Welcome to the North American Subaru Impreza Owners Club Tuesday March 2, 2021
Old 01-05-2021, 05:08 PM   #1
604bugeye
Member#: 521477
Default 4eat TCM DTC code 23
Just went stage 2 with cobbs OTS tune on my 02 WRX. Did a ATF change along with the filter. Now tranny is acting up, only when I full throttle and it downshifts seems to kind of stutter and at oil temp will pop up. Maybe I possibly didnt fill ATF to correct level? Did the secret handshake and I seem to get code 23
( two long flashes, 3 quick flashes )
Now if Im correct 4eat on 02 wrx is phase II version I? Cant seem to find what the code 23 means for that specific 4eat, anything will be helpful thanks.
604bugeye is offline   Reply With Quote
Old 01-05-2021, 05:25 PM   #2
Blktrax
Member#: 220971
2004 Impreza
Trans gets filled idling in park
Lowest 2 dots are add and full at cold ambient temp, upper 2 dots are add and full at operating temp.
Sounds like you're under or overfilled significantly.
Service Manual:
The level of ATF varies with fluid temperature. Pay attention to the ATF temperature when checking ATF level.
1. Raise the ATF temperature by driving a distance of 5 to 10 km (3 to 6 miles). Otherwise, idle the engine to raise ATF temperature to 70; 80C (158; 176F) on Subaru Select Monitor.
2. Park the vehicle on a level surface.
3. After selecting all positions (P, R, N, D), set the select lever in P range. Measure the ATF level with engine idling for one or two minutes.
4. Make sure that ATF level is between the upper level and lower level at HOT side.
5. If the ATF level is below the lower level, replenish recommended ATF to bring the fluid level between the upper level and lower level.
CAUTION:
-Use care not to exceed the upper limit level.
-Be sure that the replenishment of ATF to the upper level with the transmission cold will cause overfilling of ATF and result in a transmission failure.
6. Raise the ATF temperature by driving a distance of 5 to 10 km (3 to 6 miles). Otherwise, idle the engine to raise ATF temperature to 70; 80C (158; 176F) on Subaru Select Monitor.
7. Check the ATF for leaks. Make visual inspection for leaks from the inside of transmission. If there are leaks, repair or replace the gasket, oil seals, plugs or other parts.
Blktrax is offline   Reply With Quote
Old 01-05-2021, 06:43 PM   #3
604bugeye
Member#: 521477
Service Manual:
CAUTION:
Ill double check my level, still curious on the code 23 as to what it means.
Old 01-06-2021, 12:14 AM   #4
Blktrax
Member#: 220971
2004 Impreza
DTC 23 Mass air flow signal
Detects open or shorted input
signal circuit.
<Ref. to AT-46, DTC 23 MASS AIR FROW SIGNAL,
Diagnostic Procedure with Diagnostic Trouble
Code (DTC).>
DIAGNOSIS:
Input signal circuit of TCM from ECM is open or shorted.
TROUBLE SYMPTOM:
Excessive shift shock.
Old 01-06-2021, 12:46 AM   #5
604bugeye
Member#: 521477
signal circuit.
Code (DTC).>
DIAGNOSIS:
TROUBLE SYMPTOM:
Thanks again,
Old 01-06-2021, 01:05 AM   #6
604bugeye
Member#: 521477
signal circuit.
Code (DTC).>
DIAGNOSIS:
TROUBLE SYMPTOM:
You recommend I replace my MAF? Or take a look at the TCU
