Welcome to the North American Subaru Impreza Owners Club Tuesday March 2, 2021
Old 04-13-2014, 03:37 PM   #1
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Default Is there a replacement for this thing - oem barometric pressure sensor i think
Would be nice to replace this thing with an aftermarket piece. Anything out there?
Bad Noodle is offline   Reply With Quote
Old 04-13-2014, 07:12 PM   #2
Blackfin
Member#: 361325
2010 STi
Dark Gray Metallic
Looks like a secondary air combination valve.
What's wrong with the one you have? Is it malfunctioning or do you just not like it looking ugly?
Blackfin is offline   Reply With Quote
Old 04-13-2014, 07:52 PM   #3
HinshawWRX
Medium Frank
Member#: 140114
2013 Audi
A6 3.0T
Not a map sensor. It's part of the SECONDARY AIR INJECTION system. If it's ugly, delete it. No one is going to make an aftermarket "option" for something people delete.
Old 04-13-2014, 08:16 PM   #4
Blackfin
Member#: 361325
2010 STi
Dark Gray Metallic
Don't delete it: Keep your car intact and looking cool at the same time.
Soda blast the metal, prime it and then give it a coat of VHT high-temp black or red wrinkle paint.
Edit: Never mind...
Old 04-13-2014, 08:16 PM   #5
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Yes it's a secondary air injection valve but the value has a barometric sensor built into it. So I was wondering if there is some smaller sensor I can buy to replace it. The rest of the system is gone.
Old 04-13-2014, 08:35 PM   #6
dstroy
Member#: 283711
2012 STI sedan
Black with scratches
Cut the top off dude. Cut around the square part with a razor or dremel, straight down. It pops right off.
dstroy is offline   Reply With Quote
Old 04-13-2014, 09:03 PM   #7
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
You mean the black plastic square at the top ?
Old 04-13-2014, 10:26 PM   #8
dstroy
Member#: 283711
2012 STI sedan
Yes, just run a dremel around the raised circle or use a razor. Cut straight down. You won't be able to get the part under the connector, but the plastic is only about 1/16th" thick and you can snap it right off.
Old 04-13-2014, 10:27 PM   #9
Andrewxxcarlson
Member#: 316415
2006 WRX
Originally Posted by Blackfin View Post
Don't delete it: Keep your car intact and looking cool at the same time. Soda blast the metal, prime it and then give it a coat of VHT high-temp black or red wrinkle paint. Edit: Never mind...
Hahahaha
Andrewxxcarlson is offline   Reply With Quote
Old 04-13-2014, 11:14 PM   #10
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Sweet, thanks I'll give it a try
Old 04-25-2014, 10:34 PM   #11
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
I took a hack saw at this thing for like 20 min. It's tough to get through. I could have gotten unlucky but there was a washer in there that made it harder to cut though. I might not have been a washer, I might have gone too low and cut off the top of the metal center. I felt it strange when cutting, like something was turning in inside. Anyway, here's the result:
Old 04-25-2014, 10:59 PM   #12
JarHarms
Member#: 138994
2006 WRX, 6MT, 5x114
TMIC, FP blue, ELH
Looks good, smooth out the edges, and re install to the original harness connector. I also taped the sensor to the harness to keep it from flopping around.
JarHarms is offline   Reply With Quote
Old 04-26-2014, 12:58 AM   #13
Andrewxxcarlson
Member#: 316415
2006 WRX
That thumbnail bro.. Lolol
Old 07-20-2014, 09:16 AM   #14
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Update:
Finally got the car running and the pressure sensor works without issue. It's good to know that you don't have to be ultra gentile with it. I would guess that as long as it's cut below the bump, it should be all good.
