Welcome to the North American Subaru Impreza Owners Club Tuesday June 27, 2017
Old 05-16-2017, 06:13 PM   #1
Julio Bro!
Member#: 192923
Default Worn emission hoses = oil leaks...
I have a 2009 WRX from which oil is leaking. The culprit are the emission hoses that connect to the block and go up. There are two connections at each side of the engine (why two?), but seem to be different in size (diameter).
They are leaking at more than one spot, so replacement of the whole set or assembly is recommended. The problem is sites seem to sell the hoses individually (http://estore.subarupartswarehouse.c...12-050-07.html), not, like, in a replacement kit or assembly.
So, two options; is it a good idea to replace them with silicone hoses? Is there a silicone assembly or kit?
If not, is there a part number for the whole set or some site that sells a replacement kit?
Julio Bro! is offline   Reply With Quote
Old 05-16-2017, 06:44 PM   #2
thewolfe
Member#: 427424
2014 wrx hatch
black
One is for crankcase ventilation, the other is a balance tube. I would stick with oem on those hoses as they are molded to fit. Silicone would probably work okay though. If you have lots of oil coming out of those tubes then you have some excessive blowby.
thewolfe is offline   Reply With Quote
Old 05-17-2017, 12:14 PM   #3
Samurai Jack
Member#: 21145
2002 Enemy of Aku
You are much better of sticking w/the OEM hoses. The are already pre-formed for the best fit without any kinks. You do not want blockage for oil vapors to build up and the crankcase not to vent properly.
These are not sold in sets. They are sold individually.
and like thewolfe said, if they are actually leaking oil, you have a lot of oil blowby and it's building up inside the hoses ( which is a huge amount of blowby ) or you have a blockage somewhere causing the oil vapor to build up and then leak somehow ( cracked hoses? )
Make sure when you replace the hoses that any other vent tubes they connect to are free and clear
Old 05-18-2017, 12:51 PM   #4
Julio Bro!
Member#: 192923
Thanks for your advice. As for the leaks, the hoses are hard and brittle; the issue began a few months after replacing the gaskets (or fixing) the cylinder heads. I'm guessing the handling caused weakening and cracks; you can see them expanded at connections.
So, I'll verify exactly which hoses and go for OEM. Thanks again.
Old 05-18-2017, 04:00 PM   #5
No Go
Member#: 38928
2004 153 MPH STI
Or go half assessed and take a sample to Autozone and buy heater hose...likely that is what someone did to your car.
Note: someone else just posted the above on the same question/different thread.
I would recommend new OEM like others have posted above. My originals lasted to 190,000 miles...no leaks. I replaced with OEM...a high quality rubber.
No Go is offline   Reply With Quote
Old 05-19-2017, 08:09 AM   #6
schoes
Member#: 420451
2005 FXT
OEM or SAE 30R7 rubber hose. These are oil resistant and won't 'weep' the oil vapors like a heater hose would. Researching AOS threads may help you.
No Go is right, heater hose is probably what is on the car now. Unless they truly are very old.
schoes is offline   Reply With Quote
Old 05-19-2017, 12:17 PM   #7
mrsaturn7085
Member#: 375462
2006 Impreza WRX STI
WR Blue
I always thought silicone was more prone to fluid leakage due to 'weeping'. Heater hoses should be fine (though I still recommend molded OEM hoses) - usually the key factor in automotive hose selection is whether or not you're running brake fluid through the line (and pressure requirements). Fuels are a different story, entirely.
mrsaturn7085 is online now   Reply With Quote
Old 05-21-2017, 02:14 PM   #8
Julio Bro!
Member#: 192923
These are the emissions hoses, EGR-PCV and such 2 or 3 sections are leaking. I have 89K in the odometer, plus Puerto Rico is very hot in the summer...up to 93 degrees daily, suddenly it rains. Quite the drastic change in temperatures for 9 years.
