#1 |
Member#: 55854
Vehicle:2004 STi Blue/silver |
![]() Please post your dyno sheets along with the corresponding mods. Please do not turn this into a conversation thread as I'd like it to be a place to quickly look for dyno sheets without having to wade through 300 random posts per 1 dyno plot. Thanks all...
#2 |
Member#: 31624
Vehicle:02 WRX White uppipe, turbo-back, MBC |
![]() Do it. Gather all the info and post it here.
#3 |
Member#: 55854
![]() Or... everyone could post their own.
#4 |
Member#: 77525
Vehicle:'02 GDA, '09 GR '93 FD |
![]() At FIS last friday.
Cobb catted dp, Borla Hush cat-back, AP Stg2 map 1.20 93 octane. ![]() |
#5 |
Member#: 23071
TXIC
Vehicle:2003 WRX WRB |
![]() ![]() Facility: FIS - http://www.fi-systems.com Type of Dyno: Mustang Baseline # for a stocker at the dyno: around 170 Boost: 14.5 Fuel: 93 Octane Target AFR: Unknown SAE Corrections: Unknown Peak HP at RPM: 243.3 @ 6000 Peak Torque at RPM: 240.0 @ 3750 Mods: Helix up/downpipe, Cobb catback, Unichip, TXS MBC @ 14.5psi, K&N drop-in filter, GP Moto intake elbow Last edited by DrKicker; 01-18-2005 at 02:05 PM. |
#6 |
Member#: 71542
Vehicle:2013 WRB BRZ |
![]() EDIT: Comments deleted...
DYNOS ONLY Last edited by SilverSurfer04STi; 01-17-2005 at 11:21 PM. Reason: DELETE |
#7 |
Member#: 55854
![]() Yep. Dyno only and no commentary other than setup was my idea.
#8 |
Member#: 51537
Vehicle:2004 WRB WRX STI 62 Corvette/11 Cherokee L |
![]() How about a format, so that even if the image gets deleted it will be useful. like for instance:
Facility: Type of Dyno: Baseline # for a stocker at the dyno: Boost: Fuel: Target AFR: SAE Corrections: Peak HP at RPM: Peak Torque at RPM: Mods: |
#9 |
Member#: 58647
Vehicle:02 Exedy Carbon clutches SLIP and SUCK $! |
![]() What the hell might as well throw one of mine up here
![]() Mods include- 02' Spec-C Swap APS Pod, 3" Twin Tip Cat Back QuickTime Header, D/P with QTEC Turbo-XS FMIC Modded Injectors UTEC FP Green Junior Tune ![]() VP16 ![]() Thought I should ad my pump gas sheet too ![]() Sunoco 93 ![]() Last edited by 2002WRXSTi; 01-20-2005 at 10:16 PM. Reason: adding dyno chart |
#10 |
Member#: 43986
Vehicle:2002 WRX wagon RIP 2003 330ci black/tan |
![]() ![]() VF30 turbo STi intercooler STi injectors KTR Ecutek reflash Walbro fuel pump PDE uppipe Bosal downpipe Maddad 3rd Cat Eliminator Borla Hush Perrin short ram Samco IC hoses GFB pulleys port-matched stock header The runs were taken right after a Vishnu 3k rpm reset, hence the differences between the three runs. The ECU was freaked out by running toluene and not resetting after switching back to 93. |
#11 |
Member#: 63605
SWIC
Vehicle:04 Wrx Wgn TimeAtk 10 Golf TDI, 08 Stang GT |
![]() Dyno Comp
dyno dynamics dyno stock rex's put down around 150 91 octane Mods: perrin short ram injen up/dp hks cf/ti exhaust aps bov ecutek ![]() ![]() Last edited by WgnWheel; 01-18-2005 at 12:23 AM. |
#12 |
Member#: 49437
Vehicle:04 wrb STI PE1820 turbo [email protected] |
![]() ![]() ![]() Last edited by bgbyztoy; 03-05-2005 at 02:21 AM. |
#13 |
Member#: 55854
![]() bump.
