#26 |
Member#: 432497
Vehicle:18 Sti ISM |
![]() you have to jump the front speaker wires, they run through the telematics...look above for the IN and OUT
#27 | |
Member#: 432497
![]() Quote:
that has the SAT plug that works in it |
#28 |
Member#: 295970
Vehicle:2019 STI CWP |
![]() not sure if right thread,
but with the 2019 having car play, and using the same head-unit as the 18, would someone be able to do like a software/firmware update to the 18, so they could get carplay? I have seen this done on BMW's where the user "hacks" the head unit, to have their phone act as a chrome/apple TV cast. |
#29 | |
Member#: 221053
Vehicle:2015 WRX Blue |
![]() Quote:
#30 | |
Member#: 432497
![]() Quote:
#31 |
Member#: 432497
#32 | |
Member#: 1994
Vehicle:2018 STI WRB |
![]() Quote:
#33 |
Member#: 432497
![]() i did mine vertically, all the way back with connectors facing upwards, i did have to bend the original mounting brackets at bottom outwards to get it to fit
#34 | |
Member#: 1994
![]() Quote:
The only weirdness I ran into with my car was having to flip the RCA cables, they might have flipped the soundstage in the '18s for some dumb reason. |
#35 |
Member#: 221053
![]() I jumpered B1 to B2 and still get no sound out of that channel. I tried the others with same results so there must be something else needed
#36 |
Member#: 438216
![]() If you just want to jumper out the telemantics unit, AutoHarnessHouse.com can build you an adapter for that. This install just isn't recommended if you want to have all the functions that the telemantics unit provides.
Sometimes the telemantics unit will start setting error messages when you remove the OEM headunit. (It detects that it's missing and flags it as an error) There's a fix for this too. |
#37 |
Member#: 1994
#38 |
Member#: 432497
![]() you have to jump all four speaker leads ( each speaker has two) at the same time it is nothing more than an in and an out
#39 |
Member#: 221053
#40 | |
Member#: 432497
![]() Quote:
B1 to B2 and B9 to B10 for the left front speaker to work B3 to B4 and B11 to B12 for the right front speaker to work need at least two jumpers there to make one speaker work ...at least Last edited by phd12v; 08-01-2018 at 02:54 PM. |
#41 | |
Member#: 221053
![]() Quote:
now how do i get the gauges to work? |
#42 | |
Member#: 432497
![]() Quote:
https://i.imgur.com/McGFQOz.jpg |
#43 |
Member#: 221053
![]() thanks so much partner!!!! Ill give it a try tomorrow and let you know.
#44 | |
Member#: 1994
![]() Quote:
#45 |
Member#: 432497
![]() please remember guys and gals, the way we are doing this is the way that i got it to work.... if you call my office (Idatalink) and you go on a rant about people on NASIOC are doing it...... well just know i get to hear about it.
#46 | |
Member#: 463264
E. Canada
Vehicle:2018 WRX sport, 6MT crystal BLACK silica |
![]() Quote:
![]() just saying ![]() Thank you very much for your precious help ![]() |
#47 |
Member#: 432497
#48 |
Member#: 432497
#49 |
Member#: 463264
E. Canada
#50 |
Member#: 221053
![]() Instead of the entire ST02 kit I just got this adapter, it no workey, they dont match up.
https://www.amazon.com/iDatalink-Mae...S1179MNHDWCY91 |