Also found it a new home:
Old 07-22-2014, 01:14 PM   #15
Razgeiz
Member#: 358782
2013 STi
Update:
I'm glad you posted this up I will do the same this winter once I pull the stock block. I'm tired of looking at the secondary air injection system in the engine bay
Razgeiz is offline   Reply With Quote
Old 04-03-2017, 02:41 AM   #16
Jackalou
Member#: 445931
I have an 09 wrx. wondering if there really is a replacement baro sensor or another sensor I can use in place of it. The previous owner for some reason threw it out with the secondary air pump when he did the delete. No idea why. I can't find it anywhere online unless I buy an entirely new secondary air pump and just cut the sensor off. Which is $300 something from Subaru Please help.
Jackalou is offline   Reply With Quote
Old 07-11-2017, 08:04 AM   #17
EvasionOfTruth
Member#: 13282
2007 FXT
WRB SPB Edition
Been trying to locate one too. My sensor is stuck at 6.96 reading yet I'm only 150ft above sea level not 19,000ft.
EvasionOfTruth is offline   Reply With Quote
Old 12-17-2017, 03:14 AM   #18
chenchar
Member#: 424938
this has been causing me issues with my 07 sti. if i cut the black piece out and plug it in, will i be good to go? its in fail safe mode whenever the codes come up for the airpump, also when it's "working" and there arent any codes, I OVERBOOST!! help would be greatly appreciated. block off plates installed, and the valve is plugged in with the ports open. (no plumbing going to the valve whatsoever.
chenchar is offline   Reply With Quote
Old 11-06-2018, 06:53 PM   #19
Scargod
Member#: 260314
2007 STI
silver gray metallic
I successfully cut two apart. One has been on my race car for years. They are necessary for the ECU to know the correct barometric pressure so it can adjust to changes.
Used, these things are worth around $100 on Ebay!
So, the OP never got an answer.
I wonder if this cheap GM part would do the job? With an adapter pigtail it costs all of $19 from Amazon.
But will it do the job?
https://smile.amazon.com/gp/product/...DOWP300U&psc=1
https://smile.amazon.com/gp/product/...NB3NEHFM&psc=1
Scargod is online now   Reply With Quote
Old 04-22-2019, 10:06 AM   #20
redrexmeister
Member#: 111692
Anyone tried the GM pressure sensor in the above link from Amazon? Any tuning needed given it might be calibrated differently vs. OEM?
redrexmeister is offline   Reply With Quote
Old 05-27-2019, 03:58 AM   #21
chrisroug
Member#: 443156
2015 STI
Pearl White
I'd like to know also. Anyone?
chrisroug is offline   Reply With Quote
Old 08-13-2019, 01:34 AM   #22
FPV
Member#: 505239
MY baro pressure sensor has also been thrown away by the previous owner and my accessport is reading 21.76 constant lol. I really don't feel like buying a new or old pump, there must be an available sensor to buy...
FPV is offline   Reply With Quote
Old 11-21-2019, 06:18 PM   #23
Ajzride
Member#: 507776
2006 818 with EJ25T
Primer
I did try the GM 3Bar MAP sensor, and while the pin-outs are the same, the scale is different. The GM sensor reads 11.5 PSI at sea level, which is obviously low. It looks like a 4-bar map sensor would read 15.1 psi at sea level, which should be close enough to not cause any issues. Much more difficult to find a cheap 4 bar unit though. I'm just going to try and hard-code mine to 14.7 using RomRaider. If that fails I'll go find a 4-bar unit.
Ajzride is offline   Reply With Quote
Old 06-04-2020, 06:49 PM   #24
05WRX_Mark
Member#: 514969
2005 WRX
So did you either program the 3 bar sensor or find a 4 bar that works? I'm in a similar situation and I'm pretty sure the BARO sensor is causing my ECU to think I'm over boosting. I'm getting fuel cuts and code P0244 but the solenoid is working fine. I also am not getting P0234 which would be actual over boosting.
05WRX_Mark is offline   Reply With Quote
Old 06-09-2020, 10:46 AM   #25
colelemert
Member#: 515465
I did the same with mine - was worried about the pins that are between the main circular portion of the sensor and the harness itself - they shaved clean off in this picture but I was able to "lift" mine off, exposing what looked to be critical pins - turns out they aren't critical for sensor operation!
colelemert is offline   Reply With Quote
