Welcome to the North American Subaru Impreza Owners Club Thursday March 4, 2021
Old 12-17-2015, 02:48 AM   #151
ALOKIN
Member#: 348177
2002 Bugeye
Haltech GTX3584RS
Originally Posted by Myblack2006sti View Post
My king bearing on my last engine spun and I run acl now
Even the best bearings in the world cant protect from shoddy machine work or crap assembly practices....
ALOKIN is offline   Reply With Quote
Old 12-17-2015, 09:53 AM   #152
Delphi
Member#: 239335
2011 WRX
This. It wasn't the bearings that caused the spun bearing.
Delphi is offline   Reply With Quote
Old 12-17-2015, 02:15 PM   #153
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
OEM is the best
spoolinsti05 is offline   Reply With Quote
Old 02-01-2017, 05:21 AM   #154
pivwani
Member#: 462261
I would not be blaming the bearings and look at the clearances and along the journals. As we know the HX ACL bearings give an extra 0.001" oil clearance. This may be required depending on your required oil pressure output. If you have used King Bearings and they have spun, you need to ask why this happened and not just blame the bearings because they have failed. The bearings are designed to fail first to protect the crank and rod surfaces.
pivwani is offline   Reply With Quote
Old 02-06-2017, 01:56 AM   #155
deom2i
Member#: 404820
2011 sH9
Satin White
Default Bought ACL Bearing 5M8309H AND 4B8296H-STD.
Just bought ACL Bearing 5M8309H AND 4B8296H-STD to rebuild my WRX 2.0 Engine with stock piston and shaft.
I came to know about King bearing after purchase, these are manufactured in June 2016, lets hope they have corrected the clearance issue with this new ones.
deom2i is offline   Reply With Quote
Old 12-25-2020, 01:33 AM   #156
benflynn
Member#: 515308
Where are on this these days
benflynn is offline   Reply With Quote
Old 01-12-2021, 07:21 PM   #157
GeoNV
Member#: 518830
2009 WRX
dark grey metallic
I just built an EJ255 with forged Manley H beam rods- my stock clearance ACL's had zero clearance- I mean none!
0.0003
-0.0003
-0.0001
-0.0003
Rod Journal sizes
2.0468
2.0468
2.0468
2.0468
I bought the extra oil clearance and eked out these after switching around a bunch of shells.
0.0019
0.0018
0.0016
0.0018
I'm nervous about that 0.0016.
The main bearings were
1 0.0013
2 0.0016
3 0.0015
4 0.0017
5 0.0013
and that's with pretty uniform journal diameters.
2.3621
2.3623
2.3622
2.3623
2.3623
Long story short- I wish I would have chosen King bearings.... I've been nervous about the ACL's since I put em in.
All of these measurements I took five times per part and averaged them- I remeasured anything that was more than a half thousandths different.
I checked with plastigauge as well to make sure I didn't make any math errors- they checked out. Except on the stock rod bearing size - I didn't even try.
Last edited by GeoNV; 01-12-2021 at 07:28 PM. Reason: Added journal sizes for rods.
GeoNV is offline   Reply With Quote
Old 01-25-2021, 01:21 PM   #158
idntvpe
Member#: 521263
Default OEM bearings
What is the ballpark for max power that OEM bearings can take?
idntvpe is offline   Reply With Quote
ACL vs OEM bearings - sizes and clearences ? Bad Noodle Built Motor Discussion 1 04-16-2010 07:38 PM
Lakers vs. Kings tonight! Who's down for a meet? phattyduck Southern California Impreza Club Forum -- SCIC 37 03-25-2004 11:51 AM
Videos for STI vs. EVO comparos mpgxsvcd STi Forum Archive 57 08-08-2003 02:15 PM
comparo? re 92 vs 730 wet traction sjt Brakes, Steering & Suspension 8 04-20-2001 08:36 AM
