Welcome to the North American Subaru Impreza Owners Club Friday February 26, 2021
Old 01-11-2019, 07:25 PM   #76
ems111
Member#: 496082
2018 Wrx premium
Tapped into the CAN at the center display with no luck. Anyone have suggesestions? Those who go it work where did you get the CAN and what did you use to make the connection? If I can’t at least get the backup camera to work I’m just gonna out the stock unit back it.
ems111 is offline   Reply With Quote
Old 01-19-2019, 10:59 PM   #77
LouCioccio
Member#: 496163
2018 Forester
Pearl White
I have been following assortments of threads on doing what you guys have done. I have been acquiring the parts. I do have a question on the the two connectors 6 & 10 pins that go in the telemetric module. I under stand the previous posts on cans red and blue and tap them from su2 ob2 what I don't understand: the su2 has the two connectors 6 & 10 I connect the cars 6 & 10 to the telemetric module (STARLINK) and not to the su2 harness? Is that correct?
Lou Cioccio
LouCioccio is offline   Reply With Quote
Old 01-21-2019, 07:59 AM   #78
Xanthos
Member#: 496746
Default 2018 cam out different
I've got the idoing Android head unit and everything works but the backup camera. Cannot seem to get an RCA out from it even though I have 6v at the camera
Xanthos is offline   Reply With Quote
Old 01-21-2019, 09:24 AM   #79
LouCioccio
Member#: 496163
2018 Forester
Pearl White
Old 01-21-2019, 10:26 PM   #80
Xanthos
Member#: 496746
Originally Posted by LouCioccio View Post
Correct me if I'm wrong here but it looks like I should take the rca gnd to chassis gnd. I do have 6v at the camera, unless additional can lines are required to use an aftermarket unit
Old 01-31-2019, 10:20 PM   #81
Onoman
Member#: 497145
Ok so I am a bit confused. I was looking at Crutchfield and want to get the Kenwood DMX905s about two weeks ago, I put it all in my cart and everything was fine I just needed an adapter to get the back up camera to work. I went back this week to order and now nothing is compatible with the 2018 WRX and when I talked to them they said they didn't have a way to retain my satellite radio, back up camera and steering wheel controls. My question is what exactly do I need to get and do to pretty much make this pug and play with maybe some minor adjustments. Do I use the wiring harness Crutchfield will give me or do I need a totally different one? I been reading the forums and I think I am confusing myself going between the Starlink and other stuff. I do not have nav or Starlink. Is there a way to get the telemetrics without the starlink? that would be cool but not needed iof I have to do too much wiring. Any help is greatly appreciated
Onoman is offline   Reply With Quote
Old 02-18-2019, 05:45 PM   #82
gantou
Member#: 467982
2018 WRX
I just got my 4200NEX installed today, but like others my backup camera isn't working along with no OBDII data. I have a base 2018 with no telemetries. Where would I have to tap into for the CAN lines to get at least the backup camera to work?
gantou is offline   Reply With Quote
Old 02-19-2019, 03:15 AM   #83
ems111
Member#: 496082
2018 Wrx premium
Even with the help of the people here I could get my can lines to work and I didn’t wanna f it up so I just bought the 6volt step down and mine worked. I tried the CAN at the multi unit display and was told you could get it by the obd2 also. Red is CAN high I believe and blue CAN low.
Old 02-19-2019, 10:51 AM   #84
gantou
Member#: 467982
2018 WRX
Yeah I ended up ordering a 6v step down last night. While it would be nice to get the gauges the rear view is more necessary at this point. If I can get that working in the time being I'm ok waiting longer for idatalink to offer an official solution.
Old 02-19-2019, 12:37 PM   #85
SirBrass
Member#: 207263
2019 WRX Limited
World Rally Blue
I think I'm going to just wait to get an aftermarket HU till iDL comes out with an official solution. Stock 19 HUs with AA are pretty good on their own, unlike previous MYs.
SirBrass is offline   Reply With Quote
Old 02-19-2019, 01:02 PM   #86
gantou
Member#: 467982
2018 WRX
That's probably a good call if you haven't bought anything yet since it sounds like it would require the RR2. IDK if they will release a new harness to make the CAN wiring easier or if we'll still need to tap into the CAN's ourselves.
I unfortunately bought all my stuff in 2017 when I first got the car back when people didn't seem to know about the CAN line stuff yet. I waited the past almost 2 years now for a good way to do this, but after getting a new phone I really want to get Android Auto to make life easier. In retrospec I kind of regret getting the RR, I should have just gone with the SW.
Old 02-19-2019, 02:37 PM   #87
SirBrass
Member#: 207263
2019 WRX Limited
World Rally Blue
RR gives you more integration, though, and gives you backup camera pretty easily. It's the 2018+ folks who are still hosed on integration since iDL has taken so long to get it working. And 2018 specifically is doubly hosed with a really crappy HU and no way to easily integrate (without some effort) an aftermarket HU with backup camera. At least those of us with 2019s have a stock HU that doesn't suck and 2017s and prior have easy to install aftermarket integration options.
Old 02-19-2019, 03:59 PM   #88
gantou
Member#: 467982
2018 WRX
I'm just saying since I have a 2018 I'll be forced to get the RR2 to get the gauges when they figure that out. It would have been more cost efficient to go with the SW and get the AX-SUB28SWC or a similar harness to retain backup camera and aux for the time being while they work on the official solution. Because in the end I'll have to try and sell the RR or the would be SW to recoup some my money to upgrade to the RR2. I mean I'm not mad or anything I just mean if I could turn back time and do everything again, that would probably be the route I'd take.
