Welcome to the North American Subaru Impreza Owners Club Thursday March 4, 2021
Old 12-13-2017, 07:40 PM   #926
point78
Member#: 344329
2008 Wrx, 6mt
Originally Posted by bluesubie View Post
What's with the lead? Are you running an additive? Driving conditions?
I have no idea.
This was actually my 8th oil change.
There's been visible metal particles in all of the oil changes, some 1/4" sized flakes.
This last one had a bunch in it????
I've been thinking it's toast-but oil pressures have been the same since day one & these don't really show anything.
I noticed yesterday when I changed it The flakes would crumbe if I rubbed them between my fingers.
I'm wondering if they are some type of excess adhesive that's in there, I believe they glue the Darton sleeves in-possibly that?
No additive, pump 91 on 50/50 meth & [email protected]
King bearings, sleeved motor
Street driven up in the mountains, so long periods in boost, & also long periods in vacuum closed throttle. Full throttle every time I drive it, but still just street driven.
I went with Mobil1 0w40 euro FS this time, pumps a little better on cold starts (where I'm at its typically pretty cold)
point78 is offline   Reply With Quote
Old 12-19-2017, 02:15 AM   #927
mcwilly
Member#: 479406
First UOA 5,400km of Motul 8100 Xcess 5w40
70,000kms on car. Subaru oil changes every 5k kms or less till out of warranty. Then T6 or Motul every 5k kms or less.
Some high iron wear. Cobb stage 2 package, OTS map.
mcwilly is offline   Reply With Quote
Old 06-14-2018, 12:09 AM   #928
ROTORCRAFT230
Member#: 385360
2014 Impreza WRX
Plasma Blue
Here is my latest oil sample all looks good but silver is up from 1 to 3. Blackstone says not to worry.
I tried something, on the 18500 sample I had a K&N air filter in the stock box for the whole run and on the 22100 sample I had a Denso stock air filter in the stock box and the silicones were the same at 6 ppm.
Looks like the K&N and stock filter performed the same.
Another thing I’ve done is added a Filter Minder to the intake pre turbo and have noticed something interesting. Normal driving around the minder showed the indicator to be in the middle of the yellow which is normal range but under full boost the minder went to the end of the yellow and just to the tip of the red. Tried this with the Denso filter and the K&N. Both had the same results. Anybody else have a filter minder if so what have you seen.
ROTORCRAFT230 is offline   Reply With Quote
Old 06-14-2018, 08:58 AM   #929
bluesubie
Member#: 767
04 FXT
20 OB Onyx XT
Wow, do you live in a dirt free environment? This may be the only Subaru uoa on a K&N with silicon in the single digits that I’ve seen. Normally you can spot K&N users in uoa’s by looking at Si. I went back to a paper filter because Si was much lower with it. It would be interesting to see if Si continues to be low after more uoa’s and various driving conditions.
Hopefully the silver is just noise.
Old 06-14-2018, 11:39 AM   #930
ROTORCRAFT230
Member#: 385360
2014 Impreza WRX
Plasma Blue
I live an hour south of Houston lots of humidity as far as being dusty I don’t think so. This is a yearly oil change as it’s not my daily driver, car gets driven when it’s nice out. I have the Denso filter in now and was waiting on the UOA as what to use.
The silvers got me, I’m 51 and don’t beat on it at all. No launches, put the power on easy but will do full throttle. Probably nothing but as much as I drive it it will be another year for another sample.
Old 06-16-2018, 08:42 AM   #931
point78
Member#: 344329
2008 Wrx, 6mt
Here's my winter mix:
50/50
PUP 5w30
M1 0w40 euro FS
No block heater this winter, so multiple sub zero starts-hence the PUP 5w30. That stuff has really good cold flow when it's double digit neg temps.
(Engine still running fine despite all the garbage I've found in the oil, see previous posts)
Old 06-21-2018, 10:30 AM   #932
Breezio
Member#: 234357
2009 WRX
Sportwagen zum einbauen!
I have had a K&N (with a Perrin CAI) on mine for years. Si has always been single digit.
Breezio is offline   Reply With Quote
Old 06-26-2018, 06:17 PM   #933
Waddlz
Member#: 395275
2012 STi
think im going to go back to Amsoil. Motul xcess 5w-40
https://i.imgur.com/hx0Vwi4.png
Waddlz is offline   Reply With Quote
Old 06-26-2018, 07:48 PM   #934
bluesubie
Member#: 767
04 FXT
20 OB Onyx XT
IMO, you need a professional interpretation and guidance in fixing the issue. I don’t think switching brands will solve your issue.
http://www.dysonanalysis.com
Old 06-26-2018, 08:00 PM   #935
Waddlz
Member#: 395275
2012 STi
ok i sent in for dyson to interpret results
the previous UOAs were all Amsoil 10w-40 or 0w-40.
Old 06-27-2018, 10:28 AM   #936
Breezio
Member#: 234357
2009 WRX
Going from 0 silver every time to 3 silver is a potential problem as well.
