#1 |
Member#: 493872
![]() My 170k engine is getting a little tired, so I’m starting to plan out what direction I want to go with replacing it. I don’t really want to deal with all the headaches of settling up or deleting AVCS. So I was wondering about using a jdm shortblock with my USDM heads. Has anyone done this?
#2 |
Member#: 182415
Vehicle:1999 RS Aspen White |
![]() Yes..
#3 |
Member#: 125887
AKIC
Vehicle:2001 EJ207 V7 RSTi, Mica Blue |
![]() Can you tell me what all setup headaches you speak of? And you can run your JDM block with your USDM ecu just as easy... Whichever way you choose to go is your choice
#4 |
Member#: 50586
RMIC
Vehicle:2020 STI Crystal White Pearl |
![]() setting up AVCS is really not hard and so much worth it...imo I wouldn't ever go back to a non-avcs engine they just are so slow...all you have to do is run 4 extra wires from the engine to ecu...i mean if you can build an engine I'm sure you can get AVCS setup and running...
#5 | |
Member#: 110078
Vehicle:02 Bugeye JDM STi OBP BLACK |
![]() Quote:
It’s not hard to wire AVCS but not as easy as you say. |
#6 |
Member#: 125887
AKIC
#7 |
Member#: 395793
AKIC
Vehicle:2005 92x Aero Beige |
![]() Thank you. I'm getting tired of correcting this. To the OP. Yes add 4 wires but also re-pin wires at the ECU and on an engine harness plug by the battery. This is why companies like iA Tuning and iWire make AVCS wiring kits which do make it easier. And as has been mentioned, once you have AVCS, you'll never want an engine without it again. |
#8 |
Member#: 493872
![]() Actually I would love to have the AVCS, but I really want to be able to get tuned using an accessport. The JDM ecu is what I meant by headaches
#9 |
Member#: 395793
AKIC
![]() Get it open source tuned. It's not a headache. It's just a different platform. And it will save you money since you don't have to buy an AP. And if you already have one you can sell it and make some money back. I don't miss having my AP. AVCS is worth more than having the AP
#10 | |
Member#: 110078
![]() Quote:
Agreed. |
#11 |
Member#: 333468
RMIC
Vehicle:93 SS - 06 OB XT 03 WRB GD 205/22T 20G-XT |
![]() Don't you need the JDM ecu to run AVCS? If so I would have problems with emissions where I live. I could always swap over the the USDM ecu to pass I guess...
#12 | |
Member#: 395793
AKIC
![]() Quote:
Not sure what you're really asking here. Yes you need the JDM ECU for AVCS and yes you take 15 min and swap the ECU for emissions. |
#13 | |
Member#: 333468
RMIC
![]() Quote:
Yes, swapping out the ECU isn't that big of a deal. Maybe a little bit of a pain for some, and adding to that pain is the fact that I have to swap out my high flow catted DP every year for the stock DP makes it a little bit more of a pain. |
#14 |
Member#: 501997
Vehicle:2011 WRX gray |
![]() You just need to find a shop that will over look the visual inspection. I have been running catless for years and my shop will pass it as long as no engine light on.
#15 |
Member#: 378421
Vehicle:2005 Cobb Stg2+ Wrx Platinum Silver |
![]() I too wanted to know about using my usdm ej205 heads, that i have, on a jdm ej20 block that has no heads, and only responses were "thats stupid, do avcs". I wish ppl would just help instead of try to persuade other to do things different...
Im 99% sure you can bolt usdm ej20 heads on a jdm ej20 block, and should be able to run it and tune it with the usdm ecu. No clue what that will do to compression ratio or piston to valve clearance other than "thats stupid, AVCS ftw!!!!" |
#16 | |
Member#: 395793
AKIC
![]() Quote:
It sounds like the OP has a JDM long block. In this case it's easier to install the entire long block regardless of using AVCS. Tearing everything apart would result in taking it to a machine shop and having everything clearanced and tolerances checked before mating it all back together. It's an added expense. If you have a JDM short block and no JDM heads then that's a different story. There's no reason why you can't use the USDM heads and make it work. Any reputable machine shop can check tolerances, and make sure you're getting proper piston to valve clearance and quench height. The problem is there's a lot of bad information out there that makes people scared to use the JDM engines and hook up the AVCS when they aren't familiar with the process. So if you have a full JDM long block, why spend the extra time and money to use the USDM heads and not have the extra performance of the JDM heads? It's a step backward. If you don't have the heads then it really doesn't make a difference. Do whatever fits your budget best as no matter what heads you use, they will still need to mated to the SB properly. |
#17 | |
Member#: 378421
![]() Quote:
All im saying is, cant we help him with info about his question, usdm heads on jdm block, instead of telling him to use jdm heads, which doesnt answer his question? Last edited by 4eat05; 12-14-2020 at 06:28 PM. |
#18 | |
Member#: 395793
AKIC
![]() Quote:
Why are you getting on everyone's case? I get that you weren't happy with the responses you had from your questions in a different thread, but in this one, the OP even stated he would like to use AVCS and just thought it was going to be more complicated than he thought. But if he has a JDM engine then why spend the extra money to use inferior heads? If all he has is a short block than he can say so and we can change our responses accordingly. Without reading your thread I can't say why people weren't giving you info for your specific question. But even so, in this thread people said yes you can and asked what headaches he was referring to. He even stated his only reason for not wanting to use the JDM heads was to retain using his AP. Information was given to show him the pros and cons. Soooooo let's keep this thread on topic rather than getting on everyone's case and if the OP isn't getting the info that helps him he can say so. |
#19 |
Member#: 93750
![]() I have a jdm ej205 with avcs for sale. Compression video included. Can separate the block from the heads if you choose to go that route. Pm me if interested
