Welcome to the North American Subaru Impreza Owners Club Tuesday March 2, 2021
Old 03-08-2015, 04:59 PM   #51
pandedrigo
Member#: 411870
2009 impreza wrx
black
You should try the rivet fix and see if the noise goes away. Are you having a hard time putting the car into gear?
pandedrigo is offline   Reply With Quote
Old 03-08-2015, 05:21 PM   #52
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg 2+ 310/370, 6sp R180
how would a rivet fix a weld that isnt broken? did you watch the video? zero movement on any of those 6 welds.
not really having any difficulty going into gear under normal circumstances. after very long drives (greater than 2hrs) then it can be a little hard getting into first or reverse from a stop. but that's it. while driving, the gear changes are normal.
gsrcrxsi is offline   Reply With Quote
Old 03-08-2015, 05:26 PM   #53
pandedrigo
Member#: 411870
2009 impreza wrx
black
The firewall could be flexing. The spot welds don't have to be broken for that to be happening. When my spot welds broke I tried using self tapping screws and the spot welds stopped moving but the noise was still present
Old 03-08-2015, 09:51 PM   #54
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
self tapping screws???
OMG
that is the WAY worst thing you could have done
Old 03-08-2015, 09:53 PM   #55
pandedrigo
Member#: 411870
2009 impreza wrx
black
I know :-\ bad habit from work. Its a good thing I finally took it to get it fixed properly
Old 03-09-2015, 07:41 PM   #56
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
i had been attempting to follow this.
http://www.wrxforums.com/forums/84-d...olt-style.html
but after pulling it apart and looking at everything again. i ended up just putting everything back together. for now.
http://i.imgur.com/UZxeFM3.png
http://i.imgur.com/htfEi5l.png
http://i.imgur.com/qkGI6yp.png
http://i.imgur.com/WABU8cm.png
I had thought that the welds being referenced in the thread were those labelled "1" and "2", but after closer examination of my car and the pics, the how-to thread is putting bolts through "5" and "6".
i pulled the lower part of the dash apart to get a look at the back side of number 5 and 6. and while the clutch was being actuated. no movement from #5 and #6 at all. drilling out 5 and 6 to put bolts through seemed like a huge waste when they arent moving anyway.
additionally, i placed my hand on the welds to try to isolate where the noise (vibrations) were coming from. i felt the most vibration from #1. which unfortunately for me, the backside isnt accessible unless I pull the whole dash. guess i'll just have to tough it out until spring.
Anyone who's pulled the dash. can you confirm that these are the only 6 welds for this upper bracket? these 6 are the "problem" right? does anyone have any better pics of the bracket with the dash removed?
Old 03-23-2015, 05:25 PM   #57
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
gsrcrxsi. i looked at mine over the past summer. i just started getting the squeek. your listed #5 was the only one just starting to crack on my car. i put a sefl tapping screw through the spot weld.it been fine since. i have one of those circuit motorsports brackets wating for warm weather to install. my car is kinda layed up now anyway. im getting a clutch and flywheel installed in the next few weeks.
424wrx is offline   Reply With Quote
Old 06-05-2015, 09:18 PM   #58
Hagen1527
Member#: 417905
2009 Impreza WRX
Blue & White
I was wondering if taking out the dash really saves you more time then not. As I do not have a shop currently to work in and have to resort to doing this in my driveway.
Hagen1527 is offline   Reply With Quote
Old 06-08-2015, 08:41 AM   #59
Bosco26
Member#: 421910
Excellent thread. I've been searching on this issue to see if this was a common issue.
Since my dash is partly out, I will do some work on the area to make sure I don't have issues down the line, especially since the car is gonna spend most of its life on the track!
Thanks for the writeup
Bosco26 is offline   Reply With Quote
Old 06-09-2015, 08:45 AM   #60
bigmaninjapan
Member#: 299064
2008 VF52 WRX Sedan
2016 Ford Transit Connect
Anyone else recently get a letter in the mail from SOA regarding this issue? I've had my car into the dealer a couple times for the squeaky clutch. I'll probably be making an appointment soon to go back with the letter in hand.
bigmaninjapan is offline   Reply With Quote
Old 06-09-2015, 10:01 AM   #61
reide181
Member#: 276915
2011 WRX Limited
Satin White Pearl
It was nearly impossible to get 2 of the 6 welds without the dash out. What we did (since the project took 2 days to figure out) was cover the wiper cowl area with a tarp while sitting outside. The hood covers a lot of the area when you shut it.
Thank you! Glad you found it useful.
