Welcome to the North American Subaru Impreza Owners Club Monday March 8, 2021
Go Back   NASIOC > NASIOC Subaru Models > BRZ Forum
Old 10-02-2016, 10:22 PM   #1
SubeN'Siren
Member#: 151171
02 Subaru WRX
Default BRZ brakes
Thinking about a '17 BRZ.
I see upgraded Brembos are now an option...are they worth it for a non track car?
How have the standard brakes been on BRZ's so far?
Asking, because the brakes on my 02 wrx have always kind of sucked.
Upgraded pads, stainless lines, and can't trigger abs on clean pavement.
I see the standard rotors on the BRZ are larger than what I have on the wrx, and the BRZ is lighter, so they should work better.
SubeN'Siren is offline   Reply With Quote
Old 10-03-2016, 02:49 AM   #2
Stick8373
Member#: 259060
2014 BRZ
Satin White Pearl
The regular BRZ brakes are good. I've upgraded the rotors to drilled front, slotted rear with street/track pads and braided lines. All the upgrades made a HUGE a difference in braking quality. Any Brembos I have had on bikes and my STI were awesome; but with as light as the BRZ is I don't know that they will make a huge difference over the upgrades that are available.
That said, I want a '17 !!! Ha ha ha. The upgrades to the suspension and the computer on the sport package I think will, all around, make enough of a difference to make it worth it.
My .02
Stick8373 is offline   Reply With Quote
Old 10-03-2016, 05:22 PM   #3
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
Stock BRZ brakes worlds better than WRX brakes.
OrbitalEllipses is offline   Reply With Quote
Old 10-06-2016, 11:53 AM   #4
noodleface
Member#: 111952
'21 ZL1 1LE
'13 XV '19 Forester Sport
For the street, the BRZ brakes are waay better than a WRX. I added a master cylinder brace, upgraded pads (pMu HC+800s) with Centric blanks for the track (Palmer, Thompson, Watkins Glen, Lime Rock) and have had no issues. Only one of the tracks (Thompson) I go to is considered brake intensive so I've been fine with this setup.
noodleface is offline   Reply With Quote
Old 10-06-2016, 04:32 PM   #5
CopperTopNWOR
Member#: 295724
2013 BRZ Limited
If not tracking and you are the type of person tends to modify their car don't bother with the performance pack. Just a standard 17 BRZ will have the software update. The stock brakes are solid. If you are going to do coil overs the Sachs Dampers become pointless.
CopperTopNWOR is offline   Reply With Quote
Old 10-17-2016, 04:01 PM   #6
Klear
Member#: 312980
The stock brakes are fantastic, just change the fluid and pads. I am still tracking on my stock calipers, with pads and fluid upgraded (Ferodo DS2500 and Motul RBF600) and in 20 minute sessions in the AZ heat and no brake fade at all.
Klear is offline   Reply With Quote
Old 12-26-2016, 07:47 PM   #7
ChaosTheSlayer
Member#: 460291
Yeah, fot stock power, the only reasons for upgrading brake would be: looking and long-term saving on pads if the car sees a lot track days.
ChaosTheSlayer is offline   Reply With Quote
Old 04-21-2017, 08:43 PM   #8
mvessie
Member#: 466423
Default Brake swap
Hello everyone
I own a 2015 seires blue sti BRZ.
The new 2017 BRZ comes with brembo front and rear.
Will they fit the 2015 BRZ. The only difference I see
Between the two models are wheel size. 2015 17x7
The 2017 is 17x7.5. Hugs are the same for both as well.
Will this swap work and has anyone done this swap yet.
Any help would be appreciated thanks.........
mvessie is offline   Reply With Quote
Old 04-21-2017, 08:47 PM   #9
mvessie
Member#: 466423
Default Brake swap
Hello everyone
The 2017 is 17x7.5. Hubs are the same for both as well.
Old 08-18-2017, 11:50 PM   #10
cslntuee
Member#: 473112
OEM one should be good for daily drive ^^
cslntuee is offline   Reply With Quote
Old 06-30-2018, 03:04 PM   #11
FT86Z
Member#: 486566
Master cylinder brace was def a quick and worthwhile upgrade to improve brake feel.
FT86Z is offline   Reply With Quote
Old 12-10-2018, 12:07 PM   #12
Taco Man in HD
Member#: 495073
2015 BRZ turbo
x2, feels much better under hard braking with the brace. I have the Radium version.
Taco Man in HD is offline   Reply With Quote
Old 01-05-2019, 09:46 PM   #13
rsr417
Member#: 496048
2017 Impreza Sport &
Grey & Yellow
Default Upgrading to Brembos on the BRZ or "86
The brembos upgrade or the Performance Package is worth every penny. I had standard calipers on my 2013 BRZ and they were ok, I bought a 2017 Yellow Special Edition that came with the Brembos and night and day in stopping performance. I ran some tests on my 2013 and stopping hard stopping was good, on my 2017 from my marking I improved 22+/- feet. Since then I gave upgraded to Hawk Performance Ceramic Pads, and DBA Rotors, with 18X8.5/9.5 Enkei with 245/35 18 Michelin PSS. 32 foot improvement
rsr417 is offline   Reply With Quote
Old 01-05-2019, 09:51 PM   #14
rsr417
Member#: 496048
Grey & Yellow
Default Stainless Steel Brake lines Improves Response
I installed Stainless Steel Brake lines (MTEC) and flushed with Motul 660 DOT4 and am very happy with the feel and response
Old 01-13-2019, 11:42 AM   #15
Jochs02
Member#: 496394
Yea I did this as well. Definitely a noticeable difference in braking feel. Brakes don't feel as squishy.
Jochs02 is offline   Reply With Quote
Old 01-14-2019, 11:54 AM   #16
rsr417
Member#: 496048
Grey & Yellow
Default The tie bars are different
QUOTE=mvessie;45101336]Hello everyone
Any help would be appreciated thanks.........[/quote]
Old 01-14-2019, 12:09 PM   #17
rsr417
Member#: 496048
Grey & Yellow
Default Stock vs Brembo upgrade (Performance Package Brembos)
Any one who tells you the the stock brakes are great, even with SS lines, 660 fluid and pads has not driven with Brembos. I had a 2013 BRZ LIMITED and did all that. Bought a 2017 with PP Brembos. A 150% improvement. I recently installed Giant Brembos,DBA ROTORS and Hawk pads on my 2017 and KW Coils. 42 improvement at 80 mph. The reason why I changed is the I hit a ladder on the Florida Turnpike at night and and was doing 80 and saw it far enough ahead and hit it at 15mph because I could not stop in time. Had an 18 wheeler on left and car on the right.
