#1 |
Member#: 184335
South East
Vehicle:2004 STI WRB |
![]() Well while i was driving at 50 mph the car starts to make a hard clicking noise coming from the engine bay. it felt like it lost compresion and then died. engine turns but would not start at all. Just want some suggestion to what it might be or what to check before i consider taking apart the engine.
thanks in advance.
#2 |
Member#: 292532
NESIC
Vehicle:05 STI PSM |
![]() Sounds like a spun bearing to me...
#3 |
Member#: 184335
South East
![]() thanks for the response.. Anyone else?
#4 |
Member#: 43151
South East
Vehicle:04 STI Kinda Silver-ish |
![]() Would restart with spun bearing.
Check your timing/belt. |
#5 |
Member#: 184335
South East
#6 |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
![]() sounds like new motor time.....that is an almost certanty
is there any oil in it?? what oil...SPECIFICALLY was in it??? |
#7 |
Member#: 184335
South East
![]() Oil level was fine. I did a oil change myself the day before. I notice that car has been burning a quart of oil every 1000 miles. I had regular 10 w 40
#8 |
Member#: 7164
Vehicle:2000 Miata LS Evo Orange Mica (1/644) |
#9 |
Member#: 184335
South East
#10 |
Member#: 7164
![]() Turn the ignition key to the RUN position and use a OBDII scanner to see what codes it might have thrown.
#11 |
Member#: 184335
South East
#12 |
Member#: 7164
![]() You'll be fumbling in the dark until you find out if it threw any codes.
But, if you're really itching to do something, you could always pull the spark plugs and give them a look. |
#13 |
Member#: 184335
South East
![]() I will go ahead and check and get back with the info. Also thought of taking of the timing belt cover to double check as I did the head gaskets a couple of months ago.
#14 |
Member#: 521762
![]() Hey there, did you ever figure this out? My subaru just started doing this a few days ago, and this is the first post I've found that has the same problems.
#15 |
Member#: 510046
![]() Check timing.
