#26 |
Member#: 260314
NESIC
Vehicle:2007 STI silver gray metallic |
![]() I'm in the weeds with this Fozzy and its "Plastic Fantastic" manifold. I want to make a little over 300 HP with 2014 WRX turbo/intercooler parts. I have ported W25 heads and a built SB.
I have stripped out all the emissions crap and am dieting the harness. I recently realized that the MAP is not on the throttle body! This thread seems to address many of my concerns but a new one has popped up. Some of the three and four bar MAP's (sometimes with adapters, like the Cobb) can be expensive. I don't see the point in paying $200 for a simple pressure transducer and adapter. It doesn't seem like rocket science and I can fab about anything to adapt a sensor (pressure transducer). If I'm going to get the Fozzy tuned, is there any reason not to buy almost any three or four BAR sensor? Any recommendations or issues? Why would this not work? Or, even this, for $15!
#27 |
Member#: 108051
Vehicle:2005 TickingTimeBomb Jr tuned TT Sleeved |
![]() You absolutely need to filter the line pre sensor. My buddy had same issue. Added a filter and signal smoothed out. The lgt has a filter from factory as it's sensor is external. The sti has a jammed airway to sensor so it's filtered inside the throttle body channel itself. So grab a lgt map sensor filter from dealership or someplace.
Rocket science simplified! Your welcome! Also wanted to add a hard line would be a good idea along with filter as the sensor is a dead end. And it can swell a silicone hose that's really only meant for vacuum under boost. The map sensor has no bleed off hole. Suppose one would help. Can run it in loop so it's not a vacuum leak also.. like tial should do with there bov and waste gate cough cough. The only boost leak I haven't been able to fix just yet! Lol. Last edited by spoolinsti05; 12-22-2020 at 06:03 PM. |
#28 |
Member#: 15822
Vehicle:1999 WRB GM6 2.34 LR destroker |
![]() GM map sensors is what we have used on plenty of rally/time attack cars here with good results
I'd never put on on my street car though because of my OCD ![]() |
#29 |
Member#: 352704
VIC
Vehicle:1965 Vw panel bus with an EJ20 Turbo Swap |
#30 |
Member#: 108051
#31 |
Member#: 352704
VIC
Where is the best place to get an Up Pipe installed in East TN? | tblackgt350 | South East Region Forum | 8 | 01-06-2007 12:16 AM |
[EGT,OIL]Where is the best place to install the sensors to my gauges in the engine? | west | Interior & Exterior Modification | 2 | 05-06-2005 10:04 PM |
Where is the best place to get STI pillow mounts. | Rallyspec | North West Impreza Club Forum -- NWIC | 3 | 11-06-2001 04:46 AM |
where is the best place to buy agj sway bar and solid mounts? | wop | Brakes, Steering & Suspension | 8 | 06-27-2001 12:57 PM |
Where is the best place to buy an Impreza? | Racer X | Mid West Subaru Owners Club Forum -- MWSOC | 6 | 09-30-2000 08:56 PM |
