Welcome to the North American Subaru Impreza Owners Club Tuesday March 2, 2021
Old 07-25-2012, 04:44 PM   #1
the_mirra
Member#: 295180
2007 USDM STI
WR Blue
Default 07 Sti Front Diff noises
Hi guys
I have a noise that seems from my front end. After bringing it to my local shop, they checked for that noise, the axles are tight and the front end is solid, they say I might be my front or center diff.
Here are the symptoms:
When I turn with the DCCD on auto, there is a noise from the front end like the wheels are having trouble turning, feels like front not unlocking properly.
The more you turn the worst it is.
No noise when turning wheel standing still
Not as bad on loose surface.
With the DCCD all the way back, the noise is minimal, almost non-existent. The car feels normal. This is how I run my car all the time now.
Transmission works perfectly, change all the fluids in the car this autumn; I used Redline 75W90 NS GL-5 Gear Oil in the Trans and 75W90 GL-5 Gear Oil in the rear diff.
No issues or noises when driving straight, with the DCCD auto or all the way back
opinions?
the_mirra is offline   Reply With Quote
Old 07-25-2012, 05:31 PM   #2
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
Does it sound like when a skate board wheel bearing is gone but with slight rattle to it like a loose heat sheild.
trev762 is offline   Reply With Quote
Old 07-26-2012, 10:40 PM   #3
the_mirra
Member#: 295180
2007 USDM STI
WR Blue
No, it's more a mechanical sound, like the front wheels are locked
Old 07-27-2012, 10:11 AM   #4
All4bSpinnin
Member#: 99102
17 BMW M2
Long Beach Blue 6MT
when you turn the wheel, does it sound/feed like the car is binding up?
Have you changed your trans fluid?
All4bSpinnin is offline   Reply With Quote
Old 07-27-2012, 08:26 PM   #5
the_mirra
Member#: 295180
2007 USDM STI
WR Blue
Only when dccd in auto while moving and turning, no problem turning stationary so I don't think its my suspension. No issues with the trans.
Yep, like mentioned in the first post.
Old 07-27-2012, 08:55 PM   #6
ardevas09
Member#: 164710
05 440whp STi
2014 Evo X
have you done any work to it recently?
ardevas09 is offline   Reply With Quote
Old 07-30-2012, 06:37 PM   #7
the_mirra
Member#: 295180
2007 USDM STI
WR Blue
Nothing else than what I mentioned in the first post.
How can I check my front diff?
Old 07-31-2012, 05:10 PM   #8
tekfoc
Member#: 21392
2016 C63S AMG MB
Iridium /MB C300 4MATIC
check and clean your wheel speed sensors.
when dirty or bad this will cause binding .
tekfoc is offline   Reply With Quote
Old 07-31-2012, 05:41 PM   #9
the_mirra
Member#: 295180
2007 USDM STI
WR Blue
Thanks, I will have a look at that. Would I see a ABS light or codes associate with this?
Is there anything I could physically do to check my front diff?
Old 07-31-2012, 06:13 PM   #10
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
Hey tekfoc can u explain in further detail about how to go about cleaning and what products r safe to use on the speed sensors.
Old 07-31-2012, 06:32 PM   #11
tekfoc
Member#: 21392
2016 C63S AMG MB
parts cleaner or brake cleaner sprayed to a rag .
just follow the electrical wiring to the wheel hub .
unbolt, disconnect electrical connection and remove sensor. start cleaning .do the rear sensors also!!!!!!!!!!!!
http://www.iwsti.com/forums/how-inst...l-sensors.html
Old 07-31-2012, 06:55 PM   #12
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
Thx tekfoc would a non chlorinated maf cleaner or throttle body cleaner work also besides brake cleaner as brake cleaner can be harsh on certain things. Not second guessing u just would like to start off with something not as abrasive or is brake cleaner not harsh on speed sensors.
I've tried time and time again researching about center diff issues as iam experiencing like a binding issue only at the track in hairpin turns in 3rd gear under wot at around 3-3,500rpm range. If I gear down to 2nd no issue but I loose alot of moment doing so. Sorry for the thread jack but maybe this might help also op.
Old 07-31-2012, 07:07 PM   #13
tekfoc
Member#: 21392
2016 C63S AMG MB
sure use rubbing alcohol if your worried or maf cleaner .
Old 08-11-2012, 05:24 PM   #14
the_mirra
Member#: 295180
2007 USDM STI
WR Blue
I cleaned my both of my sensors but there is no changes.
Anything else I could try out?
Old 08-11-2012, 05:43 PM   #15
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Wheel bearings? do you get any noise from the front end, doing about 30mph and veering left to right slightly? (loading the bearings)
I've had them go straight down the road and bind turning..
Old 08-11-2012, 11:00 PM   #16
the_mirra
Member#: 295180
2007 USDM STI
WR Blue
No, wheel Bearing had been inspected replaced on one side last month. the noise was there prior to that.
It seems worse when turning full lock and reversing but only when dccd is on auto
Old 08-11-2012, 11:26 PM   #17
tekfoc
Member#: 21392
2016 C63S AMG MB
if your throttle tables are adjusted too agressive this can affect the dccd.
have your tuner lower the values and see what happans .
if this is not the issue your dccd is damaged , have subaru look in to it .
Old 08-12-2012, 11:05 PM   #18
Bamofo
Member#: 159743
07 STI Limited
TurboMike Tuned 2.35
it sounds like you center diff is binding... or your dccd controller is not working properly.
Bamofo is offline   Reply With Quote
Old 01-12-2021, 02:23 AM   #19
XXXJohnny.C
Member#: 521592
Hi Mirra, Apparently I ve overcomed with the same problem. Mine is a 11 wrx without DCCD, recently it started to make a crunking sound only when turning left with reletively high speed like 40 - 50 kph / turning right with 60 - 70 kph.
I have replaced drive shaft and double checked the tranny oil. Here s what happened. There was only less than 1 L of tranny oil in the gearbox!!! I reckon the diff was broken due to lack of tranny oil.
Question if how did you fix your problem in the end? Was is mechanical or electrical?
Cheers.
Johnny
XXXJohnny.C is offline   Reply With Quote
