#26 |
Member#: 291990
Vehicle:2003 BUGEYE WAGON PSM |
#27 |
Member#: 291990
![]() Just found this....post # 10. http://forums.nasioc.com/forums/show....php?t=2289168
#28 |
Member#: 291990
![]() Wow. I too was the victim of the evil axle pop out. Car is great now!!!
#29 |
Member#: 334797
TXIC
Vehicle:2007 WRX STI CGM |
![]() what if the front drivers side wheel is the one thats not spinning? does that still have anything to do with the rear diff? i need to know how to fix this issue.
#30 |
Member#: 341465
![]() Tagged for solution. Is there an air bubble somewhere?
#31 |
Member#: 394143
Vehicle:2002 WRX PSM 09 NISMO 370z / 90 GT-R |
![]() Bumping old thread
I have been having issues with 'clutch slipping' in very cold weather, replaced the clutch (had 80k on it) and it didn't fix the problem. Turns out the rear left axle popped out. Used a pry bar to push it back in until you hear a click as the retaining clip engages. Slipped out on the top picture, normal on the bottom. ![]() |
#32 | |
Member#: 425129
Vehicle:2002 Impreza 2.5ts Midnight Black Pearl |
![]() Quote:
#33 |
Member#: 484071
![]() Having the same problem. Blobeye. Replaced the clutch a month ago during warmer weather clutch grabbed really great. Then colder weather hits and I get a grinding noise and slipping when I accelerate. Sometimes I get a clunck on my rear driver side under weight and acceleration. Especially with passengers on the rear driver side. Gonna look into that axle issue. Will update
#34 |
Member#: 484071
![]() Drive rear Axle had popped out of rear diff like a half inch. Just enough to see a little bit of the end of the axle. Pushed it back in and car rides like a dream again. Idk what causes this but it seems that it pops out just enough to where you lose awd.
Hot weather vs Warm Weather vs Cold Weather - RPM issue. | SausageCat | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 7 | 09-01-2009 09:51 PM |
Accessport maps and cold weather issues? | KevinWRX | AccessPort | 1 | 02-22-2008 06:53 AM |
Very cold weather clutch issue | semabe | Transmission (AT/MT) & Driveline | 4 | 03-04-2004 04:24 PM |
cold weather -- gas smell issue | wrxdriver | North West Impreza Club Forum -- NWIC | 17 | 01-15-2004 03:42 PM |
Cold weather clutch and tranny stuff | leecea | Transmission (AT/MT) & Driveline | 2 | 01-11-2004 12:02 AM |
