Welcome to the North American Subaru Impreza Owners Club Monday March 8, 2021
Old 01-11-2021, 03:02 PM   #1
Ed Currant
Member#: 153187
2006 FXT
Default '06 Impreza Hatch w/ 2.5L & 4EAT: Console Shift Indicator Illumination
Are ALL positions of the "PRND321" Shift Indicator (P/N 35180FE080) in the center console normally illuminated when the Impreza's lights are switched on? Or only the PARTICULAR character indicating the CURRENT position of the shifter?
Following recent service work, a relative believes that the console shift indicator lighting has changed on their '06 Impreza. The console indicator presently only illuminates ALL of the "PRND321" characters when the headlights are on. The relative is a senior and finds it disconcerting to feel it is no longer possible be able to visually determine what SPECIFIC position is currently selected at the console.
The '06 model also has a vertical "PRND321" indicator on the left side of the instrument cluster. This DOES indicate current position, but it apparently is not the point of reference the owner is accustomed to referencing.
(This is a dupe of a thread attempt yesterday that went straight to moderation and has yet to emerge. The previous attempt included an embedded link for a photo of an '06 FXT's shift console - I presume that link is the reason the attempt was flagged ?)
Ed Currant is offline   Reply With Quote
Old 01-12-2021, 09:26 PM   #2
Ed Currant
Member#: 153187
2006 FXT
Would rephrasing the question help ... ?
Old 01-15-2021, 03:58 PM   #3
Ed Currant
Member#: 153187
2006 FXT
Well, all righty then.
Four days, 250+ views, no responses: I guess we'll just have to open things up to a broader base of contestants before declaring that this question has stumped the forum.
Shift Indicator P/N 35180FE080 is common to the following years, body styles and models.
Subaru Impreza (205) AT 4WD WRX Sedan 2005
Subaru Impreza (205) AT 4WD WRX Wagon 2005
Subaru Impreza 2.5L AT 4WD Outback Wagon 2005, 2006
Subaru Impreza 2.5L AT 4WD RS Sedan 2005
Subaru Impreza 2.5L AT 4WD RS Wagon 2005
Subaru Impreza 2.5L AT 4WD RSPRO Sedan 2005
Subaru Impreza 2.5L AT 4WD Sedan 2005, 2006
Subaru Impreza 2.5L AT 4WD Wagon 2005, 2006
Subaru Impreza 2.5L TURBO AT 4WD WRX Sedan 2005, 2006
Subaru Impreza 2.5L TURBO AT 4WD WRX Wagon 2005, 2006
Subaru WRX (205) AT 4WD SEDAN 2005
Subaru WRX (205) AT 4WD WAGON 2005
Subaru WRX 2.5L TURBO AT 4WD SEDAN 2005, 2006
Subaru WRX 2.5L TURBO AT 4WD WAGON 2005, 2006
If you drive one of the vehicles on the list, you possess the means to determine the answer to my question.
Old 01-22-2021, 11:59 PM   #4
1st impreza
Member#: 512601
i have an 07 impreza and the same thing happens the center console shifter lights up PRND321 but does not indicate which gear you are in only on the left side of the dash can i see what gear/position i am in
hope that helps
1st impreza is offline   Reply With Quote
Old 01-25-2021, 01:03 AM   #5
Ed Currant
Member#: 153187
2006 FXT
Thank you for posting, 1st impreza.
Much appreciated !
