Welcome to the North American Subaru Impreza Owners Club Monday March 1, 2021
Old 01-10-2021, 08:21 PM   #1
OhThatHurt
Member#: 490876
2016 STI
Ice Silver Metallic
Default '16 STI - OEM Up Pipe Flexible?
Kind of a noob question... Does the OEM up pipe have a built in flex coupler?
Background - Today I removed my EL header to have it thermal coated. After I removed the header I bumped the bottom of the OEM up pipe and it moved a bit. Seems there is about 1/4 in of movement if I push/pull gently sideways. All bolts on top are tight and there are no signs of soot. No CELs, boost issues, or exhaust leak noise, so I don't think it is cracked. Is a slight amount of movement normal?
OhThatHurt is offline   Reply With Quote
Old 01-11-2021, 08:25 AM   #2
undyjr
Member#: 459692
2019 WRX STI
silica black
Yes, there is a accordion like flex connector under the heat shield. In my situation my factory up pipe developed a split in the flex connector. I attempted to braze the split with my oxy acetylene rig and %56 silver bearing solder. The metal is just too thin. Without knowing if this is a typical occurrence I would plan on replacing it when most convenient.
undyjr is offline   Reply With Quote
Old 01-11-2021, 01:26 PM   #3
OhThatHurt
Member#: 490876
2016 STI
Ice Silver Metallic
Thanks for the feedback. I did find confirmation of the OEM flex connector in the uppipe FAQ. The car only has 8K miles. At this point I think the movement I found is normal. I had not detected any leak or unusual sound before removing the header.
When your UP developed the crack what were the symptoms?
Old 01-11-2021, 02:20 PM   #4
undyjr
Member#: 459692
2019 WRX STI
silica black
The initial symptom has hissing/whooshing sound during WOT. Comparing datalogs in particular the lower WGDC showed a pre-turbo exhaust leak. After torching off the heat shield (kinda sketchy, not recommended) and using an inspection mirror I found the 1 inch split. Without a doubt extended periods of WOT fatigued the flex joint. If you never go WOT past 4th you'll probably be ok.
Old 01-11-2021, 10:58 PM   #5
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Uppipe crack = loss of PSI and/or noise...lots of new noise.
Old 01-11-2021, 11:46 PM   #6
OhThatHurt
Member#: 490876
2016 STI
Ice Silver Metallic
@Unabomber I am pretty sure the movement is normal and nothing for me to worry about. I did not know the OEM uppipe had a flex section on it. It kind of freaked me out that I could move it a little bit. Learning as I go... I did not notice any unusual noise or boost loss before removal of the EL header. I happened to get some logs just last week for my tuner (BrenTunung) to review MAF scaling before I removed the header. He did not indicate there was anything unusual.
