Originally Posted by 05WRX_Mark
So did you either program the 3 bar sensor or find a 4 bar that works? I'm in a similar situation and I'm pretty sure the BARO sensor is causing my ECU to think I'm over boosting. I'm getting fuel cuts and code P0244 but the solenoid is working fine. I also am not getting P0234 which would be actual over boosting.
I did not find anything to replace it. Car seems to be running fine for me without it, but I'm using the motor in an engine swap scenario with all emissions equipment removed.
