Welcome to the North American Subaru Impreza Owners Club Tuesday March 2, 2021
Old 09-03-2010, 12:04 PM   #1
stoke
Member#: 164513
2001 2.5RS+EJ20+VF34
'13 WRX Special Ed
Default 01 RS trans/06 WRX clutch resisting shifts under load
I have a 2001 RS with a 2004 WRX EJ205, running the stock gearbox with 150K on it. When I did the swap I put in a brand new 2006 WRX clutch and Exedy lightweight flywheel (also push-type). I also installed a new RS throwout bearing and clutch lever arm. For reference I run Motul 8100 Xcess in the transmission and use the STI 5MT short shift kit.
When I'm driving calmly, the transmission has been fine. It shifts smoothly and the clutch works normally. However, when I push the car a little bit, and try to make quicker shifts at higher engine speeds under greater load, the car doesn't want to go into gear. It doesn't grind or anything, I just can't push it into gear until the revs drop almost to idle. On rare occasions, if I let off the gas sharply and push the clutch in at just the right moment and the revs drop about 1k immediately instead of blipping slightly, I can get it to slot in-- almost like I've rev-matched on an upshift.
This leads me to believe the clutch isn't disengaging properly, possibly because of the fact that I'm using the RS throwout bearing and shift lever with an 06 WRX clutch and flywheel combo. Do any gearbox gurus know if the 06 WRX throwout bearing and shift lever are different from the 01 RS parts, and if using this combination can result in the symptoms above? Can I swap over to the 06 WRX parts and correct my shift maladies?
stoke is offline   Reply With Quote
Old 09-10-2010, 09:56 AM   #2
stoke
Member#: 164513
'13 WRX Special Ed
Has anyone else experienced this issue?
Old 01-03-2021, 02:07 PM   #3
jeff6666p
Member#: 400078
1998 2.5rs06wrx swap
black
You figure it out?
jeff6666p is offline   Reply With Quote
Old 01-03-2021, 02:48 PM   #4
snow_bound26
Member#: 395793
2005 92x Aero
Beige
Doubt you'll get an answer. This has been dead for 10 years
snow_bound26 is offline   Reply With Quote
04 Wrx Longblock 20k And 01 Rs Trans jcbluescooby Engine/Power/Exhaust 29 05-02-2008 10:43 AM
ej20 + 01 RS trans= what clutch flywheel? GripGC8 Subaru Conversions 8 02-27-2007 09:05 PM
01RS struts, 01 RS trans!, 94 impreza L doors!, MKE scobaru MWSOC Private Classifieds 2 01-21-2006 03:46 AM
01 RS trans FS scobaru Private 'For Sale' Classifieds 7 11-13-2005 10:02 PM
01 RS trans FS scobaru Mid West Subaru Owners Club Forum -- MWSOC 0 11-13-2005 05:40 PM
