Welcome to the North American Subaru Impreza Owners Club Saturday March 6, 2021
Old 12-21-2020, 11:20 PM   #51
Homemade WRX
Member#: 33782
96 3MI Racing
search FIRST, then PM!!!
Originally Posted by Kyjellaye View Post
Hey I've been looking through the forums and it seems like you are very knowledgeable about the build I am thinking of doing and you're local which is even more dope! I'm thinking of doing a 22t but bored and sleeved to a 2.5 and run 255 heads as I already have a set. But my whole dilemma is what internals to run. I was just thinking about keeping the 22t crank to make it more simple but any feedback would greatly help. Also if you know any good machine shops around the area that would be comfortable in this. Thank you!
If you keep the EJ22 crank, it is set up for the #3 thrust bearing. I'd suggest going to the newer 75mm crank with #5 thrust bearing. So you'll need to machine the block for it. But the new crank also has improved oiling.
From there you're essentially making what we commonly call a destroker; 75mm stroke in an EJ25 block. They like to rev and just think of them as a big bore EJ207.
Honestly, for the headache and expense, I'd just run a closed deck EJ255/257 block.
Old 12-22-2020, 12:20 AM   #52
HOK
Member#: 447
1999 RSTI
Honestly, I wanted to do an EJ22T stroker too but I just went and bought a full long block from IAG close decked... my EJ22T is just sitting in my basement gathering dust... I think I went the right route... engine to engine it may not have been cheaper but I saved a lot of headaches and time with peripherals, tuning ease and which is all also money...
HOK is offline   Reply With Quote
Old 12-22-2020, 01:27 AM   #53
Kyjellaye
Member#: 521108
2002 Wrx
Alright thanks for clearing that up! Just trying to use some parts I have to replace my tired 205.
Kyjellaye is offline   Reply With Quote
2004 WRX sedan, speaker upgrade question wolfcri Car Audio, Video & Security 6 06-05-2010 12:34 PM
STi swap wiring question BMXspears Subaru Conversions 7 06-04-2010 03:32 PM
2.2liter stroker question... tmeultraman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 06-26-2008 12:45 AM
2.2L Stroker Questions slvrsplr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 04-27-2008 06:30 PM
Stroker questions Turbo_Mike Built Motor Discussion 26 02-22-2008 01:05 AM
