Welcome to the North American Subaru Impreza Owners Club Sunday March 7, 2021
Old 01-11-2021, 11:49 AM   #1
IDriveFords
Member#: 518804
Default Secondary Air Pump System
So this may be a silly/dumb question. I have blocked off the secondary air pump system and removed all the hardware related to it as the motor is out of the car and I figured this was the best time to do it. My stupid question is can you just block off the parts of the solenoid with the barometric pressure sensor and leave it mounted so you don't have to destroy a potentially very expensive part to get the sensor off? I only ask in case for whatever insane future reason myself or someone wants to put this system back on the car. It also looks like its a pain to cut that sensor out and would just be easier to block off what is no longer in use. I noticed in all the videos there are some wires that feed down to the solenoid they just rip out and cut off wasn't sure if that was absolutely necessary or not.
Thanks,
-Rob-
IDriveFords is offline   Reply With Quote
Old 01-11-2021, 12:17 PM   #2
Jedi03
Member#: 491095
2009 STi Blue
yup you can leave it...i did for a while too till i saw how easy it was to cut the portion needed out...
Jedi03 is offline   Reply With Quote
Old 01-11-2021, 12:25 PM   #3
IDriveFords
Member#: 518804
I guess a follow up would be ... will I need to pay $150 to Cobb to clear these codes or should I be able to just get a local tuner to clear them?
Old 01-13-2021, 03:58 AM   #4
SkylaneRG
Member#: 461781
2012 WRX Hatch
A local tuner should be able to give you map to kill the error codes associated with the air pumps. Was a pretty simple and quick process on my 2012 wrx.
SkylaneRG is offline   Reply With Quote
Old 01-13-2021, 09:54 AM   #5
K3rm1tth3fr0g
Member#: 508105
2002 WRX Wagon VF39
Midnight Black Pearl
Or you can buy access tuner and delete the codes yourself if you're tuned On an AP.
K3rm1tth3fr0g is offline   Reply With Quote
Old 01-14-2021, 12:36 PM   #6
87DMK
Member#: 521673
06 wrx
metallic grey
Default secondary air pump system
You can buy block off plates for cheap and take it to a tuner and have them turn it off in the ECU. Your check engine light will go away and you will be able to use cruise control again.
87DMK is offline   Reply With Quote
