Welcome to the North American Subaru Impreza Owners Club Thursday February 25, 2021
Old 12-10-2018, 02:32 AM   #1
WR50X
Member#: 494911
Default Cooparu
Beginning in Jan 2019 the Mini Cooper/ Subaru will start to evolve. Currently, I have a donor car and will start the process of converting the Mini to Subaru in Mid January. The project is to have a NA 2.5L AWD Mini Cooper rally car and to be completed by July. Even though the donor car is not a WRX I thought W and Mini R50 plus X would make a nice name.
WR50X is offline   Reply With Quote
Old 12-10-2018, 10:49 AM   #2
Homemade WRX
Member#: 33782
96 3MI Racing
search FIRST, then PM!!!
Ok, so you're planning on slamming an EJ25 with Subaru drivetrain into a classis Mini or a new age mini?
Old 12-10-2018, 12:00 PM   #3
WR50X
Member#: 494911
New age 2004 Mini, not exactly slamming it in but more of a careful installation LOL I already have STI suspension fitted.
Old 12-11-2018, 10:09 PM   #4
Homemade WRX
Member#: 33782
96 3MI Racing
Ok, that might have a fighting chance. My biggest concern would be engine width and the placement driven by front CV angle.
Old 12-12-2018, 01:57 AM   #5
WR50X
Member#: 494911
The Subaru engine is about 31" wide and the chassis rails on the Mini are 32" wide The axle distance on the Mini and Subaru are both around 20" although that will mean the radiator would be better placed in the rear quarter panels similar to the Renault R5 Turbo II
The Mini has subframes like the Subaru and currently, I use 2008+ STI type rear dampers, that's why I went with the Outback because the rear suspension uses similar dampers.
The job is going to be a challenge but so was the Mini
Old 01-22-2019, 04:05 AM   #6
WR50X
Member#: 494911
I started the project about 2 weeks ago and so far things are looking good at the rear. I spent a few days stripped down the Outback/Mini and then stripped down the rear suspension of both cars. There is a difference of about 7cm of height between the Subaru and the Mini so I had to cut the Mini chassis and hatch floor. Also, the Reiger coil overs are the same as the Subaru dampers so I can use them. Overall the Subaru rear subframe fits in position and I can still use the Mini fuel tank. Currently, I'm away working so when I return I will fabricate the mounts to bolt up the subframe and axle. What's a good photo sharing site?
Old 01-22-2019, 10:10 AM   #7
horsePOOGAS
Member#: 450712
04 STi
Imgur is what a lot of folks use. Just copy and past the picture link and it shows up.
horsePOOGAS is offline   Reply With Quote
Old 03-21-2019, 02:13 AM   #8
WR50X
Member#: 494911
As I travel a lot I got just got 2 full weeks of work done last month. I used the Mini Cooper subframe cut and weld to the Outback subframe. I didn't want to chop about the Mini chassis so using the Mini subframe gave me an alignment reference. The biggest issue the trailing arm front mount but I resolved that with welding the Subaru bracket to the Mini which will then give me some adjustment to finally align the tracking. All in all the hybrid subframe fits and the diff clears the Mini fuel tank. Next month I should finish the rear end and hopefully start cutting out the transmission tunnel
Old 05-14-2019, 01:07 AM   #9
WR50X
Member#: 494911
Phase 1 of the Mini/Subaru rally project is almost completed after 6 weeks of work. The Subaru/Mini subframe is now bolted to the Mini chassis which didn't take a lot of complicated fabrication. The idea is to use as much of the original chassis as possible. Overall the finish and fit worked out better than I thought. I will be back in June to finish phase 1 and start Phase 2 which will require a bit more thinking. A big thanks to EBC brakes for supporting our project.
Old 08-20-2019, 12:37 PM   #10
WR50X
Member#: 494911
Work and traveling got in the way so I had a slow start but picked up the pace this month. I now have the rear subframe sorted and cut up the Legacy body ready to transplant the front strut towers etc. I pulled the engine and transmission out of the Legacy in one go and did a quick fit into the Mini engine bay. Apart from cutting away the Mini transmission tunnel the engine/gearbox goes in with room to spare. Next job is to carefully cut away the front Legacy bodywork and then cut the Mini to fit the Legacy strut towers and subframe. Hopefully next week I will have some photos up on here.
Old 12-07-2020, 12:16 PM   #11
WR50X
Member#: 494911
I just realized I have not been updating the progress of my project here: COVID-19 has been good for the project. I have done nearly all the fabrication work, the wiring is 90% done and the engine and AWD drivetrain is sitting nicely in the Mini body shell. I figure I have around another 4 to 5 months before the project is on the road. look for it on Subaru engined conversions on FB.
Old 12-08-2020, 11:22 AM   #12
Absoluteyeti
Member#: 519596
97 Impreza OBS
Red to be white
Any pictures of it? (or my phone isn't loading them) I'm not sure why i would (sign up for and) check Facebook for a project I went on a forum to see...
Absoluteyeti is offline   Reply With Quote
Old 12-09-2020, 10:00 AM   #13
WR50X
Member#: 494911
Sorry I thought most folks are on FB. What is a good photo sharing site so I can post photos here thanks
Old 12-09-2020, 11:35 AM   #14
WR50X
Member#: 494911
what link do I use to share photos with photobucket?
Old 12-09-2020, 11:54 AM   #15
WR50X
Member#: 494911
Old 12-09-2020, 11:57 AM   #16
WR50X
Member#: 494911
Old 12-09-2020, 11:59 AM   #17
WR50X
Member#: 494911
Old 12-09-2020, 12:01 PM   #18
WR50X
Member#: 494911
Old 12-10-2020, 01:36 PM   #19
WhiteZombie
Member#: 338863
PSM 05 WRX WGN 5MT
95 Caprice 6spd Track Rat
Cool project! In for updates!
WhiteZombie is offline   Reply With Quote
Old 12-13-2020, 08:59 PM   #20
WR50X
Member#: 494911
Thanks. I will update more as the project concludes.
Old 01-01-2021, 07:40 PM   #21
T_Chayal
Member#: 511156
Nicely done.
Built, not bought.
T_Chayal is offline   Reply With Quote
