Exhaust: Video and Sound Clips.
JDM and EUR Spec Bonanza!
Compendium of big/rotated turbo kits
Compression Ratios and Heads (STI, Spec C, etc)
Rough idle on 04 Turbo motors (2.5L) TSB
Everything you need to know about boost creep
STi ECM update released (ping fix)
Cast or Forged Pistons?
Great AVCS explanation!
How To: DIY TGV Deletes
Direct dyno comparison of Stock/Ported/Aftermarket turbo manifolds and headers (discussion thread here)
DuckStu Parallel Fuel rail tutorial
UNofficial Bolt sizes
If you have a MISFIRE code, please read this FIRST
EVAP Purge control solenoid routing and info
If you find a thread that you feel should be added to the threads of note, please click the "report bad post" icon (
