#1 |
Member#: 374930
Vehicle:2013 Impreza WRX WRB Pearl |
![]() hey all, i have done all the typical misfire checks. I've done the following:
Clean Maf sensor New spark plugs (gapped at 0.028) Inspected all coil packs (did swap 2 to 1, but since no stored CEL i have no idea what cylinder is misfiring) Completed a compression test this morning Cylinder 1: 122 Cylinder 2: 124 Cylinder 3: 124 Cylinder 4: 120 Replaced in-tank fuel filter and fuel pump sock as well. Did a datalog (included below) and only see roughness counts on cylinder 3. Swapped coilpack with cylinder 1 with no change***8230; I was thinking possibly injectors but looking at the datalog i'm assuming it's not that. Only modification change in the last 6 months is a new clutch and lightweight flywheel. Car was tuned with the factory clutch kit and flywheel, so i'm unsure if that would contribute like it used to for the ej20's. Any help would be appreciated, thanks in advance. PS Data log was cut short due to having a dinosaur V2 and sometimes it stops datalogging mid-way. Datalog: https://docs.google.com/spreadsheets...it?usp=sharing modlist: vf48 13 sti tmic walbro 255 invidia catless downpipe spt intake grimmspeed ebcs protuned back in 2014 by Sean at Church in LA Last edited by Inflict89; 11-10-2020 at 06:10 PM. |
#2 | |
Member#: 193940
Vehicle:2004 WRX STI Black RalliSpec Shortblock |
![]() Quote:
#3 |
Member#: 374930
#4 |
Member#: 515308
![]() I swear I remember lightweight flywheel giving misfires somehow
#5 | |
Member#: 193940
![]() Quote:
#6 |
Member#: 149347
NESIC
Vehicle:05 LGT,09 SpecB Black/silver |
![]() Yes, I seem to recall that a LWFW that was was 14lbs. would cause an issue. I think my LWFW is 17 or 19lbs. in my 2005 Legacy GT. I also recall from back in the day, not to also do a LWCP.
#7 |
Member#: 193940
![]() Yap, Mine was giving me major issues until I got it to Jr and he tuned it properly.
#8 |
Member#: 374930
#9 |
Member#: 193940
![]() If its a good tuner and if that is the problem then it should fix the issue. But it has to be a dyno tune, not some e-tune or "Factory Tune kit" which I still have no idea what that it.
#10 | |
Member#: 374930
![]() Quote:
I never said anything about a “factory tune kit” i said it was the factory kit and flywheel which I edited to read factory clutch kit and flywheel. It’s an Action Clutch lightweight flywheel. I’d like to move to a different tuner as Sean is a pain in the ass to get a hold of. I wish Ron did ej’s still and his dyno wasn’t broken... I guess Yimi sport would be a good option.. I’d like to avoid an e tune as this is my wife’s car and rather it all get dialed in during one session. Last edited by Inflict89; 11-11-2020 at 06:09 PM. |
#11 |
Member#: 193940
![]() What FW is it?
#12 |
Member#: 374930
![]() Update. Decided to unplug the maf and start the car... low and behold she idles perfect.. leads me to think this:
Bad maf Bad front o2 Post maf leak I’ll be putting together a smoke tester over the long weekend and see if I can rule that out before throwing parts at the thing. Anyone have any other ideas? |
#13 | |
Member#: 508105
NWIC
Vehicle:2002 WRX Wagon VF39 Midnight Black Pearl |
![]() Quote:
#14 |
Member#: 374930
![]() Yeah, I had taken the car to a shop a number of years ago due to some phantom knock issues. They said it was the maf and they “changed it”. I’m confident at this point they didn’t because the previous owner used RTV to ****ing put it in... needless to say I’ll be buying a new maf and will be trying to carefully remove the one that’s there smfh. |
#15 |
Member#: 478147
Vehicle:2015 STI |
![]() Any update on this?
#16 |
Member#: 374930
![]() Took the weekend off from any headache lol. Ordered a new maf sensor. Since the old one was installed improperly using rtv I’ll likely be doing this Friday night/Saturday as it’s my wife’s daily. I’ll keep this updated till I solve it to help others. But I’m leaning toward MAF or front o2 at this stage. |
#17 |
Member#: 374930
![]() Update. New OEM maf came in this evening so I got to work. Old maf was stuck on there due to the last owner using a ton of rtv on it... after some prying I got it off. Cleaned off the RTV and put her back together. Let idle relearn, took a quick drive around the block and everything felt way better than it had in a very long time... did a quick pull and no more flashing cel and pulled hard to redline.
This is a major reason why I stopped going to "reputable shops" as the last shop I took it to claimed to have changed it and charged me over $150... clearly it wasn't changed. At the end of the day I learned the engine still has great compression for having 105k on the clock. Didn't take a pic of the mess that was on the intake***8230; but looking at the maf i'm sure you can imagine***8230; intake cleaned up nicely. ![]() ![]() |
