Welcome to the North American Subaru Impreza Owners Club Sunday March 7, 2021
Old 01-19-2011, 11:47 PM   #1
subie814
Member#: 212018
Default Overheating in stop/go traffic
Hi everyone,
I recently experience the temperature gauge increase in stop/go traffic but my oil temp gauge was still reading normal. I am thinking thermo stat but looking for other ppls opinion on this situation. I replaced the radiator a year ago to the mishimoto aluminum radiator and silicone hoses but didnt replace the thermo stat. Also once i start driving consistently the temperature drops again. Is there any other possible reasons that could cause this?
subie814 is offline   Reply With Quote
Old 01-20-2011, 01:12 AM   #2
Dzordanpl
Member#: 137563
Originally Posted by subie814 View Post
Hi everyone,
Try checking your radiator fans and fan relays for the begining. Usually they cause your car to overheat in traffic.
Thermostat will cause your car to overheat constatnly, it might be good idea to check that second.
GL
Dzordanpl is offline   Reply With Quote
Old 01-20-2011, 01:17 AM   #3
Seventh
Member#: 263223
2011 WRX 5dr
SWP, 332ti
Pressure test to be 100% sure there's no leak. Test fan/relay operation. (power probe FTW) I ALWAYS recommend t-stat with an overheating complaint, it's cheap, easy to do and great insurance. Fans are my guess tho.
Seventh is offline   Reply With Quote
Old 01-20-2011, 08:46 PM   #4
Torquey
Member#: 175334
2003 Impreza WRX
JDM v8 EJ207 WRB
Pretty sure it's air in the cooling system, that you'll need to burp out. Here's a similar thread:
http://forums.nasioc.com/forums/show....php?t=2061807
Torquey is offline   Reply With Quote
Old 04-28-2011, 03:55 PM   #5
white guys wrx
Member#: 223316
2005 STi
& 02 WRX
remove your radiator caps turn the car on till completely hot tighten the caps do a few times... if problem is not solved swap out your thermostat with a SUBARU THERMO nothing else they are $4
white guys wrx is offline   Reply With Quote
Old 04-29-2011, 07:15 PM   #6
Krazox
Member#: 236278
2013 WRX
I ran into this problem once before and was exactly like yours. Check your radiator fan fuses. Both of mine blew and all I had to do was replace them. Definitely worth checking something as small as fuses before you go onto larger things!
Krazox is offline   Reply With Quote
Old 05-08-2011, 03:49 PM   #7
sackytar
Member#: 149262
03WR rallycarFXTleg
PrimerGrey
Or sometimes the pigtails gets disconnected. Very easy to do.
sackytar is offline   Reply With Quote
Old 12-19-2016, 03:00 AM   #8
khang768
Member#: 459836
2006 Subaru Impreza
Default Subara Impreza 2005 model high temp when in traffic
My too.When I got stuck in traffic jam, say 30 minute no moving, I see the temp gauge raise to about 3/4. when out of jam, it went to normal. Any advise will be appreciated.
khang768 is offline   Reply With Quote
Old 12-19-2016, 03:46 PM   #9
mrsaturn7085
Member#: 375462
2006 Impreza WRX STI
WR Blue
Check that your fans are working as they should.
Sitting still, the only thing you are missing is airflow across the radiator. The fans should be taking care of this - since your ECT is rising (you are NOT technically overheating yet), I suspect your fans are either not working at all, or not working in high-speed mode.
Since the temp. goes back down when you get moving, the issue should NOT be the headgasket, air in the system, or other similar issues - this is clearly an airflow issue.
mrsaturn7085 is offline   Reply With Quote
Old 12-24-2020, 01:56 AM   #10
athornton
Member#: 521174
Default Similar Problem but temp comes down when I increase RPM
I have a similar problem with my 02 wrx. When I come to a stop sometimes the temp starts to creep up to the 2/3rds line and doesn't go above that but if I rev my engine the temp drops back down. If I keep sitting their the temp will go back up again and once I start moving the car goes back to operating temp. I have replaced the thermostat, the radiator, and burped the system. Sometimes I hear a gurgling noise in the dash area and so I think air is getting in but I don't know how it is.
Any help would be greatly appreciated.
athornton is offline   Reply With Quote
Old 12-24-2020, 07:08 AM   #11
snow_bound26
Member#: 395793
2005 92x Aero
Beige
Have you replaced all your coolant hoses as well? At that age they need it.
How did you bleed the system? Did you accidentally switch the upper res cap with the radiator cap? Do you remove the heater cores hoses and accidentally hook them up backward? My first thought is thermostat and there is a chance your new one is faulty. But the above mentioned can cause what you describe as well especially if the system wasn't bled properly.
snow_bound26 is offline   Reply With Quote
Old 01-04-2021, 03:12 PM   #12
WRXRgr
Member#: 54942
2004 WRX
Overheating in low-airflow conditions can indicate a worn impeller in water pump, also.
WRXRgr is offline   Reply With Quote
Help? High idle in stop and go traffic infinite012 Mid Atlantic Impreza Club -- MAIC 35 06-08-2014 08:42 AM
Idle jumps to 2000 in stop and go traffic... Synx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 32 10-19-2009 04:25 PM
Idle jumping high in stop n go traffic ReDHaTyGuY Newbies & FAQs 11 06-05-2009 10:45 AM
shift fork gets loose when car is in stop and go traffic? rougeben83 Transmission (AT/MT) & Driveline 3 06-02-2009 01:21 PM
How do you drive in stop and go traffic? Ken Off-Topic 49 09-26-2007 02:56 PM
