#1 |
Member#: 521085
![]() I am going to a SD tune and need to have a bung welded on my TMIC.
How do they drill the hole without getting the aluminum in the IC? Would hate to leave a piece and it end up in my engine.. Has anyone done this?
#2 |
Member#: 47143
#3 |
Member#: 459692
South East
Vehicle:2019 WRX STI silica black |
![]() At one point I was going to install water meth injection on my STI but decided to go flex fuel instead. I had already purchased a Snow Performance injection plate that sandwiches between the throttle body and manifold. It has two 1/8" NPT ports, maybe your IAT sensor would fit if you purchased the plate?
#4 | |
Member#: 521085
![]() Quote:
#5 |
Member#: 459692
South East
![]() You'll need this IAT sensor:
https://www.maperformance.com/products/aem-1-8-npt-air-temp-sensor-kit-30-2014?variant=29435987755078&gclid=CjwKCAiAgJWABhAr EiwAmNVTB9FlXRoXWRcrfdRSP4bC7cD1HtpPL07Rsp_6TTrBBj Hvp0jSJoQo9BoCCWYQAvD_BwE |
#6 | |
Member#: 521085
![]() Quote:
But the IAT is 3/8 NPT. Can I just cut the male connector on the SD kit and put the AEM connector on and plug in? Last edited by savagesoob; 01-18-2021 at 11:34 PM. |
#7 |
Member#: 198281
Vehicle:2005 WRX/STi WRB of course |
![]() I would want to do some comparative feedback first. Your charge air temps are going to be different from I/C end tank-to-intake runner. Whether that's 10° and inconsequential, or 50° is anybody's guess. Tuners know what works with end tank temps, but I don't believe anyone has gone in this direction. Without proper testing, you're taking on that risk.
#8 | |
Member#: 521085
![]() Quote:
My mechanic with 15 yrs exp. working in Subarus told he would weld it on the IC. I thought the spacer would be a better place since its right on the throttle body. However, with the spacer it will be near impossible to get the coupler on bc the extra 3/4" protrusion. Plus need an extension for the MAP sensor. ![]() |
#9 |
Member#: 254317
Vehicle:2011 STi |
![]() Yep, I have mine IAT bung on the TMIC too but I am not using it at the moment
#10 |
Member#: 521085
#11 |
Member#: 198281
