Welcome to the North American Subaru Impreza Owners Club Sunday February 28, 2021
Old 08-13-2011, 11:48 AM   #1
Dave G
Member#: 4738
2006 Baja Turbo
Default broken rear shock; 107K miles; replace all shocks/struts? suspension bushings?
My car is a 2006 Baja Turbo with auto trans and 107K miles.
I've got a broken rear shock on the passenger side. The car is driving as if the suspension was disonnected when I hit any bumps, etc. I looked underneath, and that rear shock is leaking some thick black oil substance. The rest of the suspension looks okay, and nothing else seems broken or disconnected.
When replacing that bad shock, I certainly plan to replace both of the rear shocks, but should I also replace the front struts?
The front suspension doesn't feel like there is anything wrong, but it also doesn't feel like it did when it was new.
And the rear suspension hasn't felt new in quite a while.
The ride height is fine, just like when it was new, and I like it that way. Do I need to consider putting in new springs?
The mileage on the car is all highway miles, so the springs haven't had a big workout over the life of the car. I'm thinking that the springs don't need to be changed, but I'd like to hear opinions from others.
I don't see anything particularly wrong with the suspension bushings, but they certainly are not like new. While the shocks and/or struts are being replaced, should I have the suspension pieces removed and have new bushings installed? Is that going to be a lot more expensive?
The plan is to have the work done at my local Subaru dealer. I have not talked to them yet. I wanted to get opinions here first.
Thanks in advance for any opinions.
Dave G is offline   Reply With Quote
Old 08-13-2011, 05:28 PM   #2
Baja_Gernaut
Member#: 229922
2005 F-Inductd BAJA
rumble black
That's good you actually spent the time inspecting the car yourself. Your baja could be premature for any crushed bushings or imperfections in the rear. I would replace both rear struts only from any mechanic other than the dealer. The job is too easy to pay the dealer 89 dollars an hour for labor. If you know or seen a shop, ask them about replacing your rear shocks only. And remember don't go cheap with shocks because you get what you pay for.
Baja_Gernaut is offline   Reply With Quote
Old 08-13-2011, 07:48 PM   #3
Benhart21
Member#: 149617
I'd say $89/hour for dealer labor is on the cheap side. Most I know of are over $100/hour. As far as the springs are concerned, they should be fine and not require replacing. At a minimum, I'd replace both rear shocks, but if it were my car, I'd do the front struts as well. With 100K on them, it couldn't hurt. Bushings are probably not necessary, but again it couldn't hurt to do them. I'd certainly get the wheels off the ground and grab whatever part the bushing is in and give it a few tugs to see if there's any obvious wear.
I was wondering something along these lines. I'm looking at replacing the shocks/struts in my car sometime soon and was looking at options that aren't the OEM parts. I've found some that are listed as Outback/'03 Baja fitment, and I'm wondering if the slightly taller springs on the '04+ would be problematic. I have no idea if that extra inch would over-extend the shock since we've got some gnarly potholes and such around here.
Benhart21 is offline   Reply With Quote
Old 08-14-2011, 03:47 PM   #4
sfeather11
Member#: 220466
2003 Baja
Silverstone
Hey there,
I put 05 springs all around on my '03 to get the extra 1" lift. They worked out well. I also put the '05 shocks on the rear only (my right rear was broken anyways). IIRC the only difference is an extra 1" travel for the rear shocks. The front struts are the same part # for all years, so I left them alone and just changed the springs. I've never had an issue in the last 2 years.
Peace!
sfeather11 is offline   Reply With Quote
Old 11-03-2014, 01:34 AM   #5
aceman67
Member#: 405411
Default 2005 baja
How do you remove the rear strut I understand one side has an access panel behind the drivers seat how do you access the passenger side you need to remove the whole panel completely
aceman67 is offline   Reply With Quote
Old 11-03-2014, 09:57 AM   #6
Grubby Baja T
Member#: 147105
2006 Baja Turbo 5sp
Atlantic Blue Pearl
Aceman,
The top of both rear shocks are accessed behind the rear seatback (fold rear seat bottom forward and seatback down flat). Then remove the plastic pieces (I think there are 3 pieces that have to be removed). You can then access the two nuts on the top of each rear shock.
Mike
Grubby Baja T is offline   Reply With Quote
Old 11-27-2020, 07:36 PM   #7
bmann
Member#: 425834
2009 WRX
Old thread, but just to add to the fun, you have to remove the whole panel. Though it looks like there are places you can get leverage to pry apart the little "cup" on the passenger side, it's fastened to the panel permanently. Pulling the whole panel off isn't super difficult, it's just held in by clips that will release if you pull it toward the front of the car. There is also a horizontal clip at the bottom, once you get the two forward facing ones free.
bmann is offline   Reply With Quote
FS : Whiteline sway bars, strut tower bar, Energy suspension bushing kits, Seth02WRX Suspension/Brakes/Handling 20 03-25-2011 10:03 AM
REPLACING Stock shocks and struts surfsubaru Newbies & FAQs 15 04-09-2010 02:35 PM
06 STi noise from font left shock. All is 100% stock, dealership replaced the shock DarkDvr Brakes, Steering & Suspension 1 06-19-2009 12:29 AM
New rear WRX KYB stock replacement suspension struts (assembled w/coils & tophats) deadeye Suspension/Brakes/Handling 2 02-25-2008 09:37 PM
Help with replacement option on strut from Subaru SPT Suspension Loaf Brakes, Steering & Suspension 8 04-27-2005 10:10 AM