Old 09-24-2018, 04:10 PM   #937
subbywrx05
Member#: 245093
2005 Sti
white
anyone else running 5w-40 t6 Rotella?
subbywrx05 is offline   Reply With Quote
Old 10-11-2018, 12:35 PM   #938
todd_fuller
Member#: 79004
2005 Impreza WRX STi
Crystal Grey
I've been running Rotella T6 in my 2005 STi for so long I can't recall if I used anything else. This is my latest UOA at 140k miles. Daily driven in Austin, TX. Stage 2 for 100k miles now, maybe more, I can't recall.
todd_fuller is offline   Reply With Quote
Old 10-11-2018, 02:38 PM   #939
bluesubie
Member#: 767
04 FXT
20 OB Onyx XT
Nice! What are filter are you running and at what mileage did you add the make-up oil?
Old 10-11-2018, 02:49 PM   #940
todd_fuller
Member#: 79004
Crystal Grey
Always the OEM filter. Probably going to move to Wix though since recent filter appear to be low quality. Can't recall makeup oil, but if I'm close to an oil change and it's a little low, I'll just do the change. Where that oil goes... no one knows.
Old 11-30-2018, 08:47 AM   #941
Stravinsky
Member#: 381085
2014 Impreza WRX STI
Blue!~
Well, finally got around to getting an oil test done now that the warranty is up. I've been having the oil/filter changed every 3600 ~ 3750 miles at the dealership with OEM filter/oil. The air filter usually gets changed every 2 or 3 oil changes since I live on a dirt road and it gets kinda bad fast.
Car is bone stock except windshield!
Stravinsky is offline   Reply With Quote
Old 11-30-2018, 02:12 PM   #942
bluesubie
Member#: 767
04 FXT
20 OB Onyx XT
Your silicon is really low so those frequent air filter changes appear to be working well! Nice uoa.
Old 12-03-2018, 03:59 PM   #943
Waddlz
Member#: 395275
2012 STi
wish i could get my silicon that low. very nice, even with subaru 5w-30.
Old 01-20-2019, 03:05 AM   #944
SMoLiK9
Member#: 446955
2012 WRX, I’m the original owner. No oil added between changes as it burns less than 1/2 quart. I believe this was with the Purolator BOSS oil filter as I’ve been using it and nothing else. As well as a Napa Gold air filter.
SMoLiK9 is offline   Reply With Quote
Old 07-05-2019, 07:02 PM   #945
ROTORCRAFT230
Member#: 385360
2014 Impreza WRX
Plasma Blue
So here is my yearly oil change. There is no knocking or ticking coming from the engine. I have been Stage 2 since January which is half way through. Car runs great I have an oil pressure and temp gages and there have been no changes there.
Fine knock learn is 0 and I get 1.4 or 2.8 feedback knock, but that seems to be normal.
Old 07-11-2019, 03:04 PM   #946
Nurp
Member#: 383782
2014 WRX STi ST
Seems like the same trend mine had. I ended up selling it but I see it from time to time and the new owner doesn't have any issues with it. While silver may show a possible issue, I don't think it's as concrete as others make it out to be.
Nurp is offline   Reply With Quote
Old 01-01-2021, 03:15 PM   #947
altonka035
Member#: 516299
2019 STI
ISM
Not sure if this is the right thread or not, didn't see another more appropriate place.
2019 STI
Bone stock mechanically, no intake, tune, etc
First sample was M1 5W30, not bad considering the general hatred for that oil amongst EJ owners.
Second was Shell Rotella Gas Truck 5W30, got it on sale for $11 and figured why not, surprised it sheared lower than the M1.
Currently have Shell Rotella Multi Vehicle 5W30 in it right now, anxious to see how that sample looks as its a heavy 5W30 while still meeting API SN requirements for warranty reasons.
altonka035 is offline   Reply With Quote
Old 01-04-2021, 01:34 PM   #948
Waddlz
Member#: 395275
2012 STi
that gas truck looks pretty good imo.
the copper is probably from your oil cooler leaching which is pretty normal for EJs. Moly is just anti-wear additive.
Si looks good, because you're using the stock filter.
It stayed well within a 30w, and I'd keep on using this for warranty purposes based on this UOA.
Old 01-05-2021, 12:26 PM   #949
bluesubie
Member#: 767
04 FXT
20 OB Onyx XT
I agree that the RGT looks good. Shell mentioned on BITOG that RGT uses higher levels of anti-oxidants.
That make-up oil for Mobil 1 may have boosted the viscosity a little bit. It's really difficult to tell how much an oil shears unless fuel is zero. There could also be a little bit of fuel contamination. HTHS will impact shear as well, but more companies are not including HTHS in their data sheets. Among M1 Resource Conserving oils, I'd go with the EP version for higher amounts of PAO.
Here's a UOA on RT6 MV from an FXT.
Notice the differences in fuel results.
Initial estimate by OAI = <1%
Follow-up OAI fuel reading by gas chromatography = 2.4%!
Same sample sent to Blackstone = Trace
Old 01-07-2021, 10:01 AM   #950
altonka035
Member#: 516299
2019 STI
ISM
I was very happy with the RGT considering I paid $11 for a 5 qt jug at Advance, I believe they quit carrying it and were clearing out any remaining inventory.
I have high hopes for the RT6 MV, was debating doing an analysis on the current oil or waiting until the following oil change when the temperatures will be warmer and should provide a better idea of how the oil handles heat (this makes sense in my head at least).
