Welcome to the North American Subaru Impreza Owners Club Wednesday March 3, 2021
Old 12-19-2020, 07:38 PM   #1
vanman23
Member#: 519102
2005 OBXT
Default Should I change the rear main seal
The engine is out from a timing belt break. We've redone the heads but did nothing to the short block. There is no indication of a rear main seal leak. The engine has 170K miles on it. 05 OBXT AT
Should we let sleeping dogs lay?
vanman23 is offline   Reply With Quote
Old 12-19-2020, 07:41 PM   #2
JDMRosa04
Member#: 504206
Never hurts to do, easy and cheap
JDMRosa04 is offline   Reply With Quote
Old 12-19-2020, 07:54 PM   #3
NighthawkSTI
Member#: 495630
at 170,000 miles I think its good insurance to put a fresh rear main seal in, especially if you plan on keeping the car for awhile. They actually dont have a reputation for leaking the crankcase cover can though. I changed my rear main seal at 87,000 when I did my clutch just to get the experience, and for piece of mind. I didnt want to do $700 in clutch parts to have a leak a couple years later.
NighthawkSTI is offline   Reply With Quote
Old 12-20-2020, 11:15 PM   #4
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
I agree - at 170k miles, given the cost and how easy it is to do now vs. after you put everything back into the car, it would be foolish not to.
DrD is offline   Reply With Quote
Old 12-21-2020, 12:32 AM   #5
vanman23
Member#: 519102
2005 OBXT
Thatíll be the plan then to replace it. Iíve heard of stories in which they started leaking after a new one was put it.
What about the oil air cover?
Old 12-21-2020, 02:09 PM   #6
NighthawkSTI
Member#: 495630
Originally Posted by vanman23 View Post
That'll be the plan then to replace it. I've heard of stories in which they started leaking after a new one was put it.
I read about the instances where it would leak after installed new, but those are situations where either the installer put a scratch on the crank when forcing out the old one with a makeshift "tool"(which will create a path for oil to escape around it and or tear up the seal), or they didnt install it properly, most commonly seating it too far back allowing oil to bypass it and come out, or tearing it or bending the metal spring inside it by installing it cocked.
I bought a disc from a subaru tool vendor that fit over the new seal and has a collar on it so that as the new seal is tapped in "squarely" it seats it at the correct depth and wont allow it to go further.
I left the crankcase covers alone and did just the seal. Of course if they look like they are leaking remove them and put new silicone sealer
Old 12-21-2020, 04:11 PM   #7
car_freak85
Member#: 13530
EA63 , EA81T, EJ20G,
EJ205
The rear main crank seal on EJ engines is a royal pain to remove, even with the correct tool. I'm not surprised many replacements end up with a leaking seal, because it is quite easy to scratch the bore.
When I was replacing the HGs on our EJ253, I asked a trusted friend who owns an independent Subaru repair shop his opinion. He said "Don't touch it if it's not already leaking." I couldn't leave well enough alone and after much cursing and breaks taken, I finally got the old seal out.
This is truly one of the cases were if it's not broken, sweet baby Jesus, don't bother replacing it.
car_freak85 is offline   Reply With Quote
Old 12-22-2020, 11:46 AM   #8
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
My school of thought would be if you have a polymeric seal (particularly if it's also a dynamic seal (seals on a moving interface)) that's going to require that either the engine or transmission be removed in order to get it if it leaks, I would replace it. A static seal, if it's not leaking, is probably ok - but if it got distorted or otherwise damaged while the engine is out and starts leaking in a month, it's not going to be a happy day for you.
It sounds from the posts above that the EJ25 RMS is difficult to remove without scoring the bore in the block or the crank, so that's something to consider - that being said, 170k miles and 15 years is a lot for a dynamic seal, though, so if you are going to be driving the car for years more, given that the engine is out of the car now, and the seal is right there, I'd replace it.
Old 12-22-2020, 01:22 PM   #9
Brokebecauseofsubies
Member#: 521121
Rear main seals are pretty cheap to do and it would hurt to freshen it up
Brokebecauseofsubies is offline   Reply With Quote
Old 12-22-2020, 06:59 PM   #10
NighthawkSTI
Member#: 495630
I think it was $7 at the dealer if I remember correctly.
Old 01-01-2021, 01:41 PM   #11
mike_n
Member#: 468458
2009 Impreza 2.5i NA
gray
I would definitely replace it especially if you don't know if it's been done before.
mike_n is offline   Reply With Quote
Old 01-01-2021, 05:10 PM   #12
AliBenn
Member#: 487
1998 /2005 STunIcorn
Acadia Green RS-T
Like replacing T-belt and not replacing tensioner(among other inexpensive parts)
RR the seal
Old 01-03-2021, 11:57 PM   #13
CaptainSlowbaru
Member#: 445600
2002 Outback Sport
Green
If your separator plate is aluminum, replace it. I don't remember when Subaru changed from aluminum, but the latest design is stamped steel, and they tend to not leak. Also, there is a wrist pin access plate back there with an o-ring. Might as well replace that too- sometimes they seep oil.
CaptainSlowbaru is offline   Reply With Quote
Old 02-27-2021, 10:42 PM   #14
SubiSIR07
Member#: 461885
I absolutely would. You just did all that work pulling the engine out you won't want to do it again because you skipped replacing one gasket. Better insurance to change it while it's out.
SubiSIR07 is offline   Reply With Quote
