out so I can daily it again: |
07-16-2014, 10:56 AM | #4632 |
Member#: 333855
RMIC
Vehicle:1995 STI v2 Type RA white |
07-16-2014, 11:27 AM | #4633 |
Member#: 43196
TXIC
Vehicle:1999 STi Type R 93GF 95GC 02GD 01SF-T |
07-16-2014, 11:29 AM | #4634 | |
Member#: 43196
TXIC
http://www.rs25.com/forums/f178/t209...itch-rare.html |
07-16-2014, 04:46 PM | #4635 | |
Member#: 346388
I still messaged him about it though. |
07-16-2014, 05:08 PM | #4636 |
Member#: 182415
Vehicle:1999 RS Aspen White |
I think i have the older style intercooler sprayer kit with the big bottle and blue cap, definitely for non-abs cars, its a big bottle. Ill sell it as i changed my plans around with whats going in that spot.
07-16-2014, 05:34 PM | #4637 |
Member#: 288003
NWIC
The Need for Pimp GC8 Pics
07-20-2014, 07:19 AM | #4638 |
Member#: 222035
International
Vehicle:1999 sti version 5 white |
07-20-2014, 03:46 PM | #4639 |
Member#: 7887
Vehicle:2023 Tangerine 2023 3 Cylinder |
Saw this at the Pittsburgh Vintage Grand Prix car show. Whoever owns it, well done! Looks fantastic! |
07-20-2014, 06:04 PM | #4640 |
Member#: 340284
Lovely white gc8!!
I took some pictures today Subaru Impreza Turbo GC8 Steel Blue 86F by SpookPictures, on Flickr Subaru Impreza Turbo GC8 Steel Blue 86F by SpookPictures, on Flickr Subaru Impreza Turbo GC8 Steel Blue 86F by SpookPictures, on Flickr Sent from my iPhone using NASIOC |
07-23-2014, 10:56 AM | #4641 |
Member#: 393858
VIC
Vehicle:1996 JDM GC8 STi Feather White |
Not pimp yet but my JDM gc8 sti
Sent from my Nexus 5 using NASIOC mobile app |
07-23-2014, 11:11 AM | #4642 |
Member#: 301037
07-23-2014, 11:13 AM | #4643 |
Member#: 182415
Can canucks up there have it too easy with imported cars, were JUST now getting R32's here keep that thing clean!
07-23-2014, 12:49 PM | #4644 |
Member#: 393858
VIC
You guys just have stupid import laws get with the times. Plus our r32 prices have gone through the roof now due to our southern neighbors buying them.
07-23-2014, 12:52 PM | #4645 |
Member#: 346388
I would move to Canada solely for the purpose of being able to buy a gc wrx or STi.
I agree, that thing nice! |
07-23-2014, 12:54 PM | #4646 |
Member#: 301037
07-23-2014, 01:18 PM | #4647 |
Member#: 393858
VIC
I got asked what type of swap my car had when I was in Seattle -_- thanks for the comments guys
07-23-2014, 02:29 PM | #4648 |
Member#: 214088
VIC
Vehicle:1995 WRX Type RA JDM YO!! |
07-23-2014, 08:55 PM | #4649 |
Member#: 115880
Vehicle:2000 RSTi STM |
07-26-2014, 05:00 PM | #4650 |
Member#: 17300
NWIC
Vehicle:1993 Widebody Wagon 748whp e98 |
I need pimp GC8 pics !! | afstevie68 | Member's Car Gallery | 15241 | 05-20-2010 11:20 AM |
Nascar's Jeremy Mayfield: "I feel the need. The need, for speed!" | Hamsterstyle | Off-Topic | 47 | 11-04-2009 08:34 AM |
JDM GC8 sti turbo front sway bar $40- you NEED for EJ20 GC8 swap | supermoose | Private 'For Sale' Classifieds | 3 | 11-16-2005 04:39 PM |
On the lookout for this GC8 STi bumper, don't know what version it is | mmmprza | Interior & Exterior Modification | 12 | 01-12-2004 04:46 PM |
I feel the need .. the need for speed | DustinR | Motorsports | 1 | 08-12-2001 01:57 PM |