I personally have not but would LOVE a copy of that posted if possible. I'll add it to the original post and I'm sure others would love to use it as leverage if they come across the same problem. If you need help covering or photoshopping your name off of it, PM me. I'll delete all the personal info off of it!
reide181 is offline   Reply With Quote
Old 06-09-2015, 12:50 PM   #62
bigmaninjapan
Member#: 299064
2008 VF52 WRX Sedan
OK. I'll send it your way when I get home.
Old 06-09-2015, 02:44 PM   #63
ninjasane
Member#: 315224
2011 WRX
I'd appreciate a copy of the letter too!
ninjasane is offline   Reply With Quote
Old 06-09-2015, 02:52 PM   #64
rumblewrx13
Member#: 420209
2013 WRX
I would also like a copy as well, maybe soa will realize and put out a recall...
rumblewrx13 is offline   Reply With Quote
Old 06-09-2015, 03:23 PM   #65
The Perfect Creature
Member#: 300620
Doubt it. No company ever wants to put out a voluntary recall on something.
They will pay out when and only if they have too.
Hence the low mileage addition of only a year/12k miles.
Most of those affected by these troubles are well outside the warranty addition and far above the mileage requirements.
The Perfect Creature is offline   Reply With Quote
Old 06-09-2015, 07:13 PM   #66
slatere17
Member#: 375471
2010 WRX Hatch
'Lightning' Red
For those that want to see the letter, I received one today as well. See the link below. I had the top 2 welds break on me and ended up drilling and bolting them which helped significantly, although I'm not exactly happy with it happening in the first place.
I agree that many of us will be outside the warranty extension, however it might help if your welds broke early on.
https://drive.google.com/file/d/0B9I...ew?usp=sharing
slatere17 is offline   Reply With Quote
Old 06-09-2015, 08:39 PM   #67
Subiezilla
Member#: 280543
You may be eligible for reimbursement if you have paid for your spot welds to be repaired in the past! I received a letter from SOA stating so.
Subiezilla is offline   Reply With Quote
Old 06-09-2015, 10:16 PM   #68
bmxhotsauce
Member#: 127099
02 IMPERZA WRX
BLACK
Just got this letter. Subaru has extended there 3 year warranty to 4 year for this issues lol so if you are out of the 45k milage you are boned. So glad I just fixed it myself for my wife. So bummed subaru does not recall this or fix it for anyone. This is a manufacturer defect 100%
bmxhotsauce is offline   Reply With Quote
Old 06-09-2015, 10:17 PM   #69
bmxhotsauce
Member#: 127099
02 IMPERZA WRX
BLACK
Sorry I forgot to add this on top.
Old 06-10-2015, 08:31 AM   #70
bigmaninjapan
Member#: 299064
2008 VF52 WRX Sedan
Sent this to the OP. Might as well post it here too.
Front:
Image001 by ch0ng, on Flickr
Back:
Image002 by ch0ng, on Flickr
Image003 by ch0ng, on Flickr
Old 06-10-2015, 11:09 AM   #71
reide181
Member#: 276915
2011 WRX Limited
Satin White Pearl
Nice! We got some good content here. Is everyone ok with me posting links to the letters in the original post? With credit of course
Old 06-10-2015, 12:00 PM   #72
bigmaninjapan
Member#: 299064
2008 VF52 WRX Sedan
No issue here.
Old 06-10-2015, 12:01 PM   #73
reide181
Member#: 276915
2011 WRX Limited
Satin White Pearl
I used a bit of everyones posted pics. Thank you! The updated section reads like this....
So, since this can happen in warranty, it must be covered right?
Our firewalls are causing huge problems, and Subaru refuses to recall or extend warranty coverage.
UPDATE: warranty coverage has been extended in June 2015 for 2008, 2009, and 2010 WRX and STI. But this only extends coverage from one extra year. Now 4yr/48,000 miles from original sale date. Thanks Subaru (sarcastic). So unless you were a leftover 2010 model car with the service date starting June 2011, you are out of luck there. They are offering reimbursements for previous work. Either way, the letter might still help people argue their case at the dealer. Thank you slatere17, bmxhotsauce, and bigmaninjapan for their provided copies of the letter. I used each and re-uploaded a Google Docs link: https://drive.google.com/file/d/0BxH...ew?usp=sharing
Old 06-10-2015, 12:13 PM   #74
subyski
Member#: 202642
08 Impreza,80Vette
68 Impala, 15 SantaFe
I received the same letter yesterday. I had a to re-read the warranty extension part a couple of times as it did not seem to make sense. All of the cars affected are already out of the extended warranty period. I bought my car in Nov 2007 and it is now 2015.
At least they are offering reimbursements but this is pretty lame from Subaru.
subyski is offline   Reply With Quote
Old 06-10-2015, 12:17 PM   #75
reide181
Member#: 276915
2011 WRX Limited
Satin White Pearl
Yeah... Seems like an "FU" from Subaru lol.
