Welcome to the North American Subaru Impreza Owners Club Tuesday March 2, 2021
Old 12-31-2020, 09:32 PM   #1
Samurai_jim
Member#: 175238
2004 WRX
black.
Default Lit up like a Christmas tree
Well hello, it's been a while since I've posted or been on the forum. By force, not choice. I'll just say that the U.S. Government doesn't care about current state laws regarding cannabis. You can still go to federal prison even if you are within state law. Never mind the 9th Amendment to the Constitution. Or Article 4, Section 2, Clause 1....
Anyway, my wife has a 2005 Forester XT. It was in the care of family members while we worked for .12 cents an hour for a few years. Upon our return, I find that the car has the ABS light, Airbag light, Cruise light, and Check Engine light on, also, the horn doesn't work.
The check engine light is an EVAP code, which I suspect has something to do with the fact that you have a real issue getting gas in the tank. The pump nozzle will click off after 1-2 seconds. It takes 10 minutes to get 20 bucks of premium in the tank. So, I will resolve that issue ASAP.
But I really don't know why the ABS, Cruise, and Airbag lights are on, or why the horn doesn't work. I've read some threads about the clock spring, but there was no work done to the car involving the steering wheel or airbag system.
I used to have a 2004 WRX Limited in Java Black Pearl, that I did a full STi swap into. I did all the work myself. Plus DW 750's, FP 68 HTA turbo, Cobb full catless exhaust, CAI, sway bars, etc. etc. Sold it on here to a fellow from Canada. (I'd like to know how the car is doing) So, I'm not stupid when it comes to these cars. But I have no idea where to start with these issues besides throwing parts at it and seeing what happens. Can anybody give me some assistance? Thanks!
Samurai_jim is offline   Reply With Quote
Old 12-31-2020, 11:51 PM   #2
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
Sounds like a evap canister vent valve issue. Cheap enough to replace that.
Cruise is probably on because check engine. Abs you'd have to check with scanner to see if any sensors are bad.
Old 01-01-2021, 12:05 AM   #3
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
Try disconnecting the small wire connector going to the rear of the alternator to see if the warning lights go out. If that works then you will need to replace the alternator.
Cougar4 is offline   Reply With Quote
Old 01-01-2021, 12:29 AM   #4
Samurai_jim
Member#: 175238
2004 WRX
black.
Thanks for the replies. The evap canister issue is easy enough to fix. Hopefully it's that and not the valve on top of the gas tank.
What's this with the alternator?
Old 01-01-2021, 12:15 PM   #5
Cougar4
Member#: 53443
Winestone
The warning lights are tied to the alternator exciter circuit so they can be tested when the ignition is turned on.
Old 01-02-2021, 10:36 AM   #6
Samurai_jim
Member#: 175238
2004 WRX
black.
So unplug the connector that has two wires going into it that is on the alternator? If the lights go off, I need to replace the alt?
Old 01-02-2021, 11:57 PM   #7
Cougar4
Member#: 53443
Winestone
Yes, that is correct.
Old 01-03-2021, 12:10 AM   #8
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
But his battery light isn't on?
Old 01-03-2021, 12:46 AM   #9
Samurai_jim
Member#: 175238
2004 WRX
black.
No battery light....
Old 01-03-2021, 12:39 PM   #10
Cougar4
Member#: 53443
Winestone
Yes, I also had wondered about the battery light and it not being on. This may mean that the alternator isn't causing the issue, but it is a very simple test to do and verify that it isn't causing the issue. I assume the battery warning light is working correctly and it turns on, along with the other warning lights, when the ignition is turned ON.
Old 01-03-2021, 06:44 PM   #11
Samurai_jim
Member#: 175238
2004 WRX
black.
The alternator tested good.
Old 01-03-2021, 10:02 PM   #12
Cougar4
Member#: 53443
Winestone
There may be a common problem causing the warning lights to be on, a bad blocking diode perhaps. You may have to track down each circuit one at a time to find the trouble. You need a factory manual for the wiring. The trouble may be within the combination meter.
Old 02-11-2021, 11:46 AM   #13
Samurai_jim
Member#: 175238
2004 WRX
black.
Ok. I'm back at this.... So, i was able to fix the fuel filling issue. It was the charcoal canister. But my ABS light and airbag light are still on. And the cruise still doesn't work, aaaaannnnnnd the horn doesn't toot either. Now, I have a battery light and the e-brake light on as well.
So, my question about this alternator check, do I unplug the little green plug with two wires on it while the car is running, or just with the ignition on?
I really wish there was a good Subaru mechanic close to me. I'd pay to get these issues fixed....
Old 02-11-2021, 11:58 AM   #14
Mulder
Trust no one
Member#: 11170
02 RAV4 MT
15 WRX/11 CRZ
Airbag light + no cruise + no horn sure sounds like clock spring. Even if you haven't touched the steering these do wear out. To be certain you'd need to have it scanned to read the airbag code.
Old 02-11-2021, 04:34 PM   #15
Cougar4
Member#: 53443
Winestone
I totally agree with Mulder's advice about the clock spring. Since the alternator check light is now on also you should check the battery voltage at the battery while the engine is running around 1,500 RPM. You should see between 13.8 to 14.8 volts there if the alternator is working correctly. I kind of sounds like you are going to need to replace the alternator going from what you stated.
