Welcome to the North American Subaru Impreza Owners Club Monday March 8, 2021
Old 01-17-2021, 12:12 AM   #1
mgrotel
Member#: 211590
Default Neutral position switch swap gotta drop trans, wtf
04 sti six speed in a 06 wrx. Trying to change out switch. I gotta drop the damn trans?
mgrotel is offline   Reply With Quote
Old 01-17-2021, 09:29 AM   #2
AceKingNYC
Member#: 406087
06 VF48 Wagon
You don't have to completely drop the trans BUT it's a PITA. I used a series of extensions and a set of crows foot.
Removed the drive shaft, unbolted the crossmember, jacked up the motor to tilt the trans back.
It's doable.
here's the guide I used: https://howtune.com/articles/559-rep...za-wrx-sti-6mt
AceKingNYC is offline   Reply With Quote
Old 01-18-2021, 03:41 AM   #3
mgrotel
Member#: 211590
Thanks for that link. What a pain in the ass, and even have the motor out. Might say forget it and just deal with cruise control not working.
Old 01-19-2021, 11:08 PM   #4
AceKingNYC
Member#: 406087
06 VF48 Wagon
I hear you, unfortunately I had to do it - when i swapped in my jdm sti trans i accidentally swapped the placement for the NSS and the Reverse sensor. Not fun, but wasn't the worst thing, just need lots of patience and if you have smaller hands it will help reach
Old 01-19-2021, 11:46 PM   #5
NewSilverWRX
Member#: 58485
2004 RASC.207 WRX 5M
Do you have an openport and do you just need to flip flop the switch? If so, I think this can be done in the ecu. This comes up with 207 swaps. It can be a pain to find it but if someone has found it already itseasier. Romraider forums will have that info. Am I missing something?
NewSilverWRX is offline   Reply With Quote
Old 01-20-2021, 05:14 PM   #6
mgrotel
Member#: 211590
I believe there was a mid year change one year with the switch. It went from ground actuated to signal actuated or something like that. I think I read about it on iwires website. Not sure if it can be tuned out, that would be ideal if so. Cruise control would be nice but Im not wresting with it and cutting up my arms to do it.
Old 01-25-2021, 02:47 PM   #7
mgrotel
Member#: 211590
I quit being a wus and just went ahead and did it. It wasn't as bad as I was making it sound. Did a little more research and iwire has a good writeup on it. In 2006 the switch changed from normally closed to normally open, or maybe I got that backwards. Anyway, I got the meter out and tested resistance and turned out the old one was faulty. Took about 2 or so hours of actual work time. I spent a lot of time taking breaks and watching football. One of the downsides to having a tv in the shop is....squirrel!
Old 01-29-2021, 08:14 AM   #8
AceKingNYC
Member#: 406087
06 VF48 Wagon
Glad you got it done. It's just a pain to swap, but it's not really hard. I took plenty of small breaks when i got frustrated but i resolved it all
Old 02-02-2021, 02:35 AM   #9
mgrotel
Member#: 211590
Excellent!
