#26 | |
Member#: 159743
Vehicle:07 STI Limited TurboMike Tuned 2.35 |
![]() Quote:
The Mahle Bearings actually aren't the same... Ive been looking at an alternative bearing as well because i don't have time to swap bearings 5 times to get it right with ACL... the Mahle bearings have the tab to keep from spinning BUT its not a stamp out.. Meaning that the bearing surface is consistent the whole way around. At least on the rod bearings from what ive seen. Might not mean much but im gonna do that with Cosworth Mains as long as i can :-p for your viewing pleasure. Adam at nolimit hooked me up with the links. http://gruppe-s.blogspot.com/2010/07...ver-mahle.html
#27 |
Member#: 14116
![]() The Mahle VC1014 rod bearings were previously Vandervell bearings. The best you can get! If you can get them...
#28 |
Member#: 159243
Vehicle:5/01 bugeye Hakt Ecu is back! |
![]() Last edited by maxpowr; 11-11-2011 at 06:24 PM. |
#29 | |
Member#: 84105
SCIC
Vehicle:2005 Super Slow STi CGM |
![]() Quote:
#30 |
Member#: 121532
SCIC
Vehicle:06 FXSTi, 06 FXTAT 06 STi Wide Body Wagon |
#31 |
Member#: 84105
SCIC
![]() That and the huge shortage in Socal of ACL bearings for Subies was because Cosworth got the last stock from every distributor in Socal when ACL started their backorder from the factories.
#32 |
Member#: 159243
![]() maybe acl/cosworths quality control is not what it needs to be right now. im looking into other options.
my machinist has access to king (israel?), but i will call mahle on monday and get he scoop. call me silly, but i prefer to buy american, when i can. Last edited by maxpowr; 11-12-2011 at 01:26 PM. |
#33 |
Member#: 217563
South East
Vehicle:2006 Sti 12.68 @ 108 321WHP 422WTQ dynojet SAE |
![]() I'm curious to how the factory bearings compare to the aftermarket choices? I know oem is more expensive but is there any other disadvantages than that?
#34 |
Member#: 21392
Vehicle:2016 C63S AMG MB Iridium /MB C300 4MATIC |
![]() subscribed
#35 |
Member#: 159243
![]() well from what i found, you have to buy a whole set at like 150$ oem. there are 4 different sizes available i believe. personally i feel subaru spent enough on R&D to know what they are doing. i prefer oem to aftermarket when i can.
#36 |
Member#: 159743
![]() Being made by ACL and being checked by cosworth are two totally different things. The Main sets that i have here from ACL take hours to spec properly in the same manner that is described here. The Cosworth Mains i have are genearlly within the .0002 that Team Scream & I accept as usable variance. |
#37 | |
Member#: 131945
Vehicle:2013 BRZ Gunmetal |
![]() Quote:
They are made in UK by Vandervell to WRC specification (which is says right on the packaging). While talking to my rep at Mahle motorsports about them I was assured they are manufactured with the highest quality and specs possible. No short cuts taken to save cost what so ever (which is what is causing the main bearing delay). The rod bearings are about $120 for a set. ![]() |
#38 |
Member#: 131945
![]() Oh btw STD size ACL rod bearings just came back in stock so we are good to go on ACL bearings now as well
#39 |
Member#: 84105
SCIC
![]() Hot damn, 120 for a set of rod bearings. They better be perfect for that much!
#40 |
Member#: 56345
Vehicle:1997 OBS Primer Grey |
![]() I've tried two sets of these Mahle Motorsport rod bearings and both were consistent in size for vertical oil clearance and both sets exhibited severe side pinch at the parting line on a set of H beam rods that did not experience any pinch with ACLs.
I was told the main bearing delay was from tooling as the Vandervel (sp?) plant was not tooled up for any flanged bearings. |
#41 | |
Member#: 131945
![]() Quote:
Come spring they are coming out with a new process for the Subaru mains that will bring cost down. |
#42 |
Member#: 133146
Vehicle:07 FPgreen [email protected] WRX VF39+E85 12.0, 121mph |
![]() I am about to order the parts for my build and I am planning on getting standard main ACLs and .001 oversized kings for the rods. Any recommendations? Maybe get subaru mains?
#43 |
Member#: 56345
![]() When doing ACLs I always tell people to buy 3 sets, -.025mm, STD & HX.
#44 |
Member#: 180514
Vehicle:2004 Sti WRB |
#45 | |
Member#: 121532
SCIC
![]() Quote:
I will be posting results on a std. size crank ASAP. |
#46 |
Member#: 289606
Vehicle:06 WRX white |
![]() They are really nice bearings though. The thrust bearings are a three part bearing that the block has to be machined for. So in reality its even more expensive than just the cost of the bearings.
#47 |
Member#: 133146
![]() Good news, please do. If they are good I am getting the standard king mains
#48 |
Member#: 289606
#49 |
Member#: 159243
![]() thats good news.
#50 |
Member#: 165104
SCIC
Vehicle:E85 SoCalPorting Owner |
![]() That's great to hear. My last 2 sets of ACL were all over the place. Had to put h and hx together just to make it work. New crank and clearances were great. But every bearing I ever used needed at least some massaging to get clearances right.
Hearing about these king bearings being spot on sounds too good to be true lol. Ill need to try a set. Anyone see an issue of using kings with nitrated OEM crank? Or is there a big differance material wise between acl vs king? |
ACL vs OEM bearings - sizes and clearences ? | Bad Noodle | Built Motor Discussion | 1 | 04-16-2010 07:38 PM |
Lakers vs. Kings tonight! Who's down for a meet? | phattyduck | Southern California Impreza Club Forum -- SCIC | 37 | 03-25-2004 11:51 AM |
Videos for STI vs. EVO comparos | mpgxsvcd | STi Forum Archive | 57 | 08-08-2003 02:15 PM |
comparo? re 92 vs 730 wet traction | sjt | Brakes, Steering & Suspension | 8 | 04-20-2001 08:36 AM |
