#29201 |
Member#: 421858
Vehicle:2012 Impreza |
![]() That's better. It's also a typical Johnson controls hit or miss battery. People hate exide but I hear about a lot fewer issues with those than JCI. I don't know of any other brand that leaks so much either.
That's what warranties are for. Hit or miss crap.
#29202 | |
Member#: 314216
Vehicle:2012 2.0i Sport 5MT DGM |
![]() Quote:
850CCA @ 0F http://shop.odysseybattery.com/p/35-pc1400t |
#29203 |
Member#: 421858
![]() Better last 4 years being $300 and weighing 50 lbs.
#29204 |
Member#: 340297
Vehicle:2013 Impreza 5sp Prm Ice Silver |
#29205 | |
Member#: 319157
Vehicle:2012 Impreza 4DR 5MT |
![]() Quote:
I'd bet far more batteries die because of abuse than manufacturing or design defects. It's good to be covered in either case. |
#29206 |
Member#: 89967
NESIC
Vehicle:2012 Impreza Sport DGM |
![]() ![]() Managed to epoxy the piece the was bent in, fairly happy with the result. Could have been a little cleaner but better than a hole! |
#29207 |
Member#: 314216
#29208 |
Member#: 421858
![]() It wouldn't matter if it was in the back, but adding a single pound to the front of the car, especially over/in front of the front wheels is just making the car that much more unbalanced.
#29209 |
Member#: 314216
#29210 | |
Member#: 319157
![]() Quote:
#29211 |
Member#: 421858
![]() CVT weighs maybe a few pounds more... think about it. It's 2 drums and a belt vs an entire set of gears.
#29212 |
Member#: 319157
![]() Fortunately, I don't have to think about it thanks to the service manual.
CVT is 66lbs heavier in total, but it's actually lighter in the rear than the 5MT. Front/Rear distribution: CVT: 59.6 / 40.4 5MT: 58.3 / 41.7 |
#29213 |
Member#: 421858
![]() Must be mostly fluid weight. I can't imagine the cvt weighing that much more unless it's also armored to be used on military mine sweepers. It's just not that big. Have you seen that video of the see-through lineartronic cvt? Not that big.
#29214 |
Member#: 340297
![]() There's also the torque converter, and the clutch pack for the center diff that's not actually a diff, so that could account for some of it.
#29215 |
Member#: 421858
#29216 |
Member#: 340297
![]() Yeah, clutches are very light though. Not sure about the center diff, but my assumption is the automated assembly for the clutch pack is probably heavier than a viscous center diff, by assumption. Who knows where the weight really comes from, the large conical gear pair?
#29217 |
Member#: 421858
![]() Sooooo... If I wanted to get coilovers some day, but couldn't find an option I like that didn't drop the car a ton, would I be able to use those HDPE spacers on top of the coilovers to lead to minimal drop/rise?
#29218 |
Member#: 340297
#29219 |
Member#: 421858
![]() Really? Seems like 99.999999% of people either want their car raised or dropped. I don't want a raise because that would turn it into crosstrek-like handling, and I don't want a drop because steep hills, potholes, etc.
#29220 |
Member#: 421858
![]() Oh and keen, I feel the need to mention that, while the amp is only rated at 50w/channel at a minimum @ 4 ohms, it was rated well over 300w on its birth sheet. All R-F amps come with one. IIRC it was 350+ which would make it nearly 60w at least. Not that it really matters. I just needed to correct that.
#29221 |
Member#: 301179
BAIC
Vehicle:2013 WRX Limited SWP |
![]() Yes, depending on the coilover. AFAIK, most coilovers give a 0.5"~1" drop from stock height, even at the highest configuration. So in theory, getting a spacer on the tophat will allow you to remain at stock height, even with coilovers.
#29222 |
Member#: 319990
TXIC
Vehicle:2012 Imp Prm 5D CVT Dark Grey Metallic |
![]() I've been absent from these forums for quite some time, but I thought it was time to lurk about and chime in now that I've had my 2012 for just about 5 years.
Still pretty low mileage at just under 45k Miles. All is running great! Replaced the OEM tires with some Pirelli Cinturato P7 All Season Plus tires a few months ago as well as the OEM battery. Since the Free Oil Changes have ended I have done my own as well as replaced the Diff. Fluid front and rear. Thanks To all who have shared I continue to gain a wealth of information and tips from this site. |
#29223 | ||
Member#: 421858
![]() Quote:
#29224 | |
Member#: 301179
BAIC
![]() Quote:
Sounds like you just want a stiffer/sportier ride? If I were you just get some RCE Yellows... Well... That's what i'm planning to get soon. ![]() |
#29225 |
Member#: 301179
BAIC
![]() Last edited by theoutbackdream; 05-06-2017 at 05:37 PM. Reason: 40, not 30. |
Possibly looking into a 2011 or 2012 Impreza? | xenonk | Mid Atlantic Impreza Club -- MAIC | 2 | 03-08-2020 06:34 PM |
2012 Impreza STI concept art | khaki_man | Member's Car Gallery | 37 | 03-15-2011 03:02 AM |
Newsflash: 2012 Impreza looks like BigElm's Butt | WagonMonster | Off-Topic | 4 | 02-28-2011 08:11 PM |
2012 Impreza Concept | Zakster87 | General Community | 14 | 11-17-2010 05:09 PM |
