Welcome to the North American Subaru Impreza Owners Club Monday March 8, 2021
Old 03-03-2016, 05:21 PM   #126
insane_one
Member#: 301431
2005 Evolution VIII
Sorry. I can only say this is will work on 04-05. Bugeyes/Hawkeyes I would imagine be the same but I cannot confirm.
insane_one is offline   Reply With Quote
Old 03-09-2016, 10:37 PM   #127
Lucien_Gauvin
Member#: 442228
2006 Subaru Sti
Grey
Default Brilliant Write up, Thanks!
Just finished wiring this all up. Very detailed and easy to follow. Thanks for including pictures of everything.
Cheers
Lucien_Gauvin is offline   Reply With Quote
Old 05-06-2016, 05:55 AM   #128
jbro16
Member#: 382625
2005 Impreza WRX STI
For those who are still wondering. 05' sti wires are blue with white stripe instead of the red with green stripe. On the relay and the fog light button. Everything else was the same. Great write up!
jbro16 is offline   Reply With Quote
Old 05-12-2016, 01:54 PM   #129
carbonwrex
Member#: 175341
2007 WRX TR
World Rally Blue
this write up worked wonderfully for my 07 wrx tr !: banana:
carbonwrex is offline   Reply With Quote
Old 05-20-2016, 02:21 AM   #130
boo-key bear
Member#: 199695
2006 impreza wrx tr
wr blue pearl
Just did this and it works. I do have a couple problems I can't figure out. The biggest one is that I have retrofitted an sti intercooler sprayer in my 06 wrx using this write up http://www.clubwrx.net/forums/engine...tallation.html and now it don't work when I push the switch. It does however spray by itself once upon ignition on. Also now my dome light stays on unless I put the switch in the off position. It used to automatically go off by itself after a little bit when the switch was in the middle position.
boo-key bear is offline   Reply With Quote
Old 06-03-2016, 02:26 AM   #131
SleepingWrex
Member#: 448222
Silver Metallic
Default Works great on my '02 Sedan
This worked perfectly on my car, I also did a DRL delete while I was messing with wires. I had run into a problem after switching to xkglow LED headlights, where if I hit the fog switch it would activate my by high beams. This also resolved that problem, which I had yet to find a solution to. Thanks!!!
SleepingWrex is offline   Reply With Quote
Old 05-12-2017, 05:54 PM   #132
dneustifter21
Member#: 461762
Default Still Lives
Bringing this thread back again. just followed and have sucess with running independent fogs. thank you very much. great post.
dneustifter21 is offline   Reply With Quote
Old 06-19-2017, 12:41 AM   #133
piddyplace
Member#: 181942
2002 wrx
Anyone done this to an sf? Is it the same?
piddyplace is offline   Reply With Quote
Old 07-05-2017, 02:20 AM   #134
TEKNOSYS
Member#: 79839
2004 WRX Premium
Sedan; Aspen White
I'm looking to do this on my '04 so I can run my JDM fogs without having my headlights on all the time. The write up seems pretty easy to follow, but the pictures don't load any longer in the first post (I really hate Photobucket). Does anybody have any pics saved any where, or is there another tutorial somewhere with pictures?
TEKNOSYS is offline   Reply With Quote
Old 07-05-2019, 06:51 PM   #135
marshm456
Member#: 477014
Default Works on an 04 Forester XT.
I just got done doing this to my 04 FXT and the steps are exactly the same. Every wire and relay you need for the project is in the exact same place. Doing this allowed me to run led fog and headlights without the brights getting stuck on. Sorry to revive an old thread but I thought it might help out other Forester owners trying to do the same thing.
marshm456 is offline   Reply With Quote
Old 08-21-2020, 01:54 AM   #136
Scubasteve009
Member#: 517838
I found a write up on this for a 99 forester a while back, I followed it to a T..!!! Mine just stay on constantly only the key turns them off and on... I just left it...***129335;***127996;****9794;***65039;***128514;
Scubasteve009 is offline   Reply With Quote
Old 09-25-2020, 04:21 PM   #137
Denver1357
Member#: 440954
2016 WRX STi
Does anyone know of a write up to do this mod on a 2016 STi?
Denver1357 is offline   Reply With Quote
Old 12-27-2020, 03:15 PM   #138
jersdunz
Member#: 426081
Cool
I just did this mod to my 2002 wrx, I have this morimoto hid projector kit & this control relay harness installed. For years I haven't been able to use high beam and the Fogs in town without manualy switching the fogs off with every high to low selection.
This mod solved that problem I'm sure there isn't a ton of folks out there with this issue and these same parts. but nonetheless this is how you fix it.
jersdunz is offline   Reply With Quote
How to DIY: DRL Disable insane_one Electrical & Lighting 28 09-14-2020 01:18 AM
Independent Foglight Mod writeup for the BE Guys MitchGT Legacy Forum 5 04-29-2005 01:20 AM
how to change the foglight bulb Grey Ghost Electrical & Lighting 12 04-27-2005 11:25 PM
how to aim my foglights? legacy2003 Electrical & Lighting 2 09-24-2004 10:14 AM
How to aim stock foglights? ShutUpGeek Electrical & Lighting 2 01-11-2004 08:20 PM