#14 |
Member#: 66694
Vehicle:2005 WRX STi WR Blue |
![]() Car: 05 USDM STi - about 5K miles at time of tune
Facility: TurboTrix (tuned by Shiv) Type of Dyno: Dynojet Baseline # for a stocker at the dyno: 240-250/240-250 awhp/awtq Boost: peak around 19, taper to 14 Fuel: 93 octane Target AFR: looks to be around 11.1 Peak HP at RPM: 290awhp at ~5500 Peak Torque at RPM: 315awtq at ~3700 Mods: Vishnu TBE + Ecutek reflash, nuttin else Other notes: blue lines are with TBE only before reflash ![]() Last edited by joshd; 12-26-2005 at 02:43 AM. Reason: Add car info |
#15 |
Member#: 55854
![]() Awsome folks. Great start so for.
Please be sure to list your car year and model (and engine size if it isn't stock for the car) as well. Especially if you don't have it listed in your profile or in case you buy a new car and change your profile. |
#16 |
Member#: 40638
Vehicle:'04 PSM STi Has some work done... ;) |
![]() Car: USDM 2004 STi with 7,000 miles
Facility: KTR Performance Type of Dyno: Dyno Dynamics Baseline # for a stocker at the dyno: 220-230whp/wtq (STi that is) Boost: 22psi tapers to 17psi at redline Fuel: 93 oct. Target AFR: 11:5 SAE Corrections: None (Within dyno room all air pressure, humidity and air temperature are put in each run to avoid correction) Peak HP at RPM: 337.9whp @ 5,500rpm Peak Torque at RPM: 345wtq @ 4,900rpm Mods: Deadbolt SuperZilla SZ49 turbo ECUTek KTR Dyno Tuned TurboXS Turboback Catless Exhaust w/RFL-Ti Muffler Power Enterprise 850cc STi Injectors Perrin Big MAF w/intake Perrin Lightweight Crank Pulley Perrin Front Mount Intercooler GT Spec Header w/ Uppipe Tial 44mm External Wastegate w/dump to atmosphere Walbro GSS342 Fuel Pump Blitz SBC i-d III Boost Controller ![]() Rick |
#17 |
Member#: 50315
Vehicle:0806 LGTspecB & Saab 9-2xAero5MT DGM & MBP |
![]() ![]() mods: vf22 utec txs tbe txs v1 tmic joe-p mbc modded stock injectors walbro pump "not the greatest" plugs tuned by junior @ 20psi max hp: 279 max tq: 268 since the dyno tune: apexi avc-r avo turbo inlet hose wastegate helper spring (now holds 18psi @ redline whereas before it tapered to 15ish) ngk one step colder copper plugs (bkr-7e) im thinking about losing the stock intake. anybody have before/after results when adding an aftermarket intake to a stg 4 wrx? -ed |
#18 |
Member#: 437
Vehicle:'91 Miata MX5 (Red) '09 Impreza OBS (Blk/Gry) |
![]() Thread stuck, title changed.