Old 02-20-2019, 08:27 AM   #89
SirBrass
Member#: 207263
2019 WRX Limited
World Rally Blue
You'll probably have an easier time selling the MRR, and thus be able to recoup some costs rather than not being able to sell off the SW at all, and then having to undo the AX-SUB28SWC just to fully integrate the MRR2 when it comes out (if you want gauges that badly).
But I understand where you're coming from. But at least you have BUC, aux, and HU integration with a good HU instead of that terrible Starlink (Starlink app itself still crashes on the 2019's btw, and also has to be manually "force stopped" in android itself).
Old 04-02-2019, 05:56 PM   #90
arempee26
Member#: 491364
Default 2018 Wrx/Sti Radio INFO factory wiring and connectors
Okay guys, I've read the whole thread.
I just installed W4400NEX to my 2017 WRX Limited with the 7" screen, with NAV and HK. Everything works except the front speakers.
(Also, I couldn't retain the factory USB underneath the arm rest, no big deal)
I now understand that I have to plug back in the telemetric unit to get the speakers to work. But which wire exactly do I need to tap into the telemetric unit, is it the speaker wires that comes from the Pioneer HU harness? Bc right now, none of them is connected, I just plugged in the RCA cables from the RR behind the Pioneer HU. Also, where exactly do I need to tap in those wire to the telemetric.
Please help.
I've been wanting to do since day one when I got the car but it was holding me off bc I wanted to retain the HK audio then I came across with the iDL and crutchfield.
Other than that, wireless Apple Carplay is hella cool!
arempee26 is offline   Reply With Quote
Old 04-02-2019, 06:41 PM   #91
arempee26
Member#: 491364
Originally Posted by phd12v View Post
you have to jump the front speaker wires, they run through the telematics...look above for the IN and OUT
When you say "jump the front wire speakers" which wires are we taking about? Is it the front speaker wires that coming off from the after market HU harness?
Old 04-02-2019, 11:35 PM   #92
arempee26
Member#: 491364
no problem at all, do you see the wiring that supposed to go to the obd2 plug??? there are two wires in there....brown red to CAN HIGH and brown yellow to CAN LOW go to the telematics can lines... red and blue.. red is high blue is low
https://i.imgur.com/McGFQOz.jpg
Did you plugged this harness back to the telematic unit after jumping the 2 wires from the OBD2? I asked bc after doing these, I finally got front speakers working but now when I plugged in the OBD2, all lights on the dash comes on. Also, the back up camera no longer working. It was working fine before doing all of these.
Old 06-16-2019, 03:53 PM   #93
18wrx.sti
Member#: 503306
Work in progress:
PLEASE READ!!!! -------please remember guys and gals, the way we are doing this is the way that i got it to work.... if you call my office (Idatalink) and you go on a rant about people on NASIOC are doing it...... well just know i get to hear about it. and not in a good way either..... i post up info to help people get stuff done, and also it helps my team understand the importance of having this firmware available for the public. I try my best to explain things and why they are done certain ways. Just a quick reminder to not yell at people when they say it isnt covered yet. Thanks in advance-------
VIDEO REMOVAL SAME AS THE 16-17 : Subaru Wrx 2016-2017 Radio Removal step by step - YouTube
Sitting pics here for reference:
STARLINK PLUG with wire:
https://i.imgur.com/lrKcktV.jpg
28 pin plug:
https://i.imgur.com/9w1ijdk.jpg
5 pin camera plug:
https://i.imgur.com/kYUPHka.jpg
Telematics unit:
https://i.imgur.com/uPURefo.jpg
Telematics unit plug with can lines:
https://i.imgur.com/spIoC8l.jpg
https://i.imgur.com/pJtXSOR.jpg
SOS pic with new radio installed:
https://i.imgur.com/66RXpE0.jpg
Hey man! Your post helped me so much! I was stuck and frustrated but thanks to you I was able to install my Android head unit on my 2018 STi.
I have a question, what do I do with the pink single wire starlink plug?
18wrx.sti is offline   Reply With Quote
Old 06-16-2019, 08:48 PM   #94
LouCioccio
Member#: 496163
2018 Forester
Pearl White
Two things did you use the idatalink su2 harness there is a wire not sure of the color but has a STARLINK tag that goes to the pink wire. If you did not use that email Brian at autoharness he can make up a cable to let STARLINK think that the OEM radio is hooked up. Not sure if you have a STARLINK subscription that will let it know if the airbags are deployed.
Old 01-27-2020, 11:30 AM   #95
ag13
Member#: 133630
2019 WRX
I know its an old thread but I need some help. On the first page/first picture the white harness. How can I depin the connectors?
ag13 is offline   Reply With Quote
Old 12-13-2020, 11:09 AM   #96
maronsp
Member#: 517212
Default Pink wire
Hey how did you get that pink wire sorted for the starlink? You know that 8 pin connector with one pink wire..
maronsp is offline   Reply With Quote
Old 12-13-2020, 11:16 AM   #97
maronsp
Member#: 517212
Did you ever get that pink wire working on the Android head unit?
