Welcome to the North American Subaru Impreza Owners Club Wednesday February 24, 2021
Old 04-04-2014, 07:49 PM   #26
bswilmington
Member#: 217563
2006 Sti 12.68 @ 108
321WHP 422WTQ dynojet SAE
Originally Posted by KillerBMotorsport View Post
The blue one in post 18, in the background. That goes to the EBCS. Cam solenoids have blue connectors, cam position sensors are grey. Thought about cranking it, but I'm still working on the fuel system and this is just eating at me in the mean time!!
True forgot about ebcs being blue. How about evap solenoid? Is that plugged in?
bswilmington is offline   Reply With Quote
Old 04-04-2014, 08:20 PM   #27
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
On the front of the manifold, fuel purge, etc.? yes
KillerBMotorsport is offline   Reply With Quote
Old 04-04-2014, 08:36 PM   #28
BeastianSTI
Member#: 310506
2005 WRX STi
CGM
What year of harness / engine? All are from an 05 STi, right?
BeastianSTI is offline   Reply With Quote
Old 04-04-2014, 09:06 PM   #29
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
2012 STi
Old 04-04-2014, 09:47 PM   #30
bswilmington
Member#: 217563
Yeah I actually see in the on pic now the purge solenoid connected.
According to the Subaru FSM there is only couple things with grey connectors with 2 pins
Fuel injectors
Knock sensor
Crank sensor
And apparently 2 Leak diagnois connectors
Old 04-04-2014, 11:11 PM   #31
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
What the heck is a leak diagnostic connector? that stupid PCV thingy. there are two?
Old 04-04-2014, 11:48 PM   #32
bswilmington
Member#: 217563
Yeah it's that stupid PCV thingy haha. I've never seen car with 2 but then again I have not had the intake off 12 Sti yet. Wouldn't surprise me to see 2 as the harness shows 2 in this break down
Old 04-05-2014, 01:09 AM   #33
Nuke209
Member#: 108089
2003 WRX
NF Performance
Theres one near the turbo then one in the front of the manifold
Nuke209 is offline   Reply With Quote
Old 04-05-2014, 11:01 AM   #34
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Well now I feel dumb. one for not knowing and two for pulling this off a couple times already and never noticing two!
Thanks guys, really appreciate the help on this!!
Old 12-19-2020, 10:05 AM   #35
Scargod
Member#: 260314
2007 STI
silver gray metallic
Default Dieting my harness, Can I delete Leak Diagnosis Connector?
As I get it the ECU wants to see this "Leak Diagnosis Connector" as a closed circuit, as in "the PCV hose is installed".
I am dieting the harness on my 2009 FXT and I am doing a custom fuelling system, installing Cosworth TGV deletes, and adding an A/OS.
If, when I get it tuned, can this be turned off or does it matter?
Seems like the simplest thing would be to put the two wires to the connector together (so the circuit is closed) and eliminate the connector since I will not have any of the smog or evap system.
Scargod is offline   Reply With Quote