Paul G. |
#19 |
Member#: 33410
Vehicle:08 wrx dgm |
![]() Facility: turbotrix edison,nj
Type of Dyno: dynojet Baseline # for a stocker at the dyno: 170-180? Boost: 18.5 down to 16 at redline Fuel: 93 Target AFR: rich LOL SAE Corrections: ??? Peak HP at RPM: 284 @ 6400 Peak Torque at RPM: [email protected] Mods: P&P vf34, hyperflow tmic, STi pinks, 3'' turboxs exhaust+stromung muffler, fuel pump, wrapped uppipe, ported exhaust manifold, perrin turbo inlet. ECUtek tuned by Shiv ![]() |
#20 |
Member#: 8343
Vehicle:2005 2012 Jeep 2013 DGM BRZ |
![]() Facility: GRD Performance
Type of Dyno: Dynapack Baseline # for a stocker at the dyno: 170 Boost: 17psi peak. Made [email protected] Fuel: ~98 octane Target AFR: 11.2:1 Peak HP at RPM: [email protected] Peak Torque at RPM: [email protected]? or thereabouts Mods: EJ257 block,V8 RA heads with V7 cams, PE1818 turbo, TXS turboback with Prodrive muffler, PE650 injectors, APS fuel rails, APS DR500 FMIC, Perrin short ram. TGV deletes, Borla header. (Lower runs are without the Borla header). Blitza DSBC-R. Remapped V8 RA ECU w/AVCS tuned by Trey Cobb. Best 1/4 mile was a [email protected] Ran [email protected] at 8psi. ![]() Last edited by dwx; 01-21-2005 at 12:01 AM. |
#21 |
Member#: 9794
TXIC
Vehicle:02 2.5LWRX-Retired 335i w/twins |
![]() TXS STG2 (TXS basemap Unichip, TXS DP, greddy EVO catback, stock uppipe) 228whp/235wtq
#22 |
Member#: 41522
RMIC
Vehicle:2008 Legacy 2.5 GT Satin White Pearl |
![]() 2002 Subaru Legacy L
![]() Custom cat-back stainless steel 2 and 1/2 inch exhaust with muffler, K&N air filter. Stock more or less. |
#23 |
Member#: 68022
Vehicle:04 Forester XT |
![]() 04 Forester XT
Facility:FourStar Motorsports (Ecutek tuned by Mick Kehl) Type of Dyno: DynoDynamics Baseline # for a stocker at the dyno:215whp STI Boost:1.2bar Fuel:93 Target AFR:unknown SAE Corrections:none Peak HP at RPM:233whp @ 4900rpm Peak Torque at RPM:267wft/lbs @ 3650 Mods:Ecutek, VF30, Ultimate-Racing catless uppipe, Bosal downpipe, stock third cat, Tanabe Hyper Medallion 3" catback, WRX ic and bov, K&N panelfilter, Samco Y pipe, Walbro 255L pump, stock injectors, stock spark plugs ![]() ![]() |
#24 |
Member#: 20354
SCIC
Vehicle:2005 SRT-4 POS Mopar stage 2 |
![]() Facility: Tuning Technologies
Type of Dyno: DynoJet Baseline # for a stocker at the dyno: *unknown* Boost: peaked @ 16psi Fuel: 91 octane (76 brand) Target AFR: Whatever COBB claims....then look at my AFR SAE Corrections: STD Peak HP at RPM: ~215 @ 6,000 rpm Peak Torque at RPM: ~226 @ 4,400 rpm Mods: Helix uppipe, Helix catless downpipe, Borla XR-1 catback, Cobb Stage 2 Cali 91 octane map. ![]() |
#25 |
Member#: 31506
Vehicle:05 Tacoma on TE37' White |
![]() Facility: Brainstorm
Type of Dyno: DTS Dyno Baseline # for a stocker at the dyno: Unknown - Around 165/170 whp Boost: 15.5 psi Fuel: 91 Octane (76 gas) Target AFR: Unknown SAE Corrections: Unknown Peak HP at RPM: 221 WHP Peak Torque at RPM: 195 WTQ Mods: HKS Uppipe, HKS Downpipe, 3" COBB Cat-Back, Blitz SBC-ID (road-tuned by myself) Note: Car pinged alittle because it was too hot that day, so it pulled timing on one of the runs. ![]() |
Post your OLD ride and your NEW ride. | MF-DIF | Member's Car Gallery | 1291 | 03-03-2016 12:43 AM |
Post your dyno results from today. (Mach V) | banzai | Mid Atlantic Impreza Club -- MAIC | 70 | 03-28-2006 11:08 PM |
hey baic folks, post your dyno results | LEOSPEED | Bay Area Impreza Club Forum -- BAIC | 16 | 11-25-2003 03:22 AM |
Utec dyno plots and target A/F ratios and some tuning advice. | nmyeti | Engine Management & Tuning | 39 | 10-15-2002 03:29 AM |
Post your dyno results here! | Darryl | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 0 | 11-10-2001 06:40 PM |
