Welcome to the North American Subaru Impreza Owners Club Thursday March 4, 2021
Old 06-01-2016, 10:59 AM   #26
hockymad1
Member#: 438543
2003 Impreza Wrx
no it broke inside of the housing
hockymad1 is offline   Reply With Quote
Old 06-02-2016, 10:05 AM   #27
quazimoto
Member#: 70395
Take a picture. I have no idea what a "cylinder housing" is.
Old 09-21-2017, 10:37 AM   #28
HAMERMAN409
Member#: 188099
OP - looks like some great information here - can you please update the photo links (maybe these photos were hosted on photo bucket)?
Short of that does anybody have the photos for this and the engine removal saved? If so it would be great if they could be zipped up and posted to sendspace or some other file hosting service along those lines.
HAMERMAN409 is offline   Reply With Quote
Old 11-29-2020, 02:11 PM   #29
wrenchMonkey99
Member#: 520587
I know this is ancient, but...
The first reply in this thread says:
3) You need to get the sealing surfaces for the head gaskets way cleaner than that. Those little dark areas are sites for potential future HG leaks. Subaru HGs are stupid fracking picky about how well you clean up. All around the sides of the shortblock, all under the heads, needs to be spotless.
I've been cleaning with a plastic razor, a rag and brake cleaner for 3 hours, and those little dark spots stubbornly persist!
Many seem to advocate using a razor blade, and others say never use anything sharp or abrasive. I can understand why, and it seems much safer not to, so I've erred on the side of caution. Is there any solvent that will help loosen them up?
Thanks for any advice!
wrenchMonkey99 is offline   Reply With Quote
Old 11-29-2020, 07:22 PM   #30
Jp925
Member#: 510046
I use a roloc white head for my head gasket and mating surfaces. It cuts everything like a hot knife in butter and won’t risk any damage to the soft aluminum.
Jp925 is online now   Reply With Quote
Old 12-04-2020, 02:54 PM   #31
neg_matnik
Member#: 132389
+1 for white roloc
neg_matnik is offline   Reply With Quote
Old 01-05-2021, 05:04 PM   #32
604bugeye
Member#: 521477
Very helpful thank you!
604bugeye is offline   Reply With Quote
Question for the local mechanically inclined about head gasket replacement crxtls2 New England Impreza Club Forum -- NESIC 11 04-05-2005 09:20 AM
what to get when leaky head gasket replaced at dealer? bigpaulo Service & Maintenance 1 03-08-2005 09:39 AM
head gasket replacement suby53 Normally Aspirated with bolt-on Forced Induction Powertrain 8 12-10-2004 05:33 PM
2000 Legacy Head gasket replaced... 45K spburns74 Legacy Forum 17 01-25-2004 07:21 PM
Dirty Block & head gasket replacement SCOOBER Normally Aspirated with bolt-on Forced Induction Powertrain 0 03-27-2003 07:52 PM
