Welcome to the North American Subaru Impreza Owners Club Friday February 26, 2021
Old 05-13-2019, 11:59 AM   #1051
jon102034050
Member#: 223895
2018 STI
white
Originally Posted by Ashley12345tran View Post
Still for sale?
yes - i'll pm you
jon102034050 is offline   Reply With Quote
Old 05-14-2019, 02:12 PM   #1052
DustoMan
Member#: 79602
2015 WRX Limited
Lightning Red
So I got one of these Joying units. John Nguyen on YouTube recommended buying the Toyota Hilux cable they sell for people that have Harmon Kardon units. I figured it was $20 so I'd just try it. It works for the most part. I found that the Left/Right rear audio channels were swapped so I need to switch those. However, The Amp Con wire that tells the HK amp to turn on wasn't connected to anything. I think it needs to put on the 10-pin harness in the pin 9 socket. I want to try that but I need to find out what kind of pins go in that harness. Does anyone know where I can buy one?
DustoMan is offline   Reply With Quote
Old 05-17-2019, 12:41 PM   #1053
amiexploited
Member#: 251061
18 Trek 6mt,
garage queen 15 WRX 6mt
If I remember correctly the orange (or blue?) amp wire needs to be tapped for power. My harness didn't power the amp so I tapped it myself.
amiexploited is offline   Reply With Quote
Old 08-26-2019, 02:14 PM   #1054
John321
Member#: 505685
Default Need help My android Quad core R16
I have and I top way android R16 quad core Something happened when I shut my vehicle off it did some update from Google and then when I turn my vehicle back on my DVR was not working the radio no longer work the movies and music was not working so I did a factory reset I forgot to backup the original data and now I'm been trying to recover everything I've been looking for a MCU update I email the company I bought it from but no luck
John321 is offline   Reply With Quote
Old 10-09-2019, 01:45 PM   #1055
Thatsubaruguy77
Member#: 448049
So for no good reason my bluetooth feature on my octane core unit from GreenYi stopped working today. Doesn't show up as a discoverable device on my phone anymore. Has anyone had this happen to them?
Thatsubaruguy77 is offline   Reply With Quote
Old 11-09-2019, 02:32 PM   #1056
TBatall
Member#: 508205
Default 08-14 wrx seicane head unit
I have everything working on my head unit but my steering wheel controls. I was wondering so one has had this same problem before.
Do I I need another harness to make it work?
TBatall is offline   Reply With Quote
Old 04-04-2020, 11:44 AM   #1057
joostin420
Member#: 1046
2020 WRX Limited
Ice silver metallic
MY19/20 limited with nav and harman Kardon - which wire do I tap for the harman amp turn-on from the vehicle side? I am reading either +12v or or blue amp turn-on wire is sufficient from aftermarket head unit side.
Thanx,
Justin
joostin420 is offline   Reply With Quote
Old 05-11-2020, 02:20 PM   #1058
alapilusa
Member#: 424692
2015 WRX
I recently updated my Samsung Galaxy Note 9 and now the Easy Connection app that mirrors my phone to the headunit won't allow me to use the headunit as a touch screen like the phone. So I can't switch between apps, i cant type in adresses into Waze or Google Maps, or anything like that from the headunit. I need to use the phone as the touch screen. Anyone know of a setting in the phone that needs to be adjusted for that functionality to work again?
alapilusa is offline   Reply With Quote
Old 06-02-2020, 10:16 AM   #1059
alapilusa
Member#: 424692
2015 WRX
did a bit more research and currently, the Easy Connection App developers are looking for a way for it to gain access to the phone with Android 10. Hopefully there will be an update with this feature soon, but in the meantime, it will just mirror your phone screen on the headunit without control through the headunit.
"Android system started to limit the access right which made Android 10 users cannot control from the car display anymore. We apologize for it, we've tried lots of solutions, but no one can solve it. Otherwise, we will launch personal software for Android car"
https://apkpure.com/easyconnection/n...onn.carman.wws
Old 06-24-2020, 05:55 PM   #1060
amiexploited
Member#: 251061
18 Trek 6mt,
I could never get the easy connection app to work for me. Samsung S8+. I've been using Headunit Reloaded and after a few updates it works great. Just can't get the google commands to work when I am driving. My car isn't that loud and the google dots/lines at the bottom don't bounce like when I'm stoppped. The stereo recognizes the "ok google" command but nothing else after that. The developer thinks it's my car not allowing the mic to work while I'm driving. If anyone has a solution to get this working while i'm driving I'd appreciate.
edit: realized easyconnection is a full phone control app. disregard.
