Welcome to the North American Subaru Impreza Owners Club Monday March 8, 2021
Old 05-18-2018, 10:33 AM   #1
RobbyJG
Member#: 456604
2015 WRX STI
GBP
Default Loud clunking noise when decelerating
What’s up fellas? Trying to figure out what this noise is coming from my 13’ wrx hatch.
I recently had the throwout bearing changed because it was making a squealing noise and now that noise is gone and Ofcourse a new noise came up the same day.
The car is making a clunking metal noise when on deceleration in first and second gears. The noise is coming from the front passengers side of the car. After driving the car for about 5 minutes then noise just goes away and doesn’t come back until I start the car again later after it’s cooled off. Any input helps guy. It’s deeply appreciated.
RobbyJG is offline   Reply With Quote
Old 01-11-2021, 12:15 AM   #2
ssirb22
Member#: 521593
2009 impreza wrx
im having the same problem in my 09 wrx hatch, sounds like a similar issue but mine happens whenever my car is moving
ssirb22 is offline   Reply With Quote
Old 01-11-2021, 05:57 AM   #3
Gucciflipflops
Member#: 521349
2005 Impreza WRX
EDIT: Just noticed the original thread is from 2018... My fault...
Do you have a video of the sound?
I would check all endlinks, bushings, suspension top hats etc etc. Check those before you start diagnosing major mechanical components. Sometimes it really is the simplest things.
The only thing that sounds strange is the fact that it goes away while warm. When was the last time you changed your oil?
Gucciflipflops is offline   Reply With Quote