Old 06-25-2020, 02:46 AM   #1061
hotsriracha
Member#: 516116
2019 WRX
That look REALLY good!
hotsriracha is offline   Reply With Quote
Old 12-02-2020, 05:55 PM   #1062
amiexploited
Member#: 251061
18 Trek 6mt,
Does your phone show up in the bluetooth devices? I remember getting issues trying to delete my phone. Try to see if you can delete it and reconnect.
Old 12-22-2020, 04:38 AM   #1063
Earl2
Member#: 519650
I think you having this issue with the app because which version you are using is not compatible with your mobile version which version of app you are using and have you tried to download the app another version.
Earl2 is offline   Reply With Quote
Old 12-22-2020, 01:27 PM   #1064
Brokebecauseofsubies
Member#: 521121
Are these head units any good? From watching a few reviews people said they feel cheap and don’t always work the best but I’m looking for a new head unit for my outback let me know what is the best for the price
Brokebecauseofsubies is offline   Reply With Quote
Old 01-12-2021, 11:41 AM   #1065
m016324
Member#: 521623
I've had mixed outcomes with them. I think some of the newer versions of the andriod headunits work significantly better than the older ones. I also think that picking one that's specific to the car instead of a generic unit makes a big difference. Used essentially this same unit in a E39 BMW and it was fine until some of the internal wiring started failing in about a year.
m016324 is offline   Reply With Quote
Old 01-12-2021, 02:33 PM   #1066
amiexploited
Member#: 251061
18 Trek 6mt,
delete, wrong quote.
Old 01-28-2021, 07:24 PM   #1067
socal_scoob
Member#: 521645
'13 WRX Hatch
I purchased one used for about $200 on Facebook. They look awesome because of the huge screen and give you loads of features and functionality. But at the end of the day they are cheap and don't always work. The Bluetooth on the unit I had would never work properly. I would have to manually pair my phone every time if I wanted to listen to music. I ended up selling it for $250 and purchased a Sony XAV AX5000. In my opinion, these units are nothing but an android tablet snuck into a car audio din. I recommend getting a proper double din radio from a brand such as Sony, Kenwood, or JVC. Take a look at the AX 5000 or the brand new AX 5500 by Sony.
socal_scoob is offline   Reply With Quote
Old 02-03-2021, 12:07 PM   #1068
amiexploited
Member#: 251061
18 Trek 6mt,
Just bought a new android 10.0 seicane to replace my old android 8.0 headunit. I wanted it to be plug and play with my custom T harness I bought the same brand since it uses the same harness. This one includes DSP and the IPS touch screen. Installed it yesterday and so far everything works. I never had bluetooth issues and it never restarted on me. I kept wifi off unless needed for updates because that caused low level static sounds. Glad my new one doesn't!
From what I researched, there are newer/better ones out there like the new Joying and new Dasaita. They use a different harness and are shipped from overseas. I don't recommend other brands or cheaper ones since they come with 2gb RAM, older Android versions and poor quality control. There's plenty of youtube videos reviewing the newer ones if you want to get a feel of what you're actually getting.
Old 02-04-2021, 05:34 PM   #1069
Bluefoton
Member#: 141373
2019 Crosstrek Sport
6MT
I had a Joying one for years in my 08. Loved it, especially being able to run Torque Pro - it was my default screen. No issues with the integrated satnav, the radio or MP3 playback either.
Bluefoton is offline   Reply With Quote
Old 02-22-2021, 01:37 PM   #1070
IggyBcool
Member#: 402169
I have an iDoing that came with Android 10. When ever there is an update for the head unit operating system, is there a generic file that will work for all of them? I ask because even if I connect my head unit to my home wifi, I cant click system update.
IggyBcool is offline   Reply With Quote
Old 02-22-2021, 08:06 PM   #1071
amiexploited
Member#: 251061
18 Trek 6mt,
from my understanding you need an update file to update not OTA.
Have you tried looking for a 2.4Ghz wifi signal?
Old 02-23-2021, 05:29 PM   #1072
IggyBcool
Member#: 402169
Yeah I'm guessing it is a file you have to have. Was wondering if the file worked for all Android HU or if it's brand specific?
Randomly had an issue with my iPhone 12 Max and my HU. CarPlay was working flawless, music working fine, maps working fine... then suddenly no media would play. Maps still work fine, but no music or in app sounds. But if you pressed anything on the head unit it would still chirp. Even while connected via cable. Anyone had an issue like this? I've formatted my HU and phone thinking some settings got switched but still nothing .
Old 02-24-2021, 11:21 AM   #1073
Jabphoenix
Member#: 522242
2020 2020 WRX - Blue
2019 Mustang Vert - GG
Originally Posted by Justduff View Post
They Sent me the wrong wiring harness but looks good in the car
That does look really nice
Jabphoenix is online now   Reply With Quote
